3342|4
31
求MSP430G2452串口通信案例 [复制链接]
本人msp新手,希望大神们能给个msp430g2452串口通信案例,比如:向串口助手发送一个字符或者字符串。
#include int main(void) {   WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT   if (CALBC1_1MHZ==0xFF)                                        // If calibration constant erased   {        while(1);                               // do not load, trap CPU!!          }   DCOCTL = 0;                               // Select lowest DCOx and MODx settings   BCSCTL1 = CALBC1_1MHZ;                    // Set DCO   DCOCTL = CALDCO_1MHZ;   P1SEL = BIT1 + BIT2 ;                     // P1.1 = RXD, P1.2=TXD   P1SEL2 = BIT1 + BIT2 ;                    // P1.1 = RXD, P1.2=TXD   UCA0CTL1 |= UCSSEL_2;                     // SMCLK   UCA0BR0 = 104;                            // 1MHz 9600   UCA0BR1 = 0;                              // 1MHz 9600   UCA0MCTL = UCBRS0;                        // Modulation UCBRSx = 1   UCA0CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**   IE2 |= UCA0RXIE;                          // Enable USCI_A0 RX interrupt   __bis_SR_register(LPM0_bits + GIE);       // Enter LPM0, interrupts enabled } //  Echo back RXed character, confirm TX buffer is ready first #if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__) #pragma vector=USCIAB0RX_VECTOR __interrupt void USCI0RX_ISR(void) #elif defined(__GNUC__) void __attribute__ ((interrupt(USCIAB0RX_VECTOR))) USCI0RX_ISR (void) #else #error Compiler not supported! #endif {   while (!(IFG2&UCA0TXIFG));                // USCI_A0 TX buffer ready?   UCA0TXBUF = UCA0RXBUF;                    // TX -> RXed character }   详情 回复 发表于 2014-11-1 11:51
496
CCS中MSP430WARE就有详细的实例
请问您能给个具体的实例吗?那个还不会用。  详情 回复 发表于 2014-10-31 09:41
个人签名相由心生,境随心转,一切法从心想生。
31
你是使用CCS还是IAR呢?CCS6的话看这个帖子https://bbs.eeworld.com.cn/thread-445434-1-1.html  详情 回复 发表于 2014-10-31 10:21
496
2781
417
#include
int main(void)
#else
#endif
例程.zip
226.17 KB, 下载次数: 20
