2724|2
445
【TI首届低功耗设计大赛】+MSP430FR5969中GPIO操作的关键 [复制链接]
终于有时间静下心来学习一下5969,刚起步就碰壁。5969的编程方式官方的给的是基于库的操作,真是有不习惯,但是这是现在编程的最流行的一种,能够提高效率,所以就开始一点点看,想从操作的GPIO开始,根据例程,点LED灯一直没有点亮,感觉挺好郁闷,重新查看例程,里面有一句关键的代码: PMM_unlockLPM5();  然后查看文档,文档中解释,PM5CTL0中的LOCKPM5需要软件复位,不然IO口处于高阻态。正是这个原因,IO操作一直没有成功。
在时间配置时,内部默认是1M的DCO,例程的中配置为8M的DCO。
下面根据是GPIO操作的代码。现在不管用库操作还是直接寄存器操作都可以。
* main.c
* Out of Box Demo for the MSP-EXP430FR5969
* Main loop, initialization, and interrupt service routines
* June 2014
* E. Chen
#include "main.h"
#include "driverlib.h"
uint8_t RXData = 0;                               // UART Receive byte
int mode = 0;                                     // mode selection variable
int pingHost = 0;                                 // ping request from PC GUI
Calendar calendar;                                // Calendar used for RTC
#if defined(__IAR_SYSTEMS_ICC__)
#pragma location = 0x9000
__no_init uint16_t dataArray[12289];
#endif
int _system_pre_init(void)
    // Stop Watchdog timer
    WDT_A_hold(__MSP430_BASEADDRESS_WDT_A__);     // Stop WDT
    /* Choose if segment initialization */
    /* should be done or not. */
    /* Return: 0 to omit initialization */
    /* 1 to run initialization */
    return 1;
* main.c
int main(void) {
    // Board initializations
    //Init_GPIO();
    //Init_Clock();
    //Init_UART();
    P1DIR |= 0xFF;
    P1OUT |= 0x00;
    P4DIR  |= 0xFF;
    P4OUT = 0x00;
    PMM_unlockLPM5();
    while (1)
            //GPIO_toggleOutputOnPin(GPIO_PORT_P1,GPIO_PIN0);
            P1OUT |= 0x01;
            P4OUT |= 0x40;
            _delay_cycles(800000);
            P1OUT &= 0xFE;
            P4OUT &= 0xBF;
* GPIO Initialization
void Init_GPIO()
    // Set all GPIO pins to output low for low power
    GPIO_setOutputLowOnPin(GPIO_PORT_P1, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
    GPIO_setOutputLowOnPin(GPIO_PORT_P2, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
    GPIO_setOutputLowOnPin(GPIO_PORT_P3, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
    GPIO_setOutputLowOnPin(GPIO_PORT_P4, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
    GPIO_setOutputLowOnPin(GPIO_PORT_PJ, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7|GPIO_PIN8|GPIO_PIN9|GPIO_PIN10|GPIO_PIN11|GPIO_PIN12|GPIO_PIN13|GPIO_PIN14|GPIO_PIN15);
    GPIO_setAsOutputPin(GPIO_PORT_P1, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
    GPIO_setAsOutputPin(GPIO_PORT_P2, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
    GPIO_setAsOutputPin(GPIO_PORT_P3, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
    GPIO_setAsOutputPin(GPIO_PORT_P4, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7);
    GPIO_setAsOutputPin(GPIO_PORT_PJ, GPIO_PIN0|GPIO_PIN1|GPIO_PIN2|GPIO_PIN3|GPIO_PIN4|GPIO_PIN5|GPIO_PIN6|GPIO_PIN7|GPIO_PIN8|GPIO_PIN9|GPIO_PIN10|GPIO_PIN11|GPIO_PIN12|GPIO_PIN13|GPIO_PIN14|GPIO_PIN15);
    PMM_unlockLPM5();  //必须有
* Clock System Initialization
void Init_Clock()
    // Set DCO frequency to 1 MHz
    CS_setDCOFreq(CS_DCORSEL_0, CS_DCOFSEL_6);
    //Set external clock frequency to 32.768 KHz
    CS_setExternalClockSource(32768, 0);
    //Set ACLK=LFXT
    CS_clockSignalInit(CS_ACLK, CS_LFXTCLK_SELECT, CS_CLOCK_DIVIDER_1);
    // Set SMCLK = DCO with frequency divider of 1
    CS_clockSignalInit(CS_SMCLK, CS_DCOCLK_SELECT, CS_CLOCK_DIVIDER_1);
    // Set MCLK = DCO with frequency divider of 1
    CS_clockSignalInit(CS_MCLK, CS_DCOCLK_SELECT, CS_CLOCK_DIVIDER_1);
    //Start XT1 with no time out
    CS_LFXTStart(CS_LFXTDRIVE_0);
应用库操作时,要把头文件包含到里面去,这里学习用工程内部相对引用的方法表示方法:
"${PROJECT_LOC}/driverlib/MSP430FR5xx_6xx"
LedTest.rar (479.39 KB, 下载次数: 4, 售价: 1 分芯积分)
c库和寄存器库都有吧 不过我还是喜欢用c库 现在单片机种类那么多,都去操作寄存器,那还不得头大  详情 回复 发表于 2014-11-2 15:02
个人签名stay hungry,stay foolish.
3416
c库和寄存器库都有吧
不过我还是喜欢用c库
So TM what......?
445
我觉的使用C库操作上手快,使用寄存器操作更好理解一些。现在也是开始学习使用这种编程方法。
