5754|9
429
84
ATMEL发布全新Cortex M7开发板 [复制链接]
SAM V71 Xplained Ultra Evaluation Kit
The Atmel® | SMART™ SAM V71 Xplained Ultra evaluation kit is ideal for evaluating and prototyping with the Atmel SAM V71, SAM V70, SAM S70 and SAM E70 ARM® Cortex®-M7 based microcontrollers.
Extension boards to the SAM V71 Xplained Ultra can be purchased individually.
Key Features
  • ATSAMV71Q21 microcontroller
  • One mechanical reset button
  • One power switch button
  • Two mechanical user pushbuttons
  • Two yellow user LEDs
  • Supercap backup
  • 12.0 MHz crystal
  • 32.768 kHz crystal
  • 2 MB SDRAM
  • 2 MB QSPI Flash
  • IEEE 802.3az 10Base-T/100Base-TX Ethernet RMII PHY
  • AT24MAC402 256KByte EEPROM with EUI-48 address
  • Stereo audio codec
    • External PLL for precise clock generation
    • Microphone jack
    • Headphone jack
  • ATA6561 CAN Transceiver
  • SD Card connector with SDIO support
  • Camera interface connector
  • MediaLB connector
  • Two Xplained Pro extension headers One Xplained Pro LCD header
  • Coresight 20 connector for 4-bit ETM
  • Arduino due compatible shield connectors
  • External debugger connector
  • USB interface, device and host mode
  • Embedded Debugger
    • Auto-ID for board identification in Atmel Studio
    • One yellow status LED
    • One green board power LED
    • Symbolic debug of complex data types including scope information
    • Programming and debugging
    • Data Gateway Interface: SPI, I2C, 4 GPIOs
    • Virtual COM port (CDC)
  • External power input (5-14V)
  • USB powered
  • Supported with application examples in Atmel Software Framework
http://www.atmel.com/zh/cn/tools/atsamv71-xult.aspx?tab=overview
Atmel-42408-SAMV71-Xplained-Ultra_User-Guide.pdf (2.36 MB, 下载次数: 93)
ATMEL就是牛Cortex M7这么快就出开发板了。  详情 回复 发表于 2015-6-2 10:49
2144
真不错,都出来了
哎 太快了,这世界,,,。。
个人签名电工
2144
来团购或者活动吧SAM V71
优势说明
  • 基于 ARM Cortex-M7 的 MCU 能够以高达 300MHz 的频率运行,并提供 16KB 的指令和 16KB 的数据缓存
  • 高达 2MB 的嵌入式闪存和 384KB 的多端口 SRAM
  • 高达 128KB 的指令紧密耦合存储器 (TCM) 和 128KB 的数据 TCM
  • 具有就地执行功能的 Quad SPI
  • 集成了 PHY 的 USB 高速控制器
  • 具有硬件流量整形功能的以太网 AVB
  • MediaLB 3 线接口
  • CAN-FD 控制器
  • 用于 TDM/I2S 连接的 SSC 模块
  • 高速多媒体卡接口
  • CMOS 相机接口
  • 真正的随机号码生成器 SHA-256 和 AES-256 加密引擎
  • 12 位 ADC 和 DAC
  • 使用 1KB SRAM 的低功耗备份,可在 CAN < 85uA @ 85C 时唤醒
  • QFP、BGA 和 QFN 可湿润侧面封装选项(SAM V71J:64 管脚;SAM V71N:100 管脚;SAM V71Q:144 管脚)
Atmel | SMART SAM V71 器件是一系列基于带浮点运算单元 (FPU) 的高性能 32 位 ARM Cortex-M7 处理器的汽车闪存微控制器的组成部分。这些器件能够以高达 300MHz 的频率运行,配备高达 2048KB 的闪存、高达 384KB 的多端口 SRAM 以及可配置的指令和数据紧密耦合存储器,可充分利用内核的高级 DSP 功能。
SAM V71 采用了独特的多端口存储器架构和高级 Cortex-M7 DSP 功能,专为组合使用以太网 A
个人签名电工
2144
CAN-FD又多新成员
个人签名电工
1291
高大上的板子
5979
东西越来越牛逼了!让我等情以何堪
个人签名生活就是油盐酱醋再加一点糖,快活就是一天到晚乐呵呵的忙
做一个简单的人,踏实而务实,不沉溺幻想,不庸人自扰
429
84
现在ST、Atmel、FSL都有CM7的芯片了
1042
强啊,都出M7的开发板了
79
好叼 膜拜一下
138
