2973|1
6112
【Atmel SAM R21创意大赛周计划】+BitCloud无线数据发送和接收 [复制链接]
首先 我们看BitCloud里有个消息缓冲结构和数据发送相关结构:
/typedef struct
  /** The status of the data request. See \ref DataReqStatuses "details". */
  APS_Status_t status;
  /**  Timestamp for the transmitted packet based on the local clock,
   * as provided by the NWK layer. */
  uint32_t txTime;
} APS_DataConf_t;
* \struct APS_TxOptions_t apsdeData.h "aps.h"
* \brief Describes additional options for data transmission.
* The structure is used to set additional parameters for a data request such as
* \li to request for acknowledgement set acknowledgedTransmission to 1
* \li to enable fragmentation set fragmentationPermitted to 1
* \li to enable encryption of the application payload of a data frame set securityEnabledTransmission to 1
* \li to use network key to encrypt the application payload of a data frame set useNwkKey to 1
* \li to include extended nonce (combination of extended address and
* sequence number) to the auxiliary header set includeExtendedNonce to 1
* These fields conform to the primitive defined in ZigBee Specification r20, Table 2.2, page 25.
* Few extensions to the specification are defined:
* \li to disable decryption of sent data (clobbers data pointed by the asdu field) set doNotDecrypt to 1
* \li to enable indications from own broadcast transmissions set indicateBroadcasts to 1
* \li to disable discovery of a route path to the destination node in the case
*     when such path is unknown; in such case if the route is unknown an error is reported
BEGIN_PACK
typedef struct PACK
  uint8_t   securityEnabledTransmission :1;
  uint8_t   useNwkKey                   :1;
  uint8_t   acknowledgedTransmission    :1;
  uint8_t   fragmentationPermitted      :1;
  uint8_t   includeExtendedNonce        :1;
  uint8_t   doNotDecrypt                :1;
  uint8_t   indicateBroadcasts          :1;
  uint8_t   noRouteDiscovery            :1;
} APS_TxOptions_t;
END_PACK
* \struct APS_DataReq_t apsdeData.h "aps.h"
* \brief The structure for request parameters of APS_DataReq() function
* The structure represents parameters of data request, i.e. the request for sending data across the network. A pointer
* to an instance of the structure should to be passed as an argument to APS_DataReq() function.
* The structure definition follows APSDE-DATA request primitive described in
* Zigbee Specification r18, 2.2.4.1.1 APSDE-DATA.request, page 23.
//APS_DataReq_t结构的定义:
typedef struct
  /** \cond SERVICE_FIELDS **/
  struct
    void *next; /*!< Used for queue support */
#ifdef _ZAPPSI_
    /* to be compatible with MAC service. */
    uint8_t requestId;
    /* Sequence number to identify request-response pair. */
    uint8_t sequenceNumber;
    union
      /* Callback wrapper routine pointer */
      void (*callback)(void*);
      /* Processing routine pointer to call after required memory will become free */
      void (*process)(void*);
    } zsi;
#endif /* # _ZAPPSI_ */
    ZDO_ResolveAddrReq_t resolveAddrReq; /*!< Used for address resolving */
  } service;
  /** \endcond **/
  /**  The addressing mode for identifying the destination of a data request.
   * May take any non-reserved value from the following list:
   * \li APS_NO_ADDRESS (0x00) - used for binding; set dstAddress and dstEndpoint
   * \li APS_GROUP_ADDRESS (0x01) - used for group transmission; 16-bit group address should be specified in dstAddress; dstEndpoint is not set
   * \li APS_SHORT_ADDRESS (0x02) - identifying the destination (unicast or broadcast) with  a 16-bit short address specified
   * in dstAddress and the endpoint set in dstEndpoint
   * \li APS_EXT_ADDRESS (0x03) - identifying the destination with a 64-bit extended address specified in dstAddress and the endpoint set in dstEndpoint
   * \li 0x04..0xff - reserved values, must not be used by the application*/
  APS_AddrMode_t dstAddrMode;
   * \ref Endian "[LE]" The address of the individual device or group address
   * of the entity to which the ASDU is being transferred.
  APS_Address_t dstAddress;
  /** This parameter shall be present if and only if the DstAddrMode parameter
   * value is 0x02 or 0x03 and, if present, shall contain either the number of
   * individual endpoints of the entity to which the ASDU is being transferred,
   * or the broadcast endpoint (0xff). */
  Endpoint_t dstEndpoint;
  /** \ref Endian "[LE]" The identifier of the profile for which
   * this frame is intended. */
  ProfileId_t profileId;
  /** \ref Endian "[LE]" The identifier of the cluster for which
  ClusterId_t clusterId;
  /** The endpoint on the request originator node from
   * which the data frame is being transferred. */
  Endpoint_t srcEndpoint;
  /** The number of octets comprising the ASDU to be transferred.
