3636|1
tm4c1294ncpdt串口的DMA中断问题 [复制链接]
进入串口中断处理程序后,获取中断工作状态后,而程序总是在中断里跑,始终挑不出来,串口的配置已配好.(附程序)
uint32_t ulStatus;
         ulStatus = UARTIntStatus(UART0_BASE, false);
                   uint32_t recv_n = 0;
                char c;
                int port_id = 0;
                unsigned long ulMode;
    UARTIntClear(UART0_BASE, ulStatus);
                if( ulStatus & UART_INT_RX || ulStatus & UART_INT_RT )                //
                                for (;;)
                                        if (!UARTCharsAvail(UART0_BASE)) break; //
                                        c = UARTCharGetNB(UART0_BASE); //
                                        recv_n++;
                                        if (RxIndex[port_id] < MAX_SIZE)
                                                RxData[port_id][RxIndex[port_id]++] = c;
                                                RxData[port_id][RxIndex[port_id]] = '\0';
                                        if (recv_n == 11)
                                                break;
                                if ( ulStatus & UART_INT_RT )
                                        RxLen[port_id] = RxIndex[port_id];
                                        RxIndex[port_id] = 0;
                                //        Rt0IntNum++;
                                        RxEndFlag[port_id] = true;
                                        uartPuts( 0, RxData[0] );
                                //        Uart0Func();
                if( ulStatus & UART_INT_DMATX )
                        ulMode = uDMAChannelModeGet( UDMA_CHANNEL_UART_TX[port_id] | UDMA_PRI_SELECT );
                        if(ulMode == UDMA_MODE_STOP)
                                uDMAChannelAssign(UDMA_CH9_UART0TX);
                                if( DMAlen[port_id] > 1024 )
                                        memcpy(DMA_temp[port_id], DMA_tBuff[port_id]+1024, DMAlen[port_id]-1024);
                                        uDMAChannelTransferSet(UDMA_CHANNEL_UART0TX | UDMA_PRI_SELECT,
        UDMA_MODE_BASIC, DMA_temp[port_id],
        (void *)(UART0_BASE + UART_O_DR), DMAlen[port_id]-1024 );
                                        uDMAChannelEnable(UDMA_CHANNEL_UART0TX);
                                        DMAlen[port_id] -= 1024;
程序有点乱  详情 回复 发表于 2014-9-4 23:39
程序有点乱
