2931|3
43
MSP430F5XXX 的I2C问题 [复制链接]
I2C通信,如果MCU作为主机时,必须要先发送从机地址,即 Slave addr + R/W。
   但为什么我看TI给出的Example中,初始化从机地址(UCB0I2CSA寄存器)之后,直接就发出了START信号,
   并没有向发送缓冲寄存器UCB0TXBUF中送任何数据?!
   难道只要初始化从机地址,然后启动START,MCU就能自动将 Slave addr + W 发送给从机??
   附TI的Example:
    int main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  P3SEL |= 0x03;                            // Assign I2C pins to USCI_B0
  UCB0CTL1 |= UCSWRST;                      // Enable SW reset
  UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC;     // I2C Master, synchronous mode
  UCB0CTL1 = UCSSEL_2 + UCSWRST;            // Use SMCLK, keep SW reset
  UCB0BR0 = 12;                             // fSCL = SMCLK/12 = ~100kHz
  UCB0BR1 = 0;
  UCB0I2CSA = 0x48;                         // Slave Address is 048h
  UCB0CTL1 &= ~UCSWRST;                     // Clear SW reset, resume operation
  UCB0IE |= UCTXIE;                         // Enable TX interrupt
  TXData = 0x01;                            // Holds TX data
  while (1)
    TXByteCtr = 1;                          // Load TX byte counter
    while (UCB0CTL1 & UCTXSTP);             // Ensure stop condition got sent
    UCB0CTL1 |= UCTR + UCTXSTT;             // I2C TX, start condition
    __bis_SR_register(LPM0_bits + GIE);     // Enter LPM0 w/ interrupts
    __no_operation();                       // Remain in LPM0 until all data
                                           // is TX'd
    TXData++;                               // Increment data byte
// The USCIAB0_ISR is structured such that it can be used to transmit any
// number of bytes by pre-loading TXByteCtr with the byte count.
#if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
#pragma vector = USCI_B0_VECTOR
__interrupt void USCI_B0_ISR(void)
#elif defined(__GNUC__)
void __attribute__ ((interrupt(USCI_B0_VECTOR))) USCI_B0_ISR (void)
#else
#error Compiler not supported!
#endif
  switch(__even_in_range(UCB0IV,12))
  case  0: break;                           // Vector  0: No interrupts
  case  2: break;                           // Vector  2: ALIFG
  case  4: break;                           // Vector  4: NACKIFG
  case  6: break;                           // Vector  6: STTIFG
  case  8: break;                           // Vector  8: STPIFG
  case 10: break;                           // Vector 10: RXIFG
  case 12:                                  // Vector 12: TXIFG
    if (TXByteCtr)                          // Check TX byte counter
      UCB0TXBUF = TXData;                   // Load TX buffer
      TXByteCtr--;                          // Decrement TX byte counter
    else
      UCB0CTL1 |= UCTXSTP;                  // I2C stop condition
      UCB0IFG &= ~UCTXIFG;                  // Clear USCI_B0 TX int flag
      __bic_SR_register_on_exit(LPM0_bits); // Exit LPM0
    break;
  default: break;
是自动发送从机地址的,在你起始信号发出后,从机地址就自动发送了,不需要再发一次。  详情 回复 发表于 2014-12-31 13:32
2856
260
仔细看一下中断程序
中断程序里是循环发送00~FF啊,有什么问题?  详情 回复 发表于 2014-12-1 15:58
43
ltbytyn 发表于 2014-12-1 14:46
仔细看一下中断程序
114
