3124|3
2700
xilinx一个最简单的闪亮led,求大神指点错误 [复制链接]
让led闪烁
module led(sys_clk,
                                sys_rstn,
                                led
input sys_clk;
input sys_rstn;
output [2:0] led;
reg         [2:0]        led;
reg        [24:0] delay_cnt;
always@(posedge sys_clk or negedge sys_rstn)
        begin
                if(!sys_rstn)
                        delay_cnt <= 25'd0;
                else
                        begin
                                if(delay_cnt == 25'd24999999)
                                        delay_cnt <= 25'd0;
                                else
                                        delay_cnt<=delay_cnt+1'b1;
                        end
        end
        begin
                if(!sys_rstn)
                        led<=3'b111;
                else
                        begin
                                if(delay_cnt==25'd24999999)
                                        led<=~led;
                                else
                                        led<=led;
                        end
        end
endmodule
添加测试模块
添加测试模块
但是clk依然没有跳变
但是clk依然没有跳变
此帖出自FPGA/CPLD论坛
`timescale 1ns / 1ps ////////////////////////////////////////////////////////////////////////////////// // Company: // Engineer: Liqingtao // // Create Date:    10:07:29 11/22/2016 // Design Name: // Module Name:    led // Project Name: // Target Devices: // Tool versions: // Description: // // Dependencies: // // Revision: // Revision 0.01 - File Created // Additional Comments: // ////////////////////////////////////////////////////////////////////////////////// module led(            div_clk,            rst_n,            cn            );                               //input signal;   input       div_clk;   input       rst_n;   //output signal;   output[5:0] cn;   reg [5:0]  cn;      reg  [2:0]  counter;   always@(posedge div_clk or negedge rst_n)     begin     if(!rst_n)       begin        counter   详情 回复 发表于 2017-2-28 13:05
2700
尼玛不容易啊
此帖出自FPGA/CPLD论坛
21
// Company:
// Engineer:Liqingtao
// Create Date:    09:51:48 11/22/2016
// Design Name:
// Module Name:    div
// Project Name:
// Target Devices:
// Tool versions:
// Description:
// Dependencies:
// Revision:
module div(
           clk,
           rst_n,
           div_clk
  //input signal;
  input    clk;
  input    rst_n;
//output signal;
  output   div_clk;
  reg [31:0] counter;
  reg        div_clk;
  always@(posedge clk or negedge rst_n)
    begin
      if(!rst_n)
        begin
          counter <= 32'd0;
          div_clk <= 1'b0;
       end
     else begin
        if(counter==32'h17d7840)
         begin
                counter <=32'h0;
                div_clk <=~div_clk;
              end
        else
               counter <= counter+1'b1;
     end
   end
endmodule
PS:分频模块;跨时钟信号自己利用计数器进行分频容易出现亚稳态,建议使用PLL进行分/倍频;
此帖出自FPGA/CPLD论坛
21
// Company:
// Design Name:
// Module Name:    led
// Project Name:
// Target Devices:
// Tool versions:
// Description:
// Dependencies:
// Revision:
module led(
           div_clk,
           rst_n,
           cn
  //input signal;
  input       div_clk;
  input       rst_n;
  //output signal;
  output[5:0] cn;
  reg [5:0]  cn;
  reg  [2:0]  counter;
    begin
    if(!rst_n)
      begin
       counter <= 3'd0;
      end
      else begin
         if(counter==3'b110)
           begin
             counter <=3'd0;
           end
         else
         counter <=counter+1'b1;
       end
     end
     begin
       if(!rst_n)
         begin
           cn  <= 6'd0;
         end
        else begin
      case(counter)
           6'b000000:
                   cn<= 6'b000000;
           6'b000001:
                   cn<= 6'b000001;
           6'b000010:
                   cn<= 6'b000011;
           6'b000011:
                   cn<= 6'b000111;
           6'b000100:
                   cn<= 6'b001111;
           6'b000101:
                   cn<= 6'b011111;
           6'b000110:
                   cn<= 6'b111111;
           default:
                   cn<= 6'b0;
          endcase
        end
      end
  //assign cn = counter;
endmodule
PS:这是LED灯闪烁的代码,这是我以前写的,现在想想还有一个更优的想法:利用移位操作符,代码更短;
led<=6'1111110;
led<={led[4:0],led[5]};
一点点小的想法,嘿嘿~~~
此帖出自FPGA/CPLD论坛
【有奖直播】2025是德科技数字月-数字新品来助阵
直播时间:3月19日(周三)14:00
直播奖励:小米口红充电宝、倍思充电线、是德科技十周年鼠标垫
