// Initialize all the handles needed for this application
myAdc = ADC_init((void *)ADC_BASE_ADDR, sizeof(ADC_Obj));
myClk = CLK_init((void *)CLK_BASE_ADDR, sizeof(CLK_Obj));
myCpu = CPU_init((void *)NULL, sizeof(CPU_Obj));
myFlash = FLASH_init((void *)FLASH_BASE_ADDR, sizeof(FLASH_Obj));
myGpio = GPIO_init((void *)GPIO_BASE_ADDR, sizeof(GPIO_Obj));
myPie = PIE_init((void *)PIE_BASE_ADDR, sizeof(PIE_Obj));
myPll = PLL_init((void *)PLL_BASE_ADDR, sizeof(PLL_Obj));
myPwm = PWM_init((void *)PWM_ePWM1_BASE_ADDR, sizeof(PWM_Obj));
myWDog = WDOG_init((void *)WDOG_BASE_ADDR, sizeof(WDOG_Obj));
mySpi = SPI_init((void *)SPIA_BASE_ADDR, sizeof(SPI_Obj));
// Step 1. Initialize System Control:
// PLL, WatchDog, enable Peripheral Clocks
// This example function is found in the F2802x_SysCtrl.c file.
// InitSysCtrl();
// Perform basic system initialization
WDOG_disable(myWDog);
CLK_enableAdcClock(myClk);
(*Device_cal)();
//Select the internal oscillator 1 as the clock source
CLK_setOscSrc(myClk, CLK_OscSrc_Internal);
// Setup the PLL for x10 /2 which will yield 50Mhz = 10Mhz * 10 / 2
PLL_setup(myPll, PLL_Multiplier_10, PLL_DivideSelect_ClkIn_by_2);
// Disable the PIE and all interrupts
PIE_disable(myPie);
PIE_disableAllInts(myPie);
CPU_disableGlobalInts(myCpu);
CPU_clearIntFlags(myCpu);
// If running from flash copy RAM only functions to RAM
#ifdef _FLASH
memcpy(&RamfuncsRunStart, &RamfuncsLoadStart, (size_t)&RamfuncsLoadSize);
#endif
// Initialize the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
// This will populate the entire table, even if the interrupt
// is not used in this example. This is useful for debug purposes.
// The shell ISR routines are found in F2802x_DefaultIsr.c.
// This function is found in F2802x_PieVect.c.
// InitPieVectTable();
PIE_setDebugIntVectorTable(myPie);
PIE_enable(myPie);
// Interrupts that are used in this example are re-mapped to
// ISR functions found within this file.
PIE_registerPieIntHandler(myPie, PIE_GroupNumber_10, PIE_SubGroupNumber_1, (intVec_t)&adc_isr);
// Step 4. Initialize the ADC:
// This function is found in F2802x_Adc.c
// InitAdc(); // For this example, init the ADC
ADC_enableBandGap(myAdc);
ADC_enableRefBuffers(myAdc);
ADC_powerUp(myAdc);
ADC_enable(myAdc);
ADC_setVoltRefSrc(myAdc, ADC_VoltageRefSrc_Int);
// Step 7. User specific code, enable interrupts:
// Enable ADCINT1 in PIE
// PieCtrlRegs.PIEIER1.bit.INTx1 = 1; // Enable INT 1.1 in the PIE
PIE_enableAdcInt(myPie, ADC_IntNumber_1);
// IER |= M_INT1; // Enable CPU Interrupt 1
CPU_enableInt(myCpu, CPU_IntNumber_10);
// EINT; // Enable Global interrupt INTM
CPU_enableGlobalInts(myCpu);
// ERTM; // Enable Global realtime interrupt DBGM
CPU_enableDebugInt(myCpu);
// Step 5. Configure ADC to sample the temperature sensor on ADCIN5:
// The output of Piccolo temperature sensor can be internally connected to the ADC through ADCINA5
// via the TEMPCONV bit in the ADCCTL1 register. When this bit is set, any voltage applied to the external
// ADCIN5 pin is ignored.
// EALLOW;
// AdcRegs.ADCCTL1.bit.TEMPCONV = 1; //Connect internal temp sensor to channel ADCINA5.
