3298|2
5970
【Arrow SoC】如何编译硬件系统 [复制链接]
This page demonstrates how to compile the FPGA Hardware design that is delivered as part of the release.
The compilation will produce the following items:FileDescription
.sofSRAM Object File - FPGA programming file, resulted from compiling the FPGA hardware project
.sopcinfoSOPC Info File - containing a description of the hardware to be used by Device Tree Generator
.svdSystem View Description File - describes the hardware for the DS-5 debugger
HandoffFolder containing a description of the hardware to be used by the Preloader Generator
Prerequisites
The following items are required:
Procedure
[size=1em]The procedure described below uses the Cyclone V GHRD. The procedure for Arria V GHRD is similar, with only the file names being changed:
FileCyclone V
GHRD Archivesockit_ghrd_14.0.tar.gz
Quartus Projectsockit_ghrd/soc_system.qpf
Qsys Filesockit_ghrd/soc_system.qsys
Programming Filesockit_ghrd/output_files/soc_system.sofOpen Quartus Project
1. Retrieve and the archive file sockit_ghrd_14.0.tar.gz containing the hardware design and save it in the home folder. The file is available at sockit_ghrd_14.0.tar.gz.
2. Extract the files from the archive$ cd ~$ tar xzf sockit_ghrd_14.0.tar.gz
3. Make all the files writable (optional)$ chmod 777 -R ~sockit_ghrd
4. Start Quartus tool by double clicking the icon on the desktop, or by running it from the command line:$ ~/altera/14.0/quartus/bin/quartus --64bit
5. In Quartus, go to File -> Open Project ..., browse to the file sockit_ghrd/soc_system.qpf and click Open.
[size=1em]6. Quartus will load the project.
Generate System in Qsys
7. In Quartus, go to Tools -> Qsys to start the Qsys tool
8. Qsys tool will start and ask you to open a Qsys file. Select sockit_ghrd/soc_system.qsys and click Open.
[size=1em]9. Qsys will load the file
10. In Qsys, select Generate -≫ Generate this will open the Generate dialogue box.
11. In the Generate dialogue box, click the Generate button.
[size=1em]12. A message will be displayed when the generation is complete (may take a few minutes depending on host machine speed)
13. Click Close button in the Generation window to close it.
14. In Qsys, go to File -> Exit to close Qsys.
Compile the Design in Quartus
Running Analysis & Synthesis
15. In Quartus, in the Tasks panel change the flow from RTL Simulation to Compilation.
16. In the Tasks panel, right click Analysis and Synthesis and select Start.
[size=1em]17. After a few minutes (depending on host machine speed) the Analysis & Synthesis will finish and a message will be displayed.
Running the Assembler
21. In the Tasks panel, select Assembler, right click it and select Start.
[size=1em]22. After the assembly phase is completed, a notification message will be displayed.
Generated Files
This section presents the name and location of the files resulted from compiling the hardware design.FileDescription
sockit_ghrd/output_files/soc_system.sofSRAM Object File - for programming FPGA
sockit_ghrd/soc_system.sopcinfoSOPC Info File - Used by Device Tree Generator
sockit_ghrd/soc_system/synthesis/soc_system_hps_0_hps.svdSystem View File - Used by ARM DS-5 AE
sockit_ghrd/hps_isw_handoffHandoff folder - Used by Preloader GeneratorConverting .sof to .rbf
[size=1em]The SOF (SRAM Object File) file can use used to program the FPGA from the Quartus Programmer tool.
[size=1em]However, for the purpose of programming the FPGA from software, the SOF file needs to be converted to a RBF (Raw Binary File) format.
[size=1em]Several different options are available for converting the file:
A. Using the command line tools from Quartus Programmer (installed by default with the SoC EDS or installed standalone) or from Quartus. $ ~/altera/14.0/quartus/bin/quartus_cpf -c \
  sockit_ghrd/output_files/soc_system.sof  \
  sockit_ghrd/output_files/soc_system.rbf  $ ~/altera/14.0/qprogrammer/bin/quartus_cpf -c \
B. Using the GUI converter, callable from either Quartus Programmer or Quartus by selecting the menu File -> Convert Programming Files.
  • Select the Programming File Type to be Raw Binary File (.rbf)
  • Select the Mode to be Fast Passive Parallel X8 or 16
  • Click on the SOF Data then click Add File and browse to the soc_system.sof file
  • Edit the desired name of the output file to be soc_system.rbf
  • Click the Generate button
此帖出自FPGA/CPLD论坛
不容易呀  详情 回复 发表于 2015-1-9 14:03
点赞 关注(1)
个人签名生活就是油盐酱醋再加一点糖,快活就是一天到晚乐呵呵的忙
做一个简单的人,踏实而务实,不沉溺幻想,不庸人自扰
1025
点赞!
尽职尽责的好斑竹,这个是你自己操作过程的截图?
我 都是直接把arrow给的lab文档整个直接上传上来,自己 只对着操作了一下,惭愧惭愧
此帖出自FPGA/CPLD论坛
不容易呀
此帖出自FPGA/CPLD论坛
