index = 0; // Reset the index; Set Breakpoint here
//Strobe( RF_SFTX );//FLUSH THE TX FIFO
_NOP();
Transmit( (unsigned char*)results,sizeof results);
TX++;
void delayms(unsigned int n)
unsigned int i,j;
for(i=0;i
for(j=0;j<800;j++);
void InitRadio(void)
// Set the High-Power Mode Request Enable bit so LPM3 can be entered
// with active radio enabled
PMMCTL0_H = 0xA5;
PMMCTL0_L |= PMMHPMRE_L;
PMMCTL0_H = 0x00;
// It is possible that ReceiveOff is called while radio is receiving a packet.
// Therefore, it is necessary to flush the RX FIFO after issuing IDLE strobe
// such that the RXFIFO is empty prior to receiving a packet.
Strobe( RF_SIDLE );
Strobe( RF_SFRX );
#pragma vector=CC1101_VECTOR
__interrupt void CC1101_ISR(void)
switch(__even_in_range(RF1AIV,32)) // Prioritizing Radio Core Interrupt
case 0: break; // No RF core interrupt pending
case 2: break; // RFIFG0
case 4: break; // RFIFG1
case 6: break; // RFIFG2
case 8: break; // RFIFG3
case 10: break; // RFIFG4
case 12: break; // RFIFG5
case 14: break; // RFIFG6
case 16: break; // RFIFG7
case 18: break; // RFIFG8
case 20: // RFIFG9
if(transmitting) // TX end of packet
//RF1AIE &= ~BIT9; // Disable TX end-of-packet interrupt
TXX++;
else while(1); // trap
break;
case 22: break; // RFIFG10
case 24: break; // RFIFG11
case 26: break; // RFIFG12
case 28: break; // RFIFG13
case 30: break; // RFIFG14
case 32: break; // RFIFG15
//__bic_SR_register_on_exit(LPM3_bits);
#include "../inc/RF_Toggle_LED_Demo.h"
_NOP();
TX++;
unsigned int i,j;
for(i=0;i
for(j=0;j<800;j++);
PMMCTL0_H = 0xA5;
PMMCTL0_H = 0x00;
Strobe( RF_SIDLE );
Strobe( RF_SFRX );
case 20: // RFIFG9
TXX++;
break;