   * The maximum length of an individual APS frame payload is given
   * as NsduLength-apscMinHeaderOverhead. Assuming the possibility
   * of fragmentation, a maximum-sized single ASDU consists of 256 such blocks.
  uint16_t asduLength;
  /** The set of octets comprising the ASDU to be transferred. */
  uint8_t *asdu;
  /** The transmission options for the ASDU to be transferred.
   * See structure definition for details.
  APS_TxOptions_t txOptions;
#if defined _GREENPOWER_SUPPORT_
  /*  Alias usage by  for the current frame */
  bool useAlias;
  /*  The source address to be used for this NSDU. If the UseAlias parameter
         has a value of FALSE,  the AliasSrcAddr parameter is ignored.*/
  ShortAddr_t aliasSrcAddr;
  /*  The sequence number to be used for this NSDU. If the UseAlias parameter
         has a value of FALSE, the AliasSeqNumb parameter is ignored.*/
  uint8_t aliasSeqNumber;
#endif /*_GREENPOWER_SUPPORT_*/
  /** The distance, in hops, that a transmitted frame will be allowed to
   * travel via the network*/
  uint8_t radius;
  /** A pointer to a callback function called upon request
   * completion. Must not be set to NULL. */
  void (*APS_DataConf)(APS_DataConf_t *conf);
  /** Confirm primitive passed to the callback and containing the results of request execution*/
  APS_DataConf_t confirm;
} APS_DataReq_t;
接下来看赋值:
AppMessageBuffer_t appMessageBuffer; //A variable for the message buffer
APS_DataReq_t dataReq; //A variable for the request parameters
//Specify the request parameters
dataReq.asdu = appMessageBuffer.data;
dataReq.asduLength = sizeof(appMessageBuffer.data);
//A confirmation callback for APS_DataReq()
static void APS_DataConf(APS_DataConf_t *confInfo) //回调函数
dataReq.profileId = APP_PROFILE_ID;//PROFILE ID
dataReq.dstAddrMode = APS_SHORT_ADDRESS;//目标短地址模式 单播 组播 广播的选择
dataReq.dstAddress.shortAddress = CPU_TO_LE16(0x0001);//目标地址
dataReq.dstEndpoint = DST_ENDPOINT_ID;//目标端点
dataReq.clusterId = CPU_TO_LE16(SAMPLE_CLUSTER_ID);//族ID列表
dataReq.srcEndpoint = SRC_ENDPOINT_ID;//源端点
dataReq.radius = 0x0;
//Specify a callback  //回调函数配置
dataReq.APS_DataConf = APS_DataConf;
//Configure the payload
dataReq.asdu = appMessageBuffer.data; //数据
dataReq.asduLength = sizeof(appMessageBuffer.data);//数据长度
最后调用:
//Issue the request
APS_DataReq(&dataReq);
调用上面的函数,这样数据就发到目的端点了。
接受函数将具有相同的端点,根据族ID列表和PROFILESID还有命令,属性等判断怎么处理数据。
端点
PROFILESID
族ID列表
要相同。
当然也必须是相同网络,也就是相同的PANID和CHANNEL
然后有个协调器有路由和终端设备。一起加入了一个网络之后才能执行发送。
以下是接收的情况,初始化的时候要登记一个端点的回调函数。在回调函数时处理数据APS_RegisterEndpointReq(&endpointDesc);函数就是登记的函数
//Global definitionsstatic ClusterId_t clustersTable[] = {0};
//The list of clusters that the endpoint will support
//Configure the simple descriptor of the endpointstatic
SimpleDescriptor_t simpleDescriptor =
    .endpoint = APP_ENDPOINT, //Endpoint ID, an arbitrary number between 1 and 240
    .AppDeviceVersion = 1,
    .AppInClustersCount = 1, //The number of suppoted input clusters
    .AppInClustersList = clustersTable,  //The list of supported input clusters
    .AppOutClustersCount = 0,
    .AppOutClustersList = NULL, //Suppose out clusters are not supported
//Configure parameters for endpoint registration requeststatic
APS_RegisterEndpointReq_t endpointDesc =
    .simpleDescriptor = &simpleDescriptor,
    .APS_DataInd = APS_DataInd,
//Data indication callback definitionstatic
void APS_DataInd(APS_DataInd_t *ind)
   //Perform appropriate actions, for example, switch on the value of
  //cluster specified in the received frame
  switch (ind->clusterId)
     case CPU_TO_LE16(APP_CLUSTER_ONE):    ...
     case CPU_TO_LE16(APP_CLUSTER_TWO):    ...
simpleDescriptor.AppProfileId = CPU_TO_LE16(APP_PROFILE_ID);
simpleDescriptor.AppDeviceId = CPU_TO_LE16(1);
到此 发送和接收的问题我们就有了一个了解。
看看 学习下 楼主加油   详情 回复 发表于 2015-4-2 09:45
赞赏
查看全部赞赏
565
513
裸片初长成(中级)
看看 学习下 楼主加油
赞赏
查看全部赞赏
