2346|1
求助ccsv4.2配置初始化链接的时候出错的问题 [复制链接]
各位大神好,我今年毕设题目和这个有关,需要用ezdsp5535在ccsv4.2环境下做。但是我按照说明书操作的时候出现了如图的问题。
我是做到第八步Target->Connect Target时候遇到这个问题的   我的ccs软件是导师给我的标准匹配板子的,所以不是板子的问题。求大神解答thank u!
1. Launch CCS v4 from the shortcut on the desktop. (This was created when CCS v4
    was installed).
2. The CCS v4 window will appear. Click the “Target” menu, then select “New Target
    Configuration File”.
3. The “New Target Configuration” window will appear. Enter a file name that describe
    the emulator connection and/or Texas Instruments device being used and click
    “Finish”. For example: “C5535_eZdsp”.
4. The “Basic” configuration setup window will open in the CCS v4. Select “Texas
    Instruments XDS100v2 USB Emulator” from the “Connection” menu. Type “5535” in
    the “Device” field and select “eZdsp5535”, from the list.
5. Click the “Save” button to save the configuration.
6. Click the “View” menu and select “Target Configurations” to expose the
    configuration(s) that have been built or imported. A new tab labeled “Target
    Configurations” will become available in the CCS window.
7. Expand the “User Defined” folder. Right-click on the new configuration that has been
    created and click “Launch Selected Configuration”.
8. Click “View->Debug” then click “Target->Connect Target”. CCS will attempt to connect
    to the C5535 eZdsp and run the GEL file. Once the connection is successful and the
    GEL file has finished, the console window will print a message stating
    “Target Connection Complete”.
驱动装了没有?选择仿真器种类正确不?  详情 回复 发表于 2015-4-26 10:11
28
裸片初长成(高级)
驱动装了没有?选择仿真器种类正确不?
