7626|3
DE1-SOC的NFS启动怎么卡住了? [复制链接]
U-Boot 2013.01.01 (Oct 24 2013 - 17:40:22)
CPU   : Altera SOCFPGA Platform
BOARD : Altera SOCFPGA Cyclone V Board
DRAM:  1 GiB
MMC:   ALTERA DWMMC: 0
In:    serial
Out:   serial
Err:   serial
Net:   mii0
Warning: failed to set MAC address
Hit any key to stop autoboot:  0
Configuring PHY skew timing for Micrel ksz9021
Waiting for PHY auto negotiation to complete. done
ENET Speed is 100 Mbps - FULL duplex connection
Using mii0 device
TFTP from server 192.168.1.27; our IP address is 192.168.1.100
Filename 'zImage'.
Load address: 0x8000
Loading: #################################################################
         1.5 MiB/s
done
Bytes transferred = 3202816 (30df00 hex)
Using mii0 device
Filename 'socfpga.dtb'.
Load address: 0x100
Loading: ##
         1.4 MiB/s
done
Bytes transferred = 17965 (462d hex)
## Flattened Device Tree blob at 00000100
   Booting using the fdt blob at 0x00000100
   Loading Device Tree to 03ff8000, end 03fff62c ... OK
Starting kernel ...
Booting Linux on physical CPU 0x0
Initializing cgroup subsys cpuset
Linux version 3.9.0 (ubuntu12@ubuntu) (gcc version 4.7.3 20121106 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2012.11-20121123 - Linaro GCC 2012.11) ) #1 SMP Thu Apr 30 19:50:04 PDT 2015
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Altera SOCFPGA, model: Altera SOCFPGA Cyclone V
Memory policy: ECC disabled, Data cache writealloc
PERCPU: Embedded 8 pages/cpu @80eb0000 s11328 r8192 d13248 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260096
Kernel command line: console=ttyS0,115200 root=/dev/nfs nfsroot=192.168.1.27:/opt/altera-linux/rootfs-socfpga ip=192.168.1.100:192.168.1.27:192.168.1.1:255.255.255.0:socfpga:eth0:off
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
__ex_table already sorted, skipping sort
Memory: 1024MB = 1024MB total
Memory: 1032648k/1032648k available, 15928k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xc0800000 - 0xff000000   (1000 MB)
    lowmem  : 0x80000000 - 0xc0000000   (1024 MB)
    modules : 0x7f000000 - 0x80000000   (  16 MB)
      .text : 0x80008000 - 0x805ede10   (6040 kB)
      .init : 0x805ee000 - 0x8062ec40   ( 260 kB)
      .data : 0x80630000 - 0x8066a498   ( 234 kB)
       .bss : 0x8066a498 - 0x806a2c80   ( 226 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:16 nr_irqs:16 16
smp_twd: clock not found -2
sched_clock: 32 bits at 100MHz, resolution 10ns, wraps every 42949ms
Console: colour dummy device 80x30
Calibrating delay loop... 1594.16 BogoMIPS (lpj=7970816)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
ftrace: allocating 16244 entries in 48 pages
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Calibrating local timer... 199.93MHz.
Setting up static identity map for 0x8045a520 - 0x8045a578
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (3188.32 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
L310 cache controller enabled
l2x0: 8 ways, CACHE_ID 0x410030c9, AUX_CTRL 0x32460000, Cache size: 524288 B
syscon ffd08000.sysmgr: syscon regmap start 0xffd08000 end 0xffd0bfff registered
syscon ffd05000.rstmgr: syscon regmap start 0xffd05000 end 0xffd05fff registered
syscon ff800000.l3regs: syscon regmap start 0xff800000 end 0xff800fff registered
syscon ffc25000.sdrctl: syscon regmap start 0xffc25000 end 0xffc25fff registered
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
bio: create slab at 0
FPGA Mangager framework driver
fpga bridge driver
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
lcd_load_custom_fonts: i2c_master_send returns -121
lcd_cmd_no_params: i2c_master_send returns -121
lcd_cmd_one_param: i2c_master_send returns -121
lcd-comm 0-0028: LCD driver initialized
Switching to clocksource timer
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP: reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
arm-pmu arm-pmu: PMU:CTI successfully enabled
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
NTFS driver 2.1.30 [Flags: R/W].
