3803|2
如何设置ADC参考电压? [复制链接]
ADC获取某点电压值,范围只有0~1.65v,M4的内部参考电压不是3.3v吗?
我用了 ADCReferenceSet (ADC0_BASE,ADC_REF_INT); 但是结果没有用。
M4可以接入更高的参考电压吗?
#include "stdint.h"
#include "stdbool.h"
#include "inc/hw_memmap.h"
#include "inc/hw_types.h"
#include "inc/hw_ints.h"
#include "driverlib/interrupt.h"
#include "driverlib/adc.h"
#include "driverlib/sysctl.h"
#include "driverlib/gpio.h"
#include "driverlib/pin_map.h"
#include "LCDDriver.h"
void Init_ADC_Detect()
        SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC0);
        SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOB);
        GPIOPinTypeADC(GPIO_PORTB_BASE, GPIO_PIN_4);
        ADCSequenceConfigure(ADC0_BASE, 3, ADC_TRIGGER_PROCESSOR, 0);
        ADCSequenceStepConfigure(ADC0_BASE, 3, 0, ADC_CTL_CH10 | ADC_CTL_IE | ADC_CTL_END);
        ADCSequenceEnable(ADC0_BASE, 3);
        ADCIntClear(ADC0_BASE, 3);
int main(void)
        uint32_t Average;
        uint32_t pui32ADC0Value[1];
        SysCtlClockSet(SYSCTL_SYSDIV_1 | SYSCTL_USE_OSC | SYSCTL_OSC_MAIN | SYSCTL_XTAL_16MHZ);
        LCD_Enable();
        LCD_Init();
        LCD_ScreenClr();
        LCD_Draw_Chinese(1,1,0);
        LCD_Draw_Chinese(2,1,16);
        LCD_Draw_Char_8x16(':',1,32);
        LCD_Draw_Char_8x16('V',1,119);
        Init_ADC_Detect();
        while(1)
            SysCtlDelay(SysCtlClockGet()/4);
                ADCProcessorTrigger(ADC0_BASE, 3);
                while(!ADCIntStatus(ADC0_BASE, 3, false))
                ADCSequenceDataGet(ADC0_BASE, 3, pui32ADC0Value);
                Average = (pui32ADC0Value[0] * 1650) / 4096;
                unsigned char data1[4] = {0};
                data1[0] = pui32ADC0Value[0] / 1000;
                data1[1] = (pui32ADC0Value[0] / 100) % 10;
                data1[2] = (pui32ADC0Value[0] / 10) % 10;
                data1[3] = (pui32ADC0Value[0] / 1) % 10;
                int k;
                for(k = 0; k < 4; ++k)
                        LCD_Draw_Char_8x16('0' + data1[k], 3, 50 + 8 * k);
                int i = 0 ;
                unsigned char data[4] = {0};
                data[0] = (Average / 1000);
                data[1] = (Average / 100) % 10;
                data[2] = (Average / 10) % 10;
                data[3] = (Average / 1) % 10;
                for(i = 0; i < 4; ++i)
                        LCD_Draw_Char_8x16('.', 1, 50 + 10 * 1);
                        if(i < 1)
                        LCD_Draw_Char_8x16('0' + data[i], 1, 50 + 10 * i);
                        else
                        LCD_Draw_Char_8x16('0' + data[i], 1, 50 + 10 * (i + 1));
TM4C123GH6PM不支持修改参考电压!可以看数据手册,参考电压端固定接在了3.3V上。。 有些其它系列芯片支持  详情 回复 发表于 2015-4-5 22:52
点赞 关注(1)
81
大神解决没,分享下啊
164
有些其它系列芯片支持
