2626|1
急!TM4C129X Development Board , EEPROM用不了,下载不了程序 [复制链接]
我用的是TI 原装的Tiva™ TM4C129X Development Board, 芯片是tm4c129xnczad
想用ARM里的内置EEPROM存储一些东西,从板子带的例子uart echo改的。
发现调用
SysCtlPeripheralEnable(SYSCTL_PERIPH_EEPROM0);
ROM_EEPROMInit();
//ROM_EEPROMProgram(pui32Data, 0x100, sizeof(pui32Data));
//ROM_EEPROMRead(pui32Read, 0x100, sizeof(pui32Read));
根本无法操作EEPROM,而且程序反复出现下列情况:
(1)程序跑飞
(2)如果再重新下载程序,就出现,下载不了程序
具体程序如下
  1. #include <stdint.h>
  2. #include <stdbool.h>
  3. #include "inc/hw_ints.h"
  4. #include "inc/hw_gpio.h"
  5. #include "inc/hw_memmap.h"
  6. #include "inc/hw_types.h"
  7. #include "driverlib/debug.h"
  8. #include "driverlib/gpio.h"
  9. #include "driverlib/interrupt.h"
  10. #include "driverlib/sysctl.h"
  11. #include "driverlib/uart.h"
  12. #include "driverlib/rom.h"
  13. #include "grlib/grlib.h"
  14. #include "drivers/kentec320x240x16_ssd2119.h"
  15. #include "drivers/frame.h"
  16. #include "drivers/pinout.h"
  17. #include "driverlib/eeprom.h"
  18. #include "driverlib/rom.h"
  19. #include "driverlib/pin_map.h"
  20. #ifdef DEBUG
  21. void
  22. __error__(char *pcFilename, uint32_t ui32Line)
  23. {
  24. }
  25. #endif
  26. //*****************************************************************************
  27. //
  28. // The UART interrupt handler.
  29. //
  30. //*****************************************************************************
  31. void
  32. UARTIntHandler(void)
  33. {
  34.     uint32_t ui32Status;
  35.     //
  36.     // Get the interrrupt status.
  37.     //
  38.     ui32Status = ROM_UARTIntStatus(UART0_BASE, true);
  39.     //
  40.     // Clear the asserted interrupts.
  41.     //
  42.     ROM_UARTIntClear(UART0_BASE, ui32Status);
  43.     //
  44.     // Loop while there are characters in the receive FIFO.
  45.     //
  46.     while(ROM_UARTCharsAvail(UART0_BASE))
  47.     {
  48.         //
  49.         // Read the next character from the UART and write it back to the UART.
  50.         //
  51.     unsigned char temp = UARTCharGetNonBlocking(UART0_BASE);
  52.         ROM_UARTCharPutNonBlocking(UART0_BASE,temp);
  53.     }
  54. }
  55. //*****************************************************************************
  56. //
  57. // Send a string to the UART.
  58. //
  59. //*****************************************************************************
  60. void
  61. UARTSend(const uint8_t *pui8Buffer, uint32_t ui32Count)
  62. {
  63.     //
  64.     // Loop while there are more characters to send.
  65.     //
  66.     while(ui32Count--)
  67.     {
  68.         //
  69.         // Write the next character to the UART.
  70.         //
  71.         ROM_UARTCharPutNonBlocking(UART0_BASE, *pui8Buffer++);
  72.     }
  73. }
  74. //*****************************************************************************
  75. //
  76. // This example demonstrates how to send a string of data to the UART.
  77. //
  78. //*****************************************************************************
  79. int
  80. main(void)
  81. {
  82.     uint32_t ui32SysClock;
  83.     tContext sContext;
  84.     ui32SysClock = SysCtlClockFreqSet((SYSCTL_XTAL_25MHZ |
  85.                                       SYSCTL_OSC_MAIN |
  86.                                       SYSCTL_USE_PLL |
  87.                                       SYSCTL_CFG_VCO_480), 120000000);
  88.     {
  89.         ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
  90.         ROM_GPIOPinConfigure(GPIO_PA0_U0RX);
  91.         ROM_GPIOPinConfigure(GPIO_PA1_U0TX);
  92.         ROM_GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1);
  93.     }
  94.     SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0);
  95.     SysCtlPeripheralEnable(SYSCTL_PERIPH_EEPROM0);
  96.     //
  97.     // Enable processor interrupts.
  98.     //
  99.     IntMasterEnable();
  100.     //
  101.     // Configure the UART for 115,200, 8-N-1 operation.
  102.     //
  103.     ROM_UARTConfigSetExpClk(UART0_BASE, ui32SysClock, 115200,
  104.                             (UART_CONFIG_WLEN_8 | UART_CONFIG_STOP_ONE |
  105.                              UART_CONFIG_PAR_NONE));
  106.     ROM_IntEnable(INT_UART0);
  107.     //ROM_EEPROMInit();
  108.     ROM_UARTIntEnable(UART0_BASE, UART_INT_RX | UART_INT_RT);
  109.     //
  110.     // Prompt for text to be entered.
  111.     //
  112.     UARTSend((uint8_t *)"0nter text: ", 12);
  113.      while(1)
  114.     {
  115.     }
  116. }
复制代码
试试看原厂自带的 EEPROM 例程行不行,检查一下是板子的问题还是程序的问题。不应该下不了程序的,用新版的 MDK 试试。  详情 回复 发表于 2015-3-30 20:25
1803
