2691|5
23
仿真了下18b20,都显示出来了,加了4个模块后,一段时间,? [复制链接]
#include
#include
#include
#define uchar  unsigned char
#define uint   unsigned int
static   uchar  th,tl,b,c,d,f,j,e;
   uint a, temp;
sbit morehigh=P1^0 ;
sbit high=P1^1 ;
sbit low=P1^2 ;
sbit morelow=P1^3 ;
sbit R=P2^3;
sbit lcdrs=P2^0;
sbit lcdrw=P2^1;
sbit lcden=P2^2;
sbit speak=P2^5;
sbit di=P2^4;
sbit close=P2^6;
sbit open=P2^7;
unsigned char  time ;
void  motor();
void motor1();
void rotate();
unsigned char code table[]={"0123456789.:'C"};
unsigned char code table1[]={"temp:"};
unsigned char code table2[]={"the angular is "};
unsigned char code error[]={"    error!"};
unsigned char code table4[]={"the angular is "};
void delay1us(unsigned char x)
uint i;
x*=5/4;
  for(i=0;i }
void delay1ms()
{ unsigned int x,y; for(x=0;x<10;x++) for(y=33;y>0;y--); }
void delay(unsigned int z)
{ unsigned char x; for(x=z;x>0;x--)   delay1ms();}
  void change();
void write_com(unsigned char com)
lcdrs=0;
             SBUF=com;         //       原来并行通信时,  这条 是  P1=com;
       // P1=com;
          while(TI==0);TI=0;  //   这条 是我改过的, 原来并行通信时,这条 是没有的
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_data(unsigned char dat)
lcdrs=1;
             SBUF=dat;            //     原来并行通信时,  这条 是  P1=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void init(void)
            lcden=0;
         lcdrw=0;
write_com(0x01);
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x80);
   /*DS18b20操作program*/
bit datayn(void)       //初始化设置
  bit flag;
  di=1;
  for(time=0;time<2;time++);
  di=0;
  for(time=0;time<200;time++);
  di=1;
for(time=0;time<10;time++);
  flag=di;
for(time=0;time<100;time++);
   di=1;
  return(flag) ;
void Delayxus_DS18B20(unsigned int t)
          for(t;t>0;t--)
                 _nop_();_nop_();_nop_();_nop_();
          _nop_(); _nop_();
unsigned char Read_Bit()
          unsigned char ret;
          di=0;//拉低总线
          _nop_(); _nop_();
          di=1;//释放总线
        //  _nop_(); _nop_();
          ret=di;//读时隙产生7 us后读取总线数据。把总线的读取动作放在15us时间限制的后面是为了保证数据读取的有效性
          Delayxus_DS18B20(3);//延时60us,满足读时隙的时间长度要求
      di=1;//释放总线
          return ret; //返回读取到的数据
uchar read_onechar(void)
          unsigned char i;
          unsigned char dat=0;
       for(i=0;i<8;i++)
          dat>>=1; //先读最低位
          if(Read_Bit())
                 dat|=0x80;
          return(dat);
  void write_onechar(uchar dat)
  uchar i,time;
      di=1; _nop_();
     for(i=0;i<8;i++)
       di=0;  // delay1us(2); //for(time=0;time<4;time++);
        di=dat&0x01; delay1us(20);  // for(time=0;time<10;time++);
     di=1;
    _nop_(); //_nop_();
     dat>>=1;
void display(void)
  unsigned int i=0;
  write_com(0x80);
  if(datayn()==1)
     while(error!='\0')
            write_data(error);
            i++;
   else
       while(table1!='\0')
          write_data(table1);
          i++;
void readtemp()
      di=1;_nop_();_nop_();
     datayn();
     write_onechar(0XCC);
     write_onechar(0x44);
     datayn();
     write_onechar(0XBE);
  tl=read_onechar(); th=read_onechar();
//  while ((tl>>4|th<<4)==85);
