2527|0
659
Manley BSP 移植 [复制链接]
STATIC const PINMUX_GRP_T pinmuxing[] = {
        /* UART0 */
        {0, 0,  (IOCON_FUNC1 | IOCON_MODE_INACT | IOCON_DIGITAL_EN)}, /* UART0 RX */
        {0, 1,  (IOCON_FUNC1 | IOCON_MODE_INACT | IOCON_DIGITAL_EN)}, /* UART0 TX */
        /* UART1 */
        {0, 5,  (IOCON_FUNC1 | IOCON_MODE_INACT | IOCON_DIGITAL_EN)}, /* UART1 RX */
        {0, 6,  (IOCON_FUNC1 | IOCON_MODE_INACT | IOCON_DIGITAL_EN)}, /* UART1 TX */
        /* SPI0 */
        {0, 11, (IOCON_FUNC1 | IOCON_MODE_INACT | IOCON_DIGITAL_EN)}, /* SPI0_SCK */
        {0, 12, (IOCON_FUNC1 | IOCON_MODE_INACT | IOCON_DIGITAL_EN)}, /* SPI0_MOSI */
        {0, 13, (IOCON_FUNC1 | IOCON_MODE_INACT | IOCON_DIGITAL_EN)}, /* SPI0_MISO */
        {0, 14, (IOCON_FUNC0 | IOCON_MODE_PULLUP | IOCON_DIGITAL_EN)}, /* SPI0_SSEL0 software control */
        /* SPI1 */
        {1, 5,  (IOCON_FUNC2 | IOCON_MODE_INACT | IOCON_DIGITAL_EN)}, /* SPI1_SSEL0 */
        {1, 6,  (IOCON_FUNC2 | IOCON_MODE_INACT | IOCON_DIGITAL_EN)}, /* SPI1_SCK */
        {1, 7,  (IOCON_FUNC2 | IOCON_MODE_INACT | IOCON_DIGITAL_EN)}, /* SPI1_MOSI */
        {1, 8,  (IOCON_FUNC2 | IOCON_MODE_INACT | IOCON_DIGITAL_EN)}, /* SPI1_MISO */
        /* I2C0 */
        {0, 23, (IOCON_FUNC1 | IOCON_MODE_INACT | IOCON_DIGITAL_EN | IOCON_STDI2C_EN)}, /* I2C0_SCL (SCL) */
        {0, 24, (IOCON_FUNC1 | IOCON_MODE_INACT | IOCON_DIGITAL_EN | IOCON_STDI2C_EN)}, /* I2C0_SDA (SDA) */
        /* ADC Input */
        {1, 4,  (IOCON_FUNC0 | IOCON_MODE_INACT | IOCON_ANALOG_EN)}, /* ADC7 */
        /* LED Output */
        {0, 30, (IOCON_FUNC0 | IOCON_MODE_PULLDOWN | IOCON_DIGITAL_EN)},
        {0, 29, (IOCON_FUNC0 | IOCON_MODE_PULLDOWN | IOCON_DIGITAL_EN)},
        {0,  8, (IOCON_FUNC0 | IOCON_MODE_PULLDOWN | IOCON_DIGITAL_EN)},
        {0,  7, (IOCON_FUNC0 | IOCON_MODE_PULLDOWN | IOCON_DIGITAL_EN)},
        /* Key&Joy Input */
        {0, 31, (IOCON_FUNC0 | IOCON_MODE_INACT | IOCON_DIGITAL_EN)}, // B2
        {1, 13, (IOCON_FUNC0 | IOCON_MODE_INACT | IOCON_DIGITAL_EN)}, // B3
        {1, 11, (IOCON_FUNC0 | IOCON_MODE_INACT | IOCON_DIGITAL_EN)}, // right
        {1, 14, (IOCON_FUNC0 | IOCON_MODE_INACT | IOCON_DIGITAL_EN)}, // up
        {1, 15, (IOCON_FUNC0 | IOCON_MODE_INACT | IOCON_DIGITAL_EN)}, // left
        {1, 16, (IOCON_FUNC0 | IOCON_MODE_INACT | IOCON_DIGITAL_EN)}, // select
        {1, 17, (IOCON_FUNC0 | IOCON_MODE_INACT | IOCON_DIGITAL_EN)}  // down
LCD_BLC位于PIO1_9,该引脚没有连接到任何Timer的输出引脚,不能使用TimerPWM功能进行背光亮度调节,设计不当。
在使用杜邦线连接SPI逻辑分析仪时,发现LCD显示有很多杂点,分析为SPI频率过高(DIV=1SPI_SCLK = 50MHz),当DIV设置为较大值(比如DIV=10SPI_SCLK=100M/11DIV=49SPI_SCLK = 100M/50 = 2MHz)。这个现象推测可能原因有:(1)过长的传输线(杜邦线)导致高频信号出现反射等信号完整性问题。(2)简易逻辑分析仪输入阻抗较低,造成高频信号畸变);
总之,该问题可以认为是一个信号完整性的问题。
(注:由于无示波器等仪器,无法呈现50MHz时加入杜邦线的波形畸变情况,有待条件完备时进行测试)
MDM2802_SPI-TFT-LCD_SPI-DIV=10.logicsession
MDM2802_SPI-TFT-LCD_SPI-DIV=49.logicsession
SPI-Flash
SPI_Flash_WriteStaReg(0x00);
SPI_Flash_DevID
SPI_Flash_ChipErase
SPI_Flash_PageWrite
SPI_Flash_Busy
SPI_Flash_Read
USART0_Bootloader
Synchronized
N
I2C Temp
查看本帖全部内容,请登录或者注册
此帖出自NXP MCU论坛
直播时间:3月12日(周三)上午10:00
直播奖励:多功能榨汁机、蓝牙音箱、手机支架
