3481|1
Mbed支持IBM的IOT开发板了 [复制链接]
http://developer.mbed.org/platforms/IBMEthernetKit/
下面是Mbed网站上的说明:
Ethernet IoT Starter Kit
This starter Kit for IBM IoT Foundation provides the user with a slick experience, getting data from the on board sensors into the IBM cloud within minutes of opening the box. It is particularly suitable for developers with no specific experience in embedded or web development, as it provides a platform for learning new concepts and creating working prototypes.After the initial out of box experience, the infinite possibilities of cloud applications can be explored through IBM's production grade BlueMix platform, in which deployment and device management is as simple for one device as it is for one million. The starter kit hardware can be modified and extended to explore the device design space, and a finalised design can be taken to production using the mbed SDK and HDK.
Kit Contents
  • mbed Enabled Freescale K64F
    • Freescale K64F Kinetis K64 MCU (MK64FN1M0VLL12)
    • High performance ARM® Cortex™-M4 Core with Floating point unit and DSP
    • 120MHz, 256KB RAM, 1MB FLASH
  • mbed Application shield
    • 128x32 Graphics LCD
    • 5 way joystick
    • 2 x Potentiometers
    • Speaker, PWM Conencted
    • 3 Axis +/1 1.5g Accelerometer
    • RGB LED, PWM connected
    • Temperature sensor
Getting started
What should happen
Within a few seconds the light on your starter kit should have lit up green, and the status on the LCD screen should be "connected"
You should see a drive appear on your computer, which contains a file called "IBM.htm" - double click this to open it in a browser. You should now be seeing the data being sent from your starter kit.
此帖出自单片机论坛
这段时间Mbed更新很快啊,支持的开发板也越来越多。
此帖出自单片机论坛
