2235|2
447
求 430 RTC 例程 [复制链接]
请问谁有430RTC这一块的例程,麻烦上传一下,谢啦~
//****************************************************************************** //  MSP430FR59xx Demo - RTC in real time clock mode // //  Description: This program demonstrates the RTC mode by triggering an //  interrupt every second and minute. This code toggles P1.0 every second. //  This code recommends an external LFXT crystal for RTC accuracy. //  ACLK = LFXT = 32768Hz, MCLK = SMCLK = default DCO = 1MHz // //                MSP430FR5969 //             ----------------- //        /|\ |              XIN|- //         |  |                 | 32768Hz //         ---|RST          XOUT|- //            |                 | //            |            P1.0 |--> Toggles every second //            |                 | // //   William Goh //   Texas Instruments Inc. //   August 2014 //   Built with IAR Embedded Workbench V5.60 & Code Composer Studio V6.0 //****************************************************************************** #include int main(void) {     WDTCTL = WDTPW | WDTHOLD;               // Stop Watchdog Timer     P1DIR |= BIT0;                          // Set P1.0 as output     PJSEL0 = BIT4 | BIT5;                   // Initialize LFXT pins     // Disable the GPIO power-on default high-impedance mode to activate     // previously configured port settings     PM5CTL0 &= ~LOCKLPM5;     // Configure LFXT 32kHz crystal     CSCTL0_H = CSKEY >> 8;                  // Unlock CS registers     CSCTL4 &= ~LFXTOFF;                     // Enable LFXT     do     {       CSCTL5 &= ~LFXTOFFG;                  // Clear LFXT fault flag       SFRIFG1 &= ~OFIFG;     } while (SFRIFG1 & OFIFG);              // Test oscillator fault flag     CSCTL0_H = 0;                           // Lock CS registers     // Configure RTC_C     RTCCTL01 = RTCTEVIE | RTCRDYIE | RTCBCD | RTCHOLD;                                             // RTC enable, BCD mode, RTC hold                                             // enable RTC read ready interrupt                                             // enable RTC time event interrupt     RTCYEAR = 0x2010;                       // Year = 0x2010     RTCMON = 0x4;                           // Month = 0x04 = April     RTCDAY = 0x05;                          // Day = 0x05 = 5th     RTCDOW = 0x01;                          // Day of week = 0x01 = Monday     RTCHOUR = 0x10;                         // Hour = 0x10     RTCMIN = 0x32;                          // Minute = 0x32     RTCSEC = 0x45;                          // Seconds = 0x45     RTCADOWDAY = 0x2;                       // RTC Day of week alarm = 0x2     RTCADAY = 0x20;                         // RTC Day Alarm = 0x20     RTCAHOUR = 0x10;                        // RTC Hour Alarm     RTCAMIN = 0x23;                         // RTC Minute Alarm     RTCCTL01 &= ~(RTCHOLD);                 // Start RTC     __bis_SR_register(LPM3_bits | GIE);     // Enter LPM3 mode w/ interrupts enabled     __no_operation();     return 0; } #if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__) #pragma vector=RTC_VECTOR __interrupt void RTC_ISR(void) #elif defined(__GNUC__) void __attribute__ ((interrupt(RTC_VECTOR))) RTC_ISR (void) #else #error Compiler not supported! #endif {     switch(__even_in_range(RTCIV, RTCIV_RT1PSIFG))     {         case RTCIV_NONE:      break;        // No interrupts         case RTCIV_RTCOFIFG:  break;        // RTCOFIFG         case RTCIV_RTCRDYIFG:               // RTCRDYIFG             P1OUT ^= 0x01;                  // Toggles P1.0 every second             break;         case RTCIV_RTCTEVIFG:               // RTCEVIFG             __no_operation();               // Interrupts every minute             break;         case RTCIV_RTCAIFG:   break;        // RTCAIFG         case RTCIV_RT0PSIFG:  break;        // RT0PSIFG         case RTCIV_RT1PSIFG:  break;        // RT1PSIFG         default: break;     } }   详情 回复 发表于 2014-12-22 15:34
3415
没有
ASF里面應該不少吧
So TM what......?
裸片初长成(高级)
//                MSP430FR5969
//        /|\ |              XIN|-
//         |  |                 | 32768Hz
//         ---|RST          XOUT|-
//   William Goh
//   August 2014
#include
int main(void)
    do
      SFRIFG1 &= ~OFIFG;
    // Configure RTC_C
    __no_operation();
    return 0;
#else
#endif
            break;
            break;
        default: break;
直播时间:3月12日(周三)上午10:00
直播奖励:多功能榨汁机、蓝牙音箱、手机支架