ADC_enableTempSensor(myAdc);
// EDIS;
// Step 6. Continue configuring ADC to sample the temperature sensor on ADCIN5:
// Since the temperature sensor is connected to ADCIN5, configure the ADC to sample channel ADCIN5
// as well as the ADC SOC trigger and ADCINTs preferred. This example uses EPWM1A to trigger the ADC
// to start a conversion and trips ADCINT1 at the end of the conversion.
//Note: The temperature sensor will be double sampled to apply the workaround for rev0 silicon errata for the ADC 1st sample issue
// EALLOW;
// AdcRegs.ADCCTL1.bit.INTPULSEPOS = 1; //ADCINT1 trips after AdcResults latch
ADC_setIntPulseGenMode(myAdc, ADC_IntPulseGenMode_Prior);
// AdcRegs.INTSEL1N2.bit.INT1E = 1; //Enabled ADCINT1
ADC_enableInt(myAdc, ADC_IntNumber_1);
// AdcRegs.INTSEL1N2.bit.INT1CONT = 0; //Disable ADCINT1 Continuous mode
ADC_setIntMode(myAdc, ADC_IntNumber_1, ADC_IntMode_ClearFlag);
// AdcRegs.INTSEL1N2.bit.INT1SEL = 1; //setup EOC1 to trigger ADCINT1 to fire
ADC_setIntSrc(myAdc, ADC_IntNumber_1, ADC_IntSrc_EOC1);
// AdcRegs.ADCSOC0CTL.bit.CHSEL = 5; //set SOC0 channel select to ADCINA5 (which is internally connected to the temperature sensor)
ADC_setSocChanNumber (myAdc, ADC_SocNumber_0, ADC_SocChanNumber_A5);
// AdcRegs.ADCSOC1CTL.bit.CHSEL = 5; //set SOC1 channel select to ADCINA5 (which is internally connected to the temperature sensor) errata workaround
ADC_setSocChanNumber (myAdc, ADC_SocNumber_1, ADC_SocChanNumber_A5);
// AdcRegs.ADCSOC0CTL.bit.TRIGSEL = 5; //set SOC0 start trigger on EPWM1A
ADC_setSocTrigSrc(myAdc, ADC_SocNumber_0, ADC_SocTrigSrc_EPWM1_ADCSOCA);
// AdcRegs.ADCSOC1CTL.bit.TRIGSEL = 5; //set SOC1 start trigger on EPWM1A errata workaround
ADC_setSocTrigSrc(myAdc, ADC_SocNumber_1, ADC_SocTrigSrc_EPWM1_ADCSOCA);
// AdcRegs.ADCSOC0CTL.bit.ACQPS = 6; //set SOC0 S/H Window to 7 ADC Clock Cycles, (6 ACQPS plus 1)
ADC_setSocSampleWindow(myAdc, ADC_SocNumber_0, ADC_SocSampleWindow_7_cycles);
// AdcRegs.ADCSOC1CTL.bit.ACQPS = 6; //set SOC1 S/H Window to 7 ADC Clock Cycles, (6 ACQPS plus 1) errata workaround
ADC_setSocSampleWindow(myAdc, ADC_SocNumber_1, ADC_SocSampleWindow_7_cycles);
// EDIS;
CLK_enablePwmClock(myClk, PWM_Number_1);
// Assumes ePWM1 clock is already enabled in InitSysCtrl();
// EPwm1Regs.ETSEL.bit.SOCAEN = 1; // Enable SOC on A group
PWM_enableSocAPulse(myPwm);
// EPwm1Regs.ETSEL.bit.SOCASEL = 4; // Select SOC from from CPMA on upcount
PWM_setSocAPulseSrc(myPwm, PWM_SocPulseSrc_CounterEqualCmpAIncr);
// EPwm1Regs.ETPS.bit.SOCAPRD = 1; // Generate pulse on 1st event
PWM_setSocAPeriod(myPwm, PWM_SocPeriod_FirstEvent);
// EPwm1Regs.CMPA = 0x0080; // Set compare A value
PWM_setCmpA(myPwm, 0x0080);
// EPwm1Regs.TBPRD = 0xFFFF; // Set period for ePWM1
PWM_setPeriod(myPwm, 0xFFFF);
// EPwm1Regs.TBCTL.bit.CTRMODE = 0; // count up and start
PWM_setCounterMode(myPwm, PWM_CounterMode_Up);
CLK_enableTbClockSync(myClk);
//初始化SPI通讯的GPIO口
GPIO_setPullUp(myGpio, GPIO_Number_16, GPIO_PullUp_Enable);
