淺析android下如何通過jni監控wifi網絡連接、dhcpcd執行和power電源控制
- 轉載的:http://blog.chinaunix.net/u1/38994/showart_1274854.html
libs/android_runtime/android_net_wifi_Wifi.cpp
部分jni接口
static JNINativeMethod gWifiMethods[] = {
{ "loadDriver", "()Z", (void *)android_net_wifi_loadDriver },
{ "setPowerModeCommand", "(I)Z", (void*) android_net_wifi_setPowerModeCommand },//電源管理
{ "connectToSupplicant", "()Z", (void *)android_net_wifi_connectToSupplicant },
{ "waitForEvent", "()Ljava/lang/String;", (void*) android_net_wifi_waitForEvent },
{ "disconnectCommand", "()Z", (void *)android_net_wifi_disconnectCommand },
int register_android_net_wifi_WifiManager(JNIEnv* env)
return AndroidRuntime::registerNativeMethods(env,
WIFI_PKG_NAME, gWifiMethods, NELEM(gWifiMethods));//登記jni
libs/android_runtime/AndroidRuntime.cpp
static const RegJNIRec gRegJNI[] = {
REG_JNI(register_android_net_wifi_WifiManager),
int AndroidRuntime::startReg(JNIEnv* env)
register_jni_procs(gRegJNI, NELEM(gRegJNI), env);
=>startReg(env)即調用方法int AndroidRuntime::startReg(JNIEnv* env)
wifi_load_driver
wifi_start_supplicant
=>ensure_config_file_exists
//檢查/data/misc/wifi/wpa_supplicant.conf文件是否存在,如果不存在,那麽從/system/etc/wifi/wpa_supplicant.conf動態拷貝一份
=>wifi_connect_to_supplicant
ctrl_conn = wpa_ctrl_open(ifname);
monitor_conn = wpa_ctrl_open(ifname);
wpa_ctrl_attach(monitor_conn);
=>wifi_wait_for_event
=>wpa_ctrl_recv(monitor_conn, buf, &nread);
=>recv(ctrl->s, reply, *reply_len, 0);//阻塞等待wpa_supplicant的netlink數據過來
=>如果接收的buf數據區,buf[0]爲'<',那麽說明有level級別信息,所以將'<'...'>'數據剔除,然後wifi_wait_for_event函數返回[luther.gliethttp].
java/android/android/net/wifi/WifiMonitor.java
public class WifiMonitor {
public void startMonitoring() {
new MonitorThread().start();//啓動java線程
class MonitorThread extends Thread {
public MonitorThread() {
super("WifiMonitor");
public void run() {
for (;;) {
ensureSupplicantConnection();//=>WifiNative.connectToSupplicant調用jni函數android_net_wifi_connectToSupplicant
String eventStr = WifiNative.waitForEvent();//=>調用jni函數android_net_wifi_waitForEvent
//private static final int CONNECTED = 1;
//private static final int DISCONNECTED = 2;
//private static final String eventPrefix = "CTRL-EVENT-";
//private static final int eventPrefixLen = eventPrefix.length();
//private static final String connectedEvent = "CONNECTED";
//private static final String disconnectedEvent = "DISCONNECTED";
String eventName = eventStr.substring(eventPrefixLen);//去掉"CTRL-EVENT-"字符串
int nameEnd = eventName.indexOf(' ');//找到隨後的空格位置,這在wpa_supplicant發送時
//#define WPA_EVENT_CONNECTED "CTRL-EVENT-CONNECTED "中,已經內置空格了.
if (nameEnd != -1)
eventName = eventName.substring(0, nameEnd);
int event;
if (eventName.equals(connectedEvent))//檢測netlink過來的字符串action類型
event = CONNECTED;
else if (eventName.equals(disconnectedEvent))
event = DISCONNECTED;
int ind = eventStr.indexOf(" - ");//CTRL-EVENT-CONNECTED - Connection to ...
if (ind != -1)
eventData = eventStr.substring(ind + 3);
//剔除前導控制字符,將" - "後面的描述字符串作爲真實數據,繼續處理
if (event == STATE_CHANGE) {
handleSupplicantStateChange(eventData);
} else if (event == DRIVER_STATE) {
handleDriverEvent(eventData);
} else {
handleEvent(event, eventData);//對于CONNECTED和DISCONNECTED等netlink事件將執行此操作來處理[luther.gliethttp]
// If supplicant is gone, exit the thread
if (event == TERMINATING) {
break;
void handleEvent(int event, String remainder) {
switch (event) {
case DISCONNECTED:
handleNetworkStateChange(NetworkInfo.DetailedState.DISCONNECTED, remainder);
break;
case CONNECTED:
handleNetworkStateChange(NetworkInfo.DetailedState.CONNECTED, remainder);//控制界面顯示
break;
public class WifiStateTracker extends NetworkStateTracker {
public void startEventLoop() {
mWifiMonitor.startMonitoring();//啓動上面的MonitorThread線程
java/services/com/android/server/WifiService.java
public class WifiService extends IWifiManager.Stub {
private boolean setWifiEnabledBlocking(boolean enable) {
final int eventualWifiState = enable ? WIFI_STATE_ENABLED : WIFI_STATE_DISABLED;
if (enable) {
if (WifiNative.loadDriver()) {
Log.e(TAG, "Failed to load Wi-Fi driver.");
updateWifiState(WIFI_STATE_UNKNOWN);
return false;
if (WifiNative.startSupplicant()) {
WifiNative.unloadDriver();
Log.e(TAG, "Failed to start supplicant daemon.");
return false;
mWifiStateTracker.startEventLoop();
//啓動MonitorThread線程,等待wpa_supplicant將netlink數據轉發過來,然後根據netlink動作類型,進一步影響界面顯示[luther.gliethttp].
