3048|1
24
ASF升级到3.25 [复制链接]
ASF又升级到3.25.0了。主要改进有:
Release ASF3.25 (Jul 2015)
Add SAMC20/SAMC21 device and SAMC21 Xplained Pro kit support in ASF:
  • Drivers: AC, ADC, BOD, CAN, CCL, DAC, DIVAS, DMA, EVENTS, EXTINT, NVM, PAC, PORT, RTC, SDADC, SERCOM(SPI, USART, I2C), System(clock, interrupt, pinmux, power, reset), TC, TCC, WDT
  • Services: eeprom, delay
  • Third party: CMSIS, freertos, fatfs
  • Applications: led_toggle, getting-started, dac_sound_player, sleepwalking_adc, xosc32k_failure_detector
SAM V70/V71/E70/S70 devices and SAMV71-ULTR board support
  • Drivers: AFEC, ACC, CHIPID, AES, DAC, EFC, GPBR, ICM, MATRIX, PIO, PMC, PWM, RSTC, RTC, RTT, SMC, SSC, SUPC, SPI, TC, TRNG, TWIHS, UART, USART, WDT
  • Services: flash_efc, delay, clock, ioport, serial, sleepmgr
  • Applications: xplained_pro_user_application, getting-started
SAM D21 Analog Comparator modes example
WINC1500 driver update to rev 19.2.1 and add IoT sensor/cloud demos
ASF 3.25.0的下载地址是:
https://gallery.atmel.com/Products/Details/6f04539f-2222-477a-92c8-2ef62a28f09a?
因为一下原因,下载速度可能很慢。如果你下载不了,可以到下面网盘下载。
链接已隐藏,如需查看请登录或者注册
文件名: as-asf-msi-6.2.1323-win32.win32.x86.msi
ASF升级到3.25.0后,发现SAM L21的例程只有149个了,比3.24.2时还少了一个。
好事,关注一下。   详情 回复 发表于 2015-7-13 09:29
565
513
裸片初长成(中级)
好事,关注一下。
