// Drain any residual data from the receive FIFO.
while(MAP_SSIDataGetNonBlocking(SSI3_BASE, &ui32Trash) != 0)
// Set the SSI module into write-only mode.
MAP_SSIAdvModeSet(SSI3_BASE, SSI_ADV_MODE_WRITE);
// Send the read command.
MAP_SSIDataPut(SSI3_BASE, CMD_READ);
// Send the address of the first byte to read.
MAP_SSIDataPut(SSI3_BASE, (ui32Addr >> 8) & 0xff);
MAP_SSIDataPut(SSI3_BASE, ui32Addr & 0xff);
// Set the SSI module into read/write mode. In this mode, dummy writes are
// required in order to make the transfer occur; the SPI flash will ignore
// the data.
MAP_SSIAdvModeSet(SSI3_BASE, SSI_ADV_MODE_READ_WRITE);
// See if there is a single byte to be read.
if(ui32Count == 1)
// Perform a single dummy write, marking it as the end of the frame.
MAP_SSIAdvDataPutFrameEnd(SSI3_BASE, 0);
else
// Perform a dummy write to prime the loop.
MAP_SSIDataPut(SSI3_BASE, 0);
// Loop while there is more than one byte left to be read.
while(--ui32Count != 1)
// Perform a dummy write to keep the transmit FIFO from going
// empty.
// Read the next data byte from the receive FIFO and place it into
// the data buffer.
MAP_SSIDataGet(SSI3_BASE, &ui32Addr);
*pui8Data++ = ui32Addr & 0xff;
// Perform the final dummy write, marking it as the end of the frame.
// Read the next data byte from the receive FIFO and place it into the
// data buffer.
// Read the final data byte from the receive FIFO and place it into the
// data buffer.
用示波器测试信号,写,时钟和片选信号均正常,EEPROM的输出无信号,一直为0.我使用的EEPROM型号
是25LC512.
麻烦各位大侠了!