java/android/android/net/wifi/WifiStateTracker.java
電源管理
private void handleConnectedState() {
mDhcpTarget.obtainMessage(EVENT_DHCP_START).sendToTarget();//傳遞到下面的handleMessage方法
public void onChange(boolean selfChange) {
handleConnectedState();
public void handleMessage(Message msg) {
switch (msg.what) {
case EVENT_SUPPLICANT_CONNECTION:
case EVENT_NETWORK_STATE_CHANGED:
handleConnectedState();//調用
private class DhcpHandler extends Handler {
private Handler mTarget;
public DhcpHandler(Looper looper, Handler target) {
super(looper);
mTarget = target;
int event;
//private static final int DRIVER_POWER_MODE_AUTO = 0;
//private static final int DRIVER_POWER_MODE_ACTIVE = 1;
switch (msg.what) {
case EVENT_DHCP_START:
synchronized (this) {
WifiNative.setPowerModeCommand(DRIVER_POWER_MODE_ACTIVE);//設置電源模式,調用android_net_wifi_setPowerModeCommand
Log.d(TAG, "DhcpHandler: DHCP request started");
//libs/android_runtime/android_net_NetUtils.cpp
//static JNINativeMethod gNetworkUtilMethods[] = {
//{ "runDhcp", "(Ljava/lang/String;Landroid/net/DhcpInfo;)Z", (void *)android_net_utils_runDhcp },
if (NetworkUtils.runDhcp(mInterfaceName, mDhcpInfo)) {//執行dhcp申請ip地址操作
event = EVENT_INTERFACE_CONFIGURATION_SUCCEEDED;
if (LOCAL_LOGD) Log.v(TAG, "DhcpHandler: DHCP request succeeded");
} else {
event = EVENT_INTERFACE_CONFIGURATION_FAILED;
Log.i(TAG, "DhcpHandler: DHCP request failed: " +
NetworkUtils.getDhcpError());
//如果dhcpcd分配ip失敗,那麽Message.obtain(mTarget, event).sendToTarget();將執行
//WifiNative.disconnectCommand();即:static JNINativeMethod gWifiMethods[] = {
//android_net_wifi_disconnectCommand發送"DISCONNECT"字符串[luther.gliethttp]
//然後在wpa_supplicant服務端執行wpa_supplicant_ctrl_iface_process
//wpa_supplicant_disassociate
WifiNative.setPowerModeCommand(DRIVER_POWER_MODE_AUTO);
break;
* Send the tracker a notification that a connection to the supplicant
* daemon has been established.
//在上面的public class WifiMonitor=>ensureSupplicantConnection
//while (!supplicantConnected) {
// boolean connected;
//synchronized (mWifiStateTracker) {
//connected = WifiNative.connectToSupplicant();//如果沒有連接成功,那麽while循環嘗試,直到嘗試成功,或者定義了oneShot,僅一次嘗試
//=>mWifiStateTracker.notifySupplicantConnection();//如果WifiNative.connectToSupplicant()成功,那麽將執行
//mWifiStateTracker.notifySupplicantConnection();的調用.
