C 题:锁定放大器的设计 1.任务 设计制作一个用来检测微弱信号的锁定放大器(LIA)。锁定放大器基本组成框图 见图 1。 信号通道
信号
交流
带通
x(t)
相敏
低通
直流
输出
显
放大器
滤波器
检波器
滤波器
放大器
示
S(t)
参考
参考通道
r(t)
触发
移相器
方波
R(t)
整形
驱动
图 1 锁定放大器基本组成结构框图 2.要求 (1)外接信号源提供频率为 1kHz 的正弦波信号,幅度自定,输入至参考信号 R(t) 端。R(t)通过自制电阻分压网络降压接至被测信号 S(t)端,S(t)幅度有效值为 10μV~1mV。(5 分) (2)参考通道的输出 r(t)为方波信号,r(t)的相位相对参考信号 R(t)可连续或步进 移相 180 度,步进间距小于 10 度。(20分) (3)信号通道的 3dB 频带范围为900Hz~1100Hz。误差小于 20%。(10 分) (4)在锁定放大器输出端,设计一个能测量显示被测信号 S(t)幅度有效值的电路。 测量显示值与 S(t)有效值的误差小于 10%。(15 分) 共 2 页,C‐1 file:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image001.pngfile:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image002.pngfile:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image003.pngfile:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image004.pngfile:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image005.pngfile:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image006.pngfile:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image007.pngfile:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image008.pngfile:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image009.pngfile:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image010.pngfile:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image011.pngfile:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image012.pngfile:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image013.pngfile:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image014.pngfile:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image015.pngfile:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image016.pngfile:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image017.pngfile:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image018.pngfile:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image019.pngfile:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image020.pngfile:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image021.pngfile:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image022.pngfile:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image023.pngfile:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image024.pngfile:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image024.png file:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image025.jpg
file:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image026.jpg
file:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image027.jpg
file:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image028.jpg
file:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image029.jpg
file:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image030.jpg
file:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image031.jpg
file:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image032.jpg
file:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image033.jpg
file:///C:/Users/ADMINI~1.KTW/AppData/Local/Temp/msohtmlclip1/01/clip_image034.jpg
(5)在锁定放大器信号 S(t)输入端增加一个运放构成的加法器电路,实现 S(t)与 干扰信号 n(t)的1:1 叠加,如图 2 所示。(5 分) 锁定放大器
S(t)
加法器
信号
交流放大器
带通滤波器
x(t)
n(t)
S(t)+n(t)
图 2 锁定放大器叠加噪声电路图 (6)用另一信号源产生一个频率为 1050~2100Hz 的正弦波信号,作为 n(t)叠加在 锁定放大器的输入端,信号幅度等于 S(t)。n(t)亦可由与获得 S(t)同样结构的 电阻分压网络得到。锁定放大器应尽量降低 n(t)对 S(t)信号有效值测量的影 响,测量误差小于 10%。(20 分) (7)增加 n(t)幅度,使之等于 10S(t),锁定放大器对 S(t)信号有效值的测量误差小 于 10%。(20 分) (8)其他自主发挥。(5 分) (9)设计报告。(20 分) 3.说明 (1)各信号输入、输出端子必须预留测量端子,以便于测量。 (2)要求(1)和(6)中的电阻分压网络的分压比例自定。由于μV 级信号常规 仪器难以测量,可通过适合加大输入信号幅度的方法,测量并标定其分压比。 (2)关于锁定放大器的原理可参考《微弱信号检测》。高晋占编著,清华大学出 版社 2004 年。
