4328|2
tm4c129 进不去 i2c从接收中断 [复制链接]
求助 使用的examples\peripherals\i2c目录下的i2c 从接收程序,不触发接收中断程序,下面是代码
// hello.c - Simple hello world example.
// Copyright (c) 2013-2014 Texas Instruments Incorporated.  All rights reserved.
// Software License Agreement
// Texas Instruments (TI) is supplying this software for use solely and
// exclusively on TI's microcontroller products. The software is owned by
// TI and/or its suppliers, and is protected under applicable copyright
// laws. You may not combine this software with "viral" open-source
// software in order to form a larger program.
// THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS.
// NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT
// NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. TI SHALL NOT, UNDER ANY
// CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL
// DAMAGES, FOR ANY REASON WHATSOEVER.
// This is part of revision 2.1.0.12573 of the EK-TM4C1294XL Firmware Package.
#include
#include
#include "inc/hw_memmap.h"
#include "inc/hw_types.h"
#include "inc/hw_i2c.h"
#include "inc/hw_ints.h"
#include "driverlib/gpio.h"
#include "drivers/pinout.h"
#include "driverlib/pin_map.h"
#include "driverlib/rom.h"
#include "driverlib/rom_map.h"
#include "driverlib/sysctl.h"
#include "driverlib/uart.h"
#include "driverlib/i2c.h"
#include "utils/uartstdio.h"
//! \addtogroup example_list
Hello World (hello)
//! A very simple ``hello world'' example.  It simply displays ``Hello World!''
//! on the UART and is a starting point for more complicated applications.
//! Open a terminal with 115,200 8-N-1 to see the output for this demo.
// System clock rate in Hz.
uint32_t g_ui32SysClock;
#define SLAVE_ADDRESS           0x3C
static uint32_t g_ui32DataRx;
static bool g_bIntFlag = false;
// The error routine that is called if the driver library encounters an error.
#ifdef DEBUG
void
__error__(char *pcFilename, uint32_t ui32Line)
#endif
// Configure the UART and its pins.  This must be called before UARTprintf().
void
ConfigureUART(void)
    // Enable the GPIO Peripheral used by the UART.
    ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
    // Enable UART0
    ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_UART2);
    // Configure GPIO Pins for UART mode.
    ROM_GPIOPinConfigure(GPIO_PA6_U2RX);
    ROM_GPIOPinConfigure(GPIO_PA7_U2TX);
    ROM_GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_6 | GPIO_PIN_7);
    // Initialize the UART for console I/O.
    UARTStdioConfig(2, 115200, g_ui32SysClock);
void
I2C0SlaveIntHandler(void)
    // Clear the I2C0 interrupt flag.
    I2CSlaveIntClear(I2C0_BASE);
    // Read the data from the slave.
    g_ui32DataRx = I2CSlaveDataGet(I2C0_BASE);
    // Set a flag to indicate that the interrupt occurred.
    g_bIntFlag = true;
// Print "Hello World!" to the UART on the Intelligent UART Module.
int
main(void)
                        uint32_t ui32DataTx;
    // Run from the PLL at 120 MHz.
    g_ui32SysClock = MAP_SysCtlClockFreqSet((SYSCTL_XTAL_25MHZ |
                SYSCTL_OSC_MAIN | SYSCTL_USE_PLL |
                SYSCTL_CFG_VCO_480), 120000000);
    // The I2C0 peripheral must be enabled before use.
    SysCtlPeripheralEnable(SYSCTL_PERIPH_I2C0);
    // For this example I2C0 is used with PortB[3:2].  The actual port and
    // pins used may be different on your part, consult the data sheet for
    // more information.  GPIO port B needs to be enabled so these pins can
    // be used.
    // TODO: change this to whichever GPIO port you are using.
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOB);
    // Configure the pin muxing for I2C0 functions on port B2 and B3.
    // This step is not necessary if your part does not support pin muxing.
    // TODO: change this to select the port/pin you are using.
    GPIOPinConfigure(GPIO_PB2_I2C0SCL);
    GPIOPinConfigure(GPIO_PB3_I2C0SDA);
    // Select the I2C function for these pins.  This function will also
    // configure the GPIO pins pins for I2C operation, setting them to
    // open-drain operation with weak pull-ups.  Consult the data sheet
    // to see which functions are allocated per pin.