     di=1; _nop_();    _nop_();  //   nop_();
      if (th>>4==0)
       e=1;
          a=tl>>4|th<<4;
        b=a/100;c=(a%100)/10;d=a%10;
        j=tl&0x0f;f=(j*10/16)%10;
       write_com(0x85); write_data('\0');
    else
      e=0;
      temp=(~(tl|th<<8)+1);temp*=0.0625;b=temp/100;c=temp/10%10;d=temp%10;f=(temp*10)%10;
      write_com(0x85); write_data('-');
     write_com(0x86); write_data(table);write_data(table[c]);
     write_data(table[d]);write_data(0x2e);write_data(table[f]);
     write_data(table[12]);write_data('c');
void main()
SCON=0x00;
R=0; _nop_(); _nop_(); R=1;
   init();
  display();
  while(1)
   readtemp();
   motor();
   motor1();
    rotate();
void motor()
  P0=0XFF;
// uchar t;
   while (close==0)
      uchar i,t;   t=0xfe;
     while (close==0);
        for(i=0;i<4;i++)
          P0=t;
           delay(1000);
          t=_crol_(t,1);
  while (open==0)
     uchar i,t;   t=0xf7;
     while (open==0);
      for(i=0;i<4;i++)
          P0=t;  delay(1000);t=_cror_(t,1);
void motor1()
  P1=0XFF;
// uchar t;
   while ( high==0)
     uchar i,t;
   while (1)
    { t=0xfe;
        for(i=0;i<4;i++)
          P0=t;
           delay(100);
          t=_crol_(t,1);
  while (low==0)
     uchar i,t;
    while (low==0)
     {  t=0xf7;
      for(i=0;i<4;i++)
          P0=t;
          delay(20);  t=_cror_(t,1);
   void  alarm()
      uchar j=10;
       while (j--)
        speak=~speak;
        delay(30);
  void rotate()
   if(a>100)
       uchar i,t;
      while (1)
        { t=0xfe;
           for(i=0;i<4;i++)
              P0=t;
              delay(20);
              t=_crol_(t,1);
              alarm();
   if(a>90&&a<100)
        uint uk ;
        uk=55-a;
        while (uk--)
      uchar i,t; t=0xfe;
         for(i=0;i<4;i++)
               P0=t;
               delay(20);
               t=_crol_(t,1);
if(a>50&&a<90) P0=0xff;
if(a>40&&a<50)
     uint uh ;
      uh=55-a;
      while (uh--)
          uchar i,t; t=0xf7;
         for(i=0;i<4;i++)
               P0=t;
               delay(20);
               t=_cror_(t,1);
if(a<40)
     uchar i,t;
               t=0xf7;
               for(i=0;i<4;i++)
                 P0=t;
                 alarm();
仿真了下18b20,都显示出来了,也正常,加了4个模块(根据不同的温度调试电机的转速)后,也正常,按钮也正常,一段时间后,温度反应异常了 。void motor() ,void motor1(),void  alarm(),void rotate()。前三个也没事,就是void rotate()出问题了,哪位大神看见后,帮忙分析下 怎么回事啊 ,小弟先在此谢谢了。还有就是刚开始就显示85,怎么一开始就显示正确呢
此帖出自单片机论坛
应该是时序吧,或者在硬件上看看, proteus怎么说是个虚物。   详情 回复 发表于 2014-9-7 23:53
106
好长,void rotate()里的 while (1)   做什么用的?为什么没跳出语句?   刚开始就显示85,那应该没什么事。
此帖出自单片机论坛
首先先谢谢了, while(1) 也确实是个问题,但主要问题,在下面的 图片上,我把while改成if 好多了 但是还是存在点问题 就是显示温度是很稳定,偶尔会出现其他的温度值,我怀疑是不是串口速度问  详情 回复 发表于 2014-9-7 13:25
4008
多机18b20是可以串接的软件改动下就行.
此帖出自单片机论坛
我的18b20就一个呀,哥,不是很清楚你的意思  详情 回复 发表于 2014-9-7 13:27
23
刘W杰 发表于 2014-9-5 22:03
好长,void rotate()里的 while (1)   做什么用的?为什么没跳出语句?   刚开始就显示85,那应该没什么事 ...
首先先谢谢了,  while(1)  也确实是个问题,但主要问题,在下面的 图片上,我把while改成if  好多了   但是还是存在点问题    就是显示温度是很稳定,偶尔会出现其他的温度值,我怀疑是不是串口速度问题。
此帖出自单片机论坛
23
此帖出自单片机论坛
106
1322685712 发表于 2014-9-7 13:25
首先先谢谢了,  while(1)  也确实是个问题,但主要问题,在下面的 图片上,我把while改成if ...
此帖出自单片机论坛