void notifySupplicantConnection() {//向對象發送message
Message.obtain(this, EVENT_SUPPLICANT_CONNECTION).sendToTarget();
void notifyStateChange(SupplicantState newState) {
Message.obtain(this, EVENT_SUPPLICANT_STATE_CHANGED, newState).sendToTarget();
static jboolean android_net_wifi_setPowerModeCommand(JNIEnv* env, jobject clazz, jint mode)
char cmdstr[256];
sprintf(cmdstr, "DRIVER POWERMODE %d", mode);
return doBooleanCommand(cmdstr, "OK");
=>doBooleanCommand
=>doCommand
=>wifi_command
=>wifi_send_command
=>wpa_ctrl_request
=>send給wpa_supplicant
然後wpa_supplicant將做如下接收操作:
system/extra/wpa_supplicant/main.c
=>wpa_supplicant_add_iface
=>wpa_supplicant_init_iface2
=>wpa_supplicant_ctrl_iface_init
=>注冊ctrl_conn控制端口和monitor_conn監聽端口的處理函數
eloop_register_read_sock(priv->sock, wpa_supplicant_ctrl_iface_receive, wpa_s, priv);//ctrl_conn端口的handler處理函數
wpa_msg_register_cb(wpa_supplicant_ctrl_iface_msg_cb);//monitor_conn端口的回調處理函數,處理netlink數據到所有monitor_conn監聽端口
=>wpa_supplicant_ctrl_iface_receive//對于unix通信方式
=>wpa_supplicant_ctrl_iface_process
=>如果wpa_cli發送的是wpa_cli driver xxx形式的命令,那麽調用這個函數
if (os_strncmp(buf, "DRIVER ", 7) == 0) {//掠過前7個,直接將命令傳過去
reply_len = wpa_supplicant_driver_cmd(wpa_s, buf + 7, reply, reply_size);
=>wpa_supplicant_driver_cmd
=>wpa_drv_driver_cmd
=>自定義DRIVER擴展處理函數,所以對于java傳遞過來的power電源管理命令,wpa_drv_driver_cmd將收到"POWERMODE 0"或者"POWERMODE 1"字符串[luther.gliethttp]
jni
=>runDhcp
=>android_net_utils_runDhcp
libs/netutils/dhcp_utils.c
=>dhcp_do_request
static const char DAEMON_NAME[] = "dhcpcd";
static const char DAEMON_PROP_NAME[] = "init.svc.dhcpcd";
static const char DHCP_PROP_NAME_PREFIX[] = "dhcp";
const char *ctrl_prop = "ctl.start";
const char *desired_status = "running";
snprintf(result_prop_name, sizeof(result_prop_name), "%s.%s.result",
DHCP_PROP_NAME_PREFIX,
interface);
property_set(result_prop_name, "");//設置dhcp.eth0.result="";等到成功完成dhcp之後,
property_set(ctrl_prop, DAEMON_NAME);//向名字爲dhcpcd的service,發送"ctrl.start"啓動命令字,該service在init.rc中
//init.rc中dhcpcd服務進程命令字
//service dhcpcd /system/bin/dhcpcd eth0
// disabled
// oneshot
wait_for_property(DAEMON_PROP_NAME, desired_status, 10);
//init.c=>init進程
//=>handle_property_set_fd因爲是"ctrl.start"命令字,所以調用handle_control_message處理控制信息
//=>handle_control_message
//=>msg_start
// struct service *svc = service_find_by_name(name);
// service_start(svc);//啓動svc,即執行:/system/bin/dhcpcd eth0
//=>service_start
//=>pid = fork();
// if(pid == 0)execve(svc->args[0], (char**) svc->args, (char**) ENV);子進程執行execve運行/system/bin/dhcpcd,參數爲eth0
//=>否則父進程,即init進程將
//=>notify_service_state(svc->name, "running");設置該svc的狀態prop
// snprintf(pname, sizeof(pname), "init.svc.%s", name);
// property_set(pname, state);//所以這樣上面wait_for_property(DAEMON_PROP_NAME, desired_status, 10);也才能夠正常pass[luther.gliethttp].
wait_for_property(result_prop_name, NULL, 15);//等待dhcp.eth0.result=非空
system/extra/dhcpcd-4.0.0-beta9/dhcpcd.c
dhcpcd
=>main
# define SYSCONFDIR "/system/etc/dhcpcd"
#define PACKAGE "dhcpcd"
# define CONFIG SYSCONFDIR "/" PACKAGE ".conf"
# define LIBEXECDIR "/system/etc/dhcpcd"
# define SCRIPT LIBEXECDIR "/" PACKAGE "-run-hooks"
=>strlcpy(options->script, SCRIPT, sizeof(options->script));//默認的options->script="/system/etc/dhcpcd/dhcpcd-run-hooks"
=>f = fopen(cf ? cf : CONFIG, "r");//如果沒有指定.conf文件,那麽使用默認.conf文件
=>parse_config_line//解析"/system/etc/dhcpcd/dhcpcd.conf"默認配置文件
=>parse_option
=>如果在"/system/etc/dhcpcd/dhcpcd.conf"有"script"這個節
=>那麽執行strlcpy(options->script, oarg, sizeof(options->script));直接拷貝
{"script", required_argument, NULL, 'c'},
{"option", required_argument, NULL, 'o'},
"/system/etc/dhcpcd/dhcpcd.conf"中的部分內容如下:
option domain_name_servers, domain_name, domain_search, host_name
=>dhcp_run
=>handle_dhcp_packet
=>handle_dhcp
=>bind_dhcp
reason = "TIMEOUT";reason = "BOUND";reason = "REBIND";reason = "RENEW";
system/extra/dhcpcd-4.0.0-beta9/configure.c
=> configure(iface, reason, state->new, state->old, &state->lease, options, 1);
//如果dhcp超時或者dhcp成功,都會調用exec_script來執行腳本,
//執行setprop dhcp.${interface}.result "failed"或者
//執行setpro