    GPIOPinTypeI2CSCL(GPIO_PORTB_BASE, GPIO_PIN_2);
    GPIOPinTypeI2C(GPIO_PORTB_BASE, GPIO_PIN_3);
    // Enable loopback mode.  Loopback mode is a built in feature that helps
    // for debug the I2Cx module.  It internally connects the I2C master and
    // slave terminals, which effectively lets you send data as a master and
    // receive data as a slave.  NOTE: For external I2C operation you will need
    // to use external pull-ups that are faster than the internal pull-ups.
    // Refer to the datasheet for more information.
    HWREG(I2C0_BASE + I2C_O_MCR) |= 0x01;
    // Enable the I2C0 interrupt on the processor (NVIC).
    ROM_IntEnable(INT_I2C0);
    // Configure and turn on the I2C0 slave interrupt.  The I2CSlaveIntEnableEx()
    // gives you the ability to only enable specific interrupts.  For this case
    // we are only interrupting when the slave device receives data.
    I2CSlaveIntEnableEx(I2C0_BASE, I2C_SLAVE_INT_DATA);
    // Enable and initialize the I2C0 master module.  Use the system clock for
    // the I2C0 module.  The last parameter sets the I2C data transfer rate.
    // If false the data rate is set to 100kbps and if true the data rate will
    // be set to 400kbps.  For this example we will use a data rate of 100kbps.
    I2CMasterInitExpClk(I2C0_BASE, g_ui32SysClock, false);
    // Enable the I2C0 slave module.
    I2CSlaveEnable(I2C0_BASE);
    // Set the slave address to SLAVE_ADDRESS.  In loopback mode, it's an
    // arbitrary 7-bit number (set in a macro above) that is sent to the
    // I2CMasterSlaveAddrSet function.
    I2CSlaveInit(I2C0_BASE, SLAVE_ADDRESS);
    // Tell the master module what address it will place on the bus when
    // communicating with the slave.  Set the address to SLAVE_ADDRESS
    // (as set in the slave module).  The receive parameter is set to false
    // which indicates the I2C Master is initiating a writes to the slave.  If
    // true, that would indicate that the I2C Master is initiating reads from
    // the slave.
    I2CMasterSlaveAddrSet(I2C0_BASE, SLAVE_ADDRESS, false);
    // Set up the serial console to use for displaying messages.  This is just
    // for this example program and is not needed for proper I2C operation.
    ConfigureUART();
    // Enable interrupts to the processor.
    ROM_IntMasterEnable();
    // Display the example setup on the console.
    UARTprintf("I2C Slave Interrupt Example ->");
    UARTprintf("\n   Module = I2C0");
    UARTprintf("\n   Mode = Receive interrupt on the Slave module");
    UARTprintf("\n   Rate = 100kbps\n\n");
    // Initialize the data to send.
    ui32DataTx = 'I';
    // Indicate the direction of the data.
    UARTprintf("Transferring from: Master -> Slave\n");
    // Display the data that I2C0 is transferring.
    UARTprintf("  Sending: '%c'", ui32DataTx);
    // Place the data to be sent in the data register.
    I2CMasterDataPut(I2C0_BASE, ui32DataTx);
    // Initiate send of single piece of data from the master.  Since the
    // loopback mode is enabled, the Master and Slave units are connected
    // allowing us to receive the same data that we sent out.
    I2CMasterControl(I2C0_BASE, I2C_MASTER_CMD_SINGLE_SEND);
    // Wait for interrupt to occur.
    while(!g_bIntFlag)
    // Display that interrupt was received.
    UARTprintf("\n  Slave Interrupt Received!\n");
    // Display the data that the slave has received.
    UARTprintf("  Received: '%c'\n\n", g_ui32DataRx);
    // Loop forever.
    while(1)
中断向量表配置了吗?  详情 回复 发表于 2015-5-29 14:15
81
你有主机发送数据的代码吗
1945
32
中断向量表配置了吗?
【直播时间】5月28日(周三)上午10:00