jffs2: version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
msgmni has been set to 2016
io scheduler noop registered (default)
Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
ffc02000.serial: ttyS0 at MMIO 0xffc02000 (irq = 194) is a 16550A
console [ttyS0] enabled
altera_fpga_manager ff706000.fpgamgr: fpga manager [Altera FPGA Manager] registered as minor 0
brd: module loaded
at24 0-0051: 4096 byte 24c32 EEPROM, writable, 32 bytes/write
altera_hps2fpga_bridge fpgabridge.2: fpga bridge [hps2fpga] registered as device hps2fpga
altera_hps2fpga_bridge fpgabridge.3: fpga bridge [lshps2fpga] registered as device lwhps2fpga
altera_hps2fpga_bridge fpgabridge.4: fpga bridge [fpga2hps] registered as device fpga2hps
cadence-qspi ff705000.flash: master is unqueued, this is deprecated
m25p80 spi2.0: unrecognized JEDEC id ffffff
cadence-qspi ff705000.flash: Cadence QSPI controller driver
stmmac - user ID: 0x10, Synopsys ID: 0x37
DMA HW capability register supported
Enhanced/Alternate descriptors
RX Checksum Offload Engine supported (type 2)
TX Checksum insertion supported
Enable RX Mitigation via HW Watchdog Timer
libphy: stmmac: probed
eth0: PHY ID 00221611 at 1 IRQ 0 (stmmac-0:01) active
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
Using Slave mode
dwc_otg ffb40000.usb: DWC OTG Controller
dwc_otg ffb40000.usb: new USB bus registered, assigned bus number 1
dwc_otg ffb40000.usb: irq 160, io mem 0xffb40000
Init: Port Power? op_state=a_host
Init: Power Port (1)
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
Synopsys Designware Multimedia Card Interface Driver
dwmmc_socfpga ff704000.flash: couldn't determine pwr-en, assuming pwr-en = 0
dwmmc_socfpga ff704000.flash: Using internal DMA controller.
dwmmc_socfpga ff704000.flash: DW MMC controller at irq 171, 32 bit host data width, 1024 deep fifo
mmc_host mmc0: Bus speed (slot 0) = 12500000Hz (slot req 400000Hz, actual 390625HZ div = 16)
dwmmc_socfpga ff704000.flash: 1 slots initialized
dwmmc_socfpga ff704000.flash: Version ID is 240a
platform leds.1: Driver leds-gpio requests probe deferral
++OTG Interrupt: Debounce Done++
ledtrig-cpu: registered to indicate activity on CPUs
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
oprofile: using arm/armv7-ca9
TCP: cubic registered
NET: Registered protocol family 17
NET: Registered protocol family 15
Key type dns_resolver registered
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
ThumbEE CPU extension supported.
Registering SWP/SWPB emulation handler
eth0: device MAC address fa:8e:28:b5:65:35
dwmmc_socfpga ff704000.flash: data FIFO error (status=00000800)
mmc0: problem reading SD Status register.
mmc_host mmc0: Bus speed (slot 0) = 12500000Hz (slot req 12500000Hz, actual 12500000HZ div = 0)
mmc0: new high speed SDHC card at address 1234
IP-Config: Complete:
mmcblk0: mmc0:1234 SA04G 3.63 GiB
     device=eth0, hwaddr=fa:8e:28:b5:65:35, ipaddr=192.168.1.100, mask=255.255.255.0, gw=192.168.1.1
     host=socfpga, domain=, nis-domain=(none)
     bootserver=192.168.1.27, rootserver=192.168.1.27, rootpath= mmcblk0: p1 p2 p3
usb 1-1: new high-speed USB device number 2 using dwc_otg
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 2 ports detected
libphy: stmmac-0:01 - Link is Up - 100/Full
VFS: Mounted root (nfs filesystem) readonly on device 0:11.
devtmpfs: mounted
Freeing init memory: 256K
INIT: version 2.88 booting
Starting Bootlog daemon: bootlogd.
Configuring network interfaces... ifup skipped for nfsroot interface eth0
run-parts: /etc/network/if-pre-up.d/nfsroot exited with code 1
Starting portmap daemon...
Mon May  4 13:11:00 UTC 2015
INIT: Entering runlevel: 5
Starting OpenBSD Secure Shell server: sshd
NET: Registered protocol family 10
done.
Starting syslogd/klogd: done
Starting Lighttpd Web Server: lighttpd.
怎么一直停在这里呢?走不下去!
用的yocto的文件系统
此帖出自FPGA/CPLD论坛
yocto的文件系统怎么进不了终端命令行呢?  我使用的是fpga独立配置模式。 不需要HPS来配置
此帖出自FPGA/CPLD论坛
在 /etc/rc5.d/目录下,关闭了很多的 xxx.sh脚本 和 服务,终于出来了。
此帖出自FPGA/CPLD论坛
本来想自己做个文件系统的,但是下载的busybox用zynq的 arm-xilinx-linux-gnueabi- 编译就蛮好,而用 altera的 arm-linux-gnueabihf- 编译链接就出错了。烦躁。
此帖出自FPGA/CPLD论坛
