2584|5
22
F6638关于UART串口突然失效,连中断都进不了的问题 [复制链接]
之前还好好的可以用,我为了验证uart能不能用,直接把官网例程DEBUG,结果依然进不了中断。不知道是我CCS工程配置的问题,还是板子的问题,下面附上官网例程代码,大家帮忙看一看
你好  最后怎么解决的???  详情 回复 发表于 2016-9-1 23:52
22
/* --COPYRIGHT--,BSD_EX
* Copyright (c) 2012, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* *  Redistributions of source code must retain the above copyright
*    notice, this list of conditions and the following disclaimer.
* *  Redistributions in binary form must reproduce the above copyright
*    notice, this list of conditions and the following disclaimer in the
*    documentation and/or other materials provided with the distribution.
* *  Neither the name of Texas Instruments Incorporated nor the names of
*    its contributors may be used to endorse or promote products derived
*    from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
*                       MSP430 CODE EXAMPLE DISCLAIMER
* MSP430 code examples are self-contained low-level programs that typically
* demonstrate a single peripheral function or device feature in a highly
* concise manner. For this the code may rely on the device's power-on default
* register values and settings such as the clock configuration and care must
* be taken when combining code from several examples to avoid potential side
* effects. Also see www.ti.com/grace for a GUI- and www.ti.com/msp430ware
* for an API functional library-approach to peripheral configuration.
* --/COPYRIGHT--*/
//   MSP430F66x Demo - USCI_A0, Ultra-Low Pwr UART 9600 Echo ISR, 32kHz ACLK
//   Description: Echo a received character, RX ISR used. Normal mode is LPM3,
//   USCI_A0 RX interrupt triggers TX Echo.
//   ACLK = 32768Hz crystal, MCLK = SMCLK = DCO ~1.045MHz
//   Baud rate divider with 32768Hz XTAL @9600 = 32768Hz/9600 = 3.41
//   See User Guide for baud rate divider table
//   Note that UCA0RXD and UCA0TXD need to be assigned pins via the PMAP
//  controller.
//                MSP430F66x
//        /|\ |              XIN|-
//         |  |                 | 32kHz
//         ---|RST          XOUT|-
//            |     P2.0/UCA0TXD|------------>
//            |                 | 9600 - 8N1
//            |     P2.1/UCA0RXD|<------------
//   Priya Thanigai
//   Texas Instruments Inc.
//   Nov 2009
//   Built with IAR Embedded Workbench Version: 4.20 & Code Composer Studio V4.0
#include
void Port_Mapping(void);
int main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  while(BAKCTL & LOCKBAK)                    // Unlock XT1 pins for operation
     BAKCTL &= ~(LOCKBAK);
  UCSCTL6 &= ~(XT1OFF);                     // XT1 On
  UCSCTL6 |= XCAP_3;                        // Internal load cap
  // Loop until XT1 fault flag is cleared
  do
    UCSCTL7 &= ~(XT2OFFG + XT1LFOFFG + DCOFFG);
                                            // Clear XT2,XT1,DCO fault flags
    SFRIFG1 &= ~OFIFG;                      // Clear fault flags
  }while (SFRIFG1&OFIFG);                   // Test oscillator fault flag
  Port_Mapping();
  P2SEL |= 0x03;                            // Assign P2.0 to UCA0TXD and...
  P2DIR |= 0x03;                            // P2.1 to UCA0RXD
  UCA0CTL1 |= UCSWRST;                      // **Put state machine in reset**
  UCA0CTL1 |= UCSSEL_1;                     // CLK = ACLK
  UCA0BR0 = 0x03;                           // 32kHz/9600=3.41 (see User's Guide)
  UCA0BR1 = 0x00;                           //
  UCA0MCTL = UCBRS_3+UCBRF_0;               // Modulation UCBRSx=3, UCBRFx=0
  UCA0CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
  UCA0IE |= UCRXIE;                         // Enable USCI_A0 RX interrupt
  __bis_SR_register(LPM3_bits + GIE);       // Enter LPM3, interrupts enabled
  __no_operation();                         // For debugger
// Echo back RXed character, confirm TX buffer is ready first
#if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
#pragma vector=USCI_A0_VECTOR
__interrupt void USCI_A0_ISR(void)
#elif defined(__GNUC__)
void __attribute__ ((interrupt(USCI_A0_VECTOR))) USCI_A0_ISR (void)
#else
#error Compiler not supported!
#endif
  switch(__even_in_range(UCA0IV,4))
  case 0:break;                             // Vector 0 - no interrupt
  case 2:                                   // Vector 2 - RXIFG
    while (!(UCA0IFG&UCTXIFG));             // USCI_A0 TX buffer ready?
    UCA0TXBUF = UCA0RXBUF;                  // TX -> RXed character
    break;
  case 4:break;                             // Vector 4 - TXIFG
  default: break;
  // Disable Interrupts before altering Port Mapping registers
  __disable_interrupt();
  // Enable Write-access to modify port mapping registers
  PMAPPWD = 0x02D52;
  #ifdef PORT_MAP_RECFG
  // Allow reconfiguration during runtime
  PMAPCTL = PMAPRECFG;
  #endif
  P2MAP0 = PM_UCA0TXD;
  P2MAP1 = PM_UCA0RXD;
  // Disable Write-Access to modify port mapping registers
  PMAPPWD = 0;
  #ifdef PORT_MAP_EINT
  __enable_interrupt();                     // Re-enable all interrupts
  #endif
22
* are met:
* --/COPYRIGHT--*/
//  controller.
//                MSP430F66x
//        /|\ |              XIN|-
//         |  |                 | 32kHz
//         ---|RST          XOUT|-
//            |                 | 9600 - 8N1
//   Priya Thanigai
//   Nov 2009
#include
int main(void)
  do
  Port_Mapping();
  UCA0BR1 = 0x00;                           //
#else
#endif
    break;
  default: break;
  PMAPPWD = 0x02D52;
  #endif
  PMAPPWD = 0;
  #endif
22
又验证了,这个例程可以发数据,但是不能触发发送中断和接收中断,发送中断使能我验证的时候也使能了
22
不知道怎么回事,现在可以触发发送中断,接收中断还是不能触发
你好  最后怎么解决的???
