2508|0
6423
LPC1500体验+4.UART [复制链接]
1、在开关矩阵中给RXDTXD分配引脚,设置系统时钟、主时钟、和UART时钟分频
  1. SystemCoreClockUpdate();
  2. Init_UART0_PinMux();
复制代码
2、全局定义
3、定义配置结构体,初始化UART API的指针
4、定义要发送的字符串
5、为UART  API 初始化memory并创建句柄
6、初始化UART,配置波特率。
  1. /* Set UART base rate */
  2. uint32_t Chip_Clock_SetUARTBaseClockRate(uint32_t rate, bool fEnable)
  3. {
  4.         uint32_t div, inclk;
  5.         /* Input clock into FRG block is the main system cloock */
  6.         inclk = Chip_Clock_GetMainClockRate();
  7.         /* Get integer divider for coarse rate */
  8.         div = inclk / rate;
  9.         if (div == 0) {
  10.                 div = 1;
  11.         }
  12.         /* Approximated rate with only integer divider */
  13.         Chip_Clock_SetUARTFRGDivider((uint8_t) div);
  14.         if (fEnable) {
  15.                 uint32_t err;
  16.                 uint64_t uart_fra_multiplier;
  17.                 err = inclk - (rate * div);
  18.                 uart_fra_multiplier = ((uint64_t) err  * 256) / (uint64_t) (rate * div);
  19.                 /* Enable fractional divider and set multiplier */
  20.                 LPC_SYSCTL->FRGCTRL = 0xFF | ((uart_fra_multiplier & 0xFF) << 8);
  21.         }
  22.         else {
  23.                 /* Disable fractional generator and use integer divider only */
  24.                 LPC_SYSCTL->FRGCTRL = 0;
  25.         }
  26.         return Chip_Clock_GetUARTBaseClockRate();
  27. }
复制代码
7、使能UART中断
  1. NVIC_EnableIRQ(UART0_IRQn);
复制代码
8、配置UART 常数结构体UART_PARAM_T
  1. /**
  2. * @brief UART ROM driver parameter structure
  3. */
  4. typedef struct {
  5.         uint8_t         *buffer;                /*!< Pointer to data buffer */
  6.         uint32_t        size;                        /*!< Size of the buffer */
  7.         uint16_t        transfer_mode;        /*!< Transfer mode settings */
  8.        /*!<   0x00: uart_get_line: stop transfer when the buffer is full */
  9.        /*!<   0x00: uart_put_line: stop transfer when the buffer is empty */
  10.        /*!<   0x01: uart_get_line: stop transfer when CRLF are received */
  11.        /*!<   0x01: uart_put_line: transfer stopped after reaching \0 and CRLF is sent out after that */
  12.        /*!<   0x02: uart_get_line: stop transfer when LF are received */
  13.        /*!<   0x02: uart_put_line: transfer stopped after reaching \0 and LF is sent out after that */
  14.        /*!<   0x03: uart_get_line: RESERVED */
  15.        /*!<   0x03: uart_put_line: transfer stopped after reaching \0 */
  16.         uint8_t         driver_mode;        /*!< Driver mode */
  17.        /*!<  0x00: Polling mode, function blocked until transfer completes */
  18.        /*!<  0x01: Interrupt mode, function immediately returns, callback invoked when transfer completes */
  19.        /*!<  0x02: DMA mode, in case DMA block is available, DMA req function is called for UART DMA channel setup, then callback function indicate that transfer completes */
  20.         uint8_t         dma_num;                /*!< DMA channel number in case DMA mode is enabled */
  21.         UART_CALLBK_T   callback_func_pt;
  22.         uint32_t dma;        /* DMA handler */
  23. } UART_PARAM_T;
复制代码
9、定义传输结束时调用的接收和发送回调函数
10、发送字符串,遇到\0时结束发送,然后发送回车换行(CRCarriage Return  LFLine Feed \r\n)
11、接收字符串直到填满缓冲区
此帖出自单片机论坛
个人签名training
