2913|11
小弟跪求大神帮助 [复制链接]
由于本人在单片机数菜鸟级别,下面这程序已经调试半个来月,搞得寝食难安,现已经筋疲力尽,在这发出求助 还请大神们伸出援助之手 帮帮小弟,小弟将万分感激。本程序为电池保护程序 ,过放切断负载 过充切断 充电太阳能板
//     PIC16F616头文件
#include
#include
//     PIC16F616配置
__CONFIG(0x3F04);
//    宏定义
#define uint  unsigned int
#define uchar unsigned char
#define Solar_SW   RA2
#define Load_SW    RA4
#define led        RA5
#define LOW_V         224   //2.8V
#define LOW_renew     253   //3.1V
#define HIGH_V        341   //4.25V
#define HIGH_renew    327   //4.08V
#define Solar_V       200   //2.5V
void  delay1(uint x)      //延时程序 1ms
uint a,b;
for(a=x;a>0;a--)
      for(b=110;b>0;b--);
//     全局变量
uint  DC_vbat,DC_vbat1;
void  initialIO()
    TRISA=0x01;
    TRISC=0x01;
    TRISA3=1;
        PORTA=0xfe;
    ANSEL=0x11;
    delay1(10);
//   AD初始化
void ad_init(uchar channel)
        while(GO_nDONE);
        switch(channel)
        case 0:TRISA0=1;ANS0=1; break;
        case 1:TRISA1=1;ANS1=1; break;
        case 2:TRISA2=1;ANS2=1; break;
        case 3:TRISA4=1;ANS3=1; break;
        case 4:TRISC0=1;ANS4=1; break;
        case 5:TRISC1=1;ANS5=1; break;
        case 6:TRISC2=1;ANS6=1; break;
        case 7:TRISC3=1;ANS7=1; break;
     ADCON0=0xc1;
     ADCON1=0x04;
     delay1(10);
//  AD读电压
uint ad_read(uchar channel)
        uint adval;
        while(GO_nDONE);
        ADON=1;
    switch(channel)
        case 0: {CHS2=0;CHS1=0;CHS0=0;}break;
        case 1: {CHS2=0;CHS1=0;CHS0=1;}break;
        case 2: {CHS2=0;CHS1=1;CHS0=0;}break;
        case 3: {CHS2=0;CHS1=1;CHS0=1;}break;
        case 4: {CHS2=1;CHS1=0;CHS0=0;}break;
                case 5: {CHS2=1;CHS1=0;CHS0=1;}break;
                case 6: {CHS2=1;CHS1=1;CHS0=0;}break;
                case 7: {CHS2=1;CHS1=1;CHS0=1;}break;
        default:break;
        delay1(10);
        GO_nDONE=1;
        while(GO_nDONE);
        adval=ADRESH;
        adval=adval<<8|ADRESL;
        return(adval);
void chargingled()
                DC_vbat1=ad_read(4);
                        if(DC_vbat1<=Solar_V)
                                led=1;
                                delay1(600);
                                led=0;
                                delay1(600);
      else
              led=1;
//    主函数
void Dischang()
        delay1(10);
     DC_vbat=ad_read(0);
     if(DC_vbat<=LOW_V)         //低压保护
                        Solar_SW=0;
                        Load_SW=1;
                        chargingled();
                        delay1(10);
                        do{
                DC_vbat=ad_read(0);
                                delay1(10);
                                Solar_SW=0;
                                delay1(20);
                                chargingled();
                                Load_SW=1;
                                delay1(50);
            while(DC_vbat<=LOW_renew);//2.5~2.9低压恢复;
                        //Load_SW=1;
     else if((DC_vbat>LOW_V)&&(DC_vbat< HIGH_V))  //充电放电
                            Load_SW=0;
                delay1(10);
                    Solar_SW=0;
                                delay1(10);
                                chargingled();
                delay1(10);
          else if (DC_vbat>=HIGH_V)  //高压保护
                                        Solar_SW=1;
                   do{
                        Solar_SW=1;
                              Load_SW=0;
                                                delay1(20);
                                                chargingled();
                         delay1(10);
                     while((DC_vbat>=HIGH_renew)); //4.08~4.35高压恢复
//    主函数
void main(void)
        delay1(1000);
        initialIO();
        ad_init(0);
        ad_init(4);
    while(1)
                Dischang();
Protel Schematic.pdf
71.52 KB, 下载次数: 6
电路硬件部分
1.首先,要说明你要完成功能的具体要求,如电压工作点,监视点,有无低功耗要求等, 2.另外应该提供下你的硬件原理图(对软件编写有关的部分就可以) 3.最好说明下现阶段你卡在哪里,好针对性的帮助解决问题.  详情 回复 发表于 2015-7-13 15:27
顶起啊 不要沉下去  怎么没人帮我
4008
这种贴不太好帮,不知道你哪里有问题.
211
对啊····应该具体说说程序运行出了什么问题····
个人签名You have to do everything you can.You have to work your hardest.And if you do,if you stay positive,the you have a shot at a sliver lining.
1298
楼主只要思路对了应该是没问题的,无非就是单片机检测电压和IO开启和关断操作,思路思路……
huo_hu 发表于 2015-7-9 16:03
这种贴不太好帮,不知道你哪里有问题.
现在问题就是 低压保护后 恢复供电要等到4V才可以
2886
那么长的代码,很少有人会认真读一遍的
个人签名昵称:灰小子
exiao 发表于 2015-7-9 17:32
那么长的代码,很少有人会认真读一遍的
好吧 还是得自己解决
你也可以外包的  详情 回复 发表于 2015-7-9 22:42
3471
把思路捋清楚,问题就应该就简单一些了。恢复供电要等到4V才可以,看看程序在小于4V时的运行情况。
2886
你也可以外包的
136
跟你一样也是菜鸟,逛逛看看能不能遇到大神
638
