3074|0
CC2530串口打印出错的问题 [复制链接]
从串口中得到数据,先存入环形数组,再从环形数组中读取数字,分析之后通过原串口发送,利用串口助手显示在电脑上。可是存在有的数据能够正常打印,有的数据却不行的问题。
利用串口助手发送数据为:AT+SEND=18,1,0,123,8,00 12 4B 00 07 22 AC 92
环形数组存储和读取都没有问题
//读取尾指针指向的的地址中存储的需要调用的命令长度
  CMD_Len = *(UART_StoreBuf + UART_StoreBuf_tail_pointer);
  UART_StoreBuf_tail_pointer++;
  UART_StoreBuf_tail_pointer %= UART_StoreBuf_Len_MAX;
  sprintf(temp,"CMD_Len:%d\r\n",CMD_Len);
  HalUARTWrite(0, temp, strlen(temp));
  //将环形数组中的命令读取拼接出来,存入命令分析缓存区
  if((UART_StoreBuf_tail_pointer + CMD_Len) <= UART_StoreBuf_Len_MAX)
    memcpy(UartData_Behavior_Buf,UART_StoreBuf + UART_StoreBuf_tail_pointer,CMD_Len);
  }else
    temp1 = UART_StoreBuf_Len_MAX - UART_StoreBuf_tail_pointer;
    memcpy(UartData_Behavior_Buf,UART_StoreBuf + UART_StoreBuf_tail_pointer, temp1);
    temp2 = CMD_Len - temp1;
    memcpy(UartData_Behavior_Buf + temp1,UART_StoreBuf,temp2);
  //对命令分析缓存区中的数据经行分析
  p1 = strchr((const char*)UartData_Behavior_Buf,',');
  memcpy(num_str,UartData_Behavior_Buf,1);
  CMD = atoi(num_str);
  sprintf(temp,"CMD:%d\r\n",CMD);
  if(CMD == 1)
    p2 = strchr((const char*)(p1+1),',');
    memcpy(num_str,p1+1,p2-p1-1);
    operate = atoi(num_str);
    sprintf(temp,"operate:%d\r\n",operate);
    p3 = strchr((const char*)(p2+1),',');
    memcpy(num_str,p2+1,p3-p2-1);
    SettingIndex = atoi(num_str);
    sprintf(temp,"SettingIndex:%d\r\n",SettingIndex);
    p4 = strchr((const char*)(p3+1),',');
    memcpy(num_str,p3+1,p4-p3-1);
    data_len = atoi(num_str);
    sprintf(temp,"data_len:%d\r\n",data_len);
    memcpy(Data,p4+1,8);
    sprintf(temp,"Data:%X\r\n",Data[7]);
    //HalUARTWrite(0, "WhiteList\r\n", 11);
    //调用数据处理函数
    rev = Data_Process(operate,data_len,WhiteList_Data);
    sprintf(temp,"rev:%d\r\n",rev);
    if(rev)
      HalUARTWrite(0, "Update tail pointer\r\n", 21);
      HalLcdWriteString( "Update", HAL_LCD_LINE_1 );
      //发送完成,更新尾指针
      UART_StoreBuf_tail_pointer += CMD_Len;
    }else
      UART_StoreBuf_tail_pointer--;
      HalLcdWriteString( "fail", HAL_LCD_LINE_1 );
      sprintf(temp,"tail_pointer:%d\r\n",UART_StoreBuf_tail_pointer);
    HalUARTWrite(0, "fail!\r\n", 7);
求指导!!!谢谢!!
data_len和Data没有打印,后面的尾指针也没有打印!
此帖出自无线连接论坛
