2973|7
484
学习M3/M4编程与调试并不一定需要板卡 [复制链接]
我觉得采用proteus学习ARM Cortex编程与调试也很方便,朝下面看M3闪烁灯程序的调试!
仿真跟实践终究有差别!!!没条件只能仿真那就仿真,,有条件最好上板子  详情 回复 发表于 2015-1-23 19:41
484
可视化单步
太方便了,甚至超过了在真实实验板上的单步调试  详情 回复 发表于 2015-1-23 12:47
484
结论:学习ARM Cortex编程,买本书就行了,甚至书都不用买,看看TI的文档就行!  详情 回复 发表于 2015-1-23 12:49
484
#include "inc/lm3s301.h"
//! \addtogroup example_list
Blinky (blinky)
//! A very simple example that blinks the on-board LED.
// Blink the on-board LED.
int
main(void)
    volatile unsigned long ulLoop;
    // Enable the GPIO port that is used for the on-board LED.
    SYSCTL_RCGC2_R = SYSCTL_RCGC2_GPIOB;
    // Do a dummy read to insert a few cycles after enabling the peripheral.
    ulLoop = SYSCTL_RCGC2_R;
    // Enable the GPIO pin for the LED (PB0).  Set the direction as output, and
    // enable the GPIO pin for digital function.  Care is taken to not disrupt
    // the operation of the PB7/TRST pin.
    GPIO_PORTB_DIR_R |= 0x01;
    GPIO_PORTB_DEN_R |= 0x01;
    // Loop forever.
    while(1)
        // Turn on the LED.
        GPIO_PORTB_DATA_R |= 0x01;
        // Delay for a bit.
        for(ulLoop = 0; ulLoop < 200000; ulLoop++)
        // Turn off the LED.
        GPIO_PORTB_DATA_R &= ~(0x01);
        // Delay for a bit.
你说的太绝了,我竟然无言以对  详情 回复 发表于 2015-1-23 14:09
3416
不支持M4吧
仿真这玩意儿......
还是有个板子比较靠谱
So TM what......?
484
呵呵,M3与M4的编程有区别?呵呵,学习编程还是proteus方便。
269
//! Blinky (blinky)
int
main(void)
    // Loop forever.
    while(1)
        // Turn on the LED.
        // Delay for a bit.
        // Delay for a bit.
你说的太绝了,我竟然无言以对
164