GPIO_setPullUp(myGpio, GPIO_Number_17, GPIO_PullUp_Enable);
GPIO_setPullUp(myGpio, GPIO_Number_18, GPIO_PullUp_Enable);
GPIO_setPullUp(myGpio, GPIO_Number_19, GPIO_PullUp_Enable);
GPIO_setQualification(myGpio, GPIO_Number_16, GPIO_Qual_ASync);
GPIO_setQualification(myGpio, GPIO_Number_17, GPIO_Qual_ASync);
GPIO_setQualification(myGpio, GPIO_Number_18, GPIO_Qual_ASync);
GPIO_setQualification(myGpio, GPIO_Number_19, GPIO_Qual_ASync);
GPIO_setMode(myGpio, GPIO_Number_16, GPIO_16_Mode_SPISIMOA);
GPIO_setMode(myGpio, GPIO_Number_17, GPIO_17_Mode_SPISOMIA);
GPIO_setMode(myGpio, GPIO_Number_18, GPIO_18_Mode_SPICLKA);
GPIO_setMode(myGpio, GPIO_Number_19, GPIO_19_Mode_SPISTEA_NOT);
spi_init(); // Initialize SPI
spi_fifo_init(); // Initialize the SPI FIFOs
// Wait for ADC interrupt
for(;;)
interrupt void adc_isr(void)
// TempSensorVoltage[ConversionCount] = AdcResult.ADCRESULT1; //discard ADCRESULT0 as part of the workaround to the 1st sample errata for rev0
TempSensorVoltage+= ADC_readResult(myAdc, ADC_ResultNumber_1);
// If 64 conversions have been logged, start over
if(ConversionCount == 63)
TV=TempSensorVoltage>> 6;//64次采样后取平均值
TempSensorVoltage=0;
ConversionCount=0;
degC = ADC_getTemperatureC(myAdc, TV);
// degK = ADC_getTemperatureK(myAdc, TV);
sdata0 = Led_lib[degC/10]*256 + Led_lib[degC%10];//具体温度值
sdata1 = Led_lib[20]*256 + Led_lib[21];//℃显示
SPI_write(mySpi, sdata0); // Send data
SPI_write(mySpi, sdata1); // Send data
//数据传输结束GPIO19产生一个上升沿使移位寄存器输出显示数据
GpioDataRegs.GPACLEAR.bit.GPIO19 = 1;
GpioDataRegs.GPASET.bit.GPIO19 = 1;
else ConversionCount++;
// AdcRegs.ADCINTFLGCLR.bit.ADCINT1 = 1; //Clear ADCINT1 flag reinitialize for next SOC
ADC_clearIntFlag(myAdc, ADC_IntNumber_1);
// PieCtrlRegs.PIEACK.all = PIEACK_GROUP1; // Acknowledge interrupt to PIE
PIE_clearInt(myPie, PIE_GroupNumber_10);
// This example function is found in the DSP2802x_SysCtrl.c file.
// InitSysCtrl();
// Step 2. Initalize GPIO:
// This example function is found in the DSP2802x_Gpio.c file and
// illustrates how to set the GPIO to it's default state.
// InitGpio(); // Skipped for this example
// For this example use the following configuration:
Gpio_select();
// Step 3. Clear all interrupts and initialize PIE vector table:
// Disable CPU interrupts
DINT;
// Initialize PIE control registers to their default state.
// The default state is all PIE interrupts disabled and flags
// are cleared.
// This function is found in the DSP2802x_PieCtrl.c file.
// InitPieCtrl();
// Disable CPU interrupts and clear all CPU interrupt flags:
IER = 0x0000;
IFR = 0x0000;
// The shell ISR routines are found in DSP2802x_DefaultIsr.c.
// This function is found in DSP2802x_PieVect.c.
// Step 4. Initialize all the Device Peripherals:
// This function is found in DSP2802x_InitPeripherals.c
// InitPeripherals(); // Not required for this example
Gpio_example1();
void delay_loop(short n)
short i;
for (i = 0; i < n; i++) {}
