4074|13
34
看到浙江省电子设计竞赛元器件清单可以猜测大概可以做什么题目? [复制链接]
电源类
MOSFET驱动器
TPS28225DR
8-Pin High Frequency 4-Amp Sink Synchronous MOSFET Driver
UCC27211DDAR
120V Boot, 4A Peak, High Frequency High-Side Low-Side Driver
降压开关电源,MOS管内置
TPS54340DDAR
42 V Input, 3.5 A, Step-Down DC/DC Converter with Eco-mode?
TPS56528DDAR
4.5V to 18V Input, 5-A Synchronous Step-Down Converter with Advanced Eco-mode?
降压线性电源
TPS7A1601QDGNRQ1
Automotive Catalog 60V, 5-µA Iq, 100-mA, Low-Dropout Voltage Regulator with Enable and Power Good
降压线性电源
TPS7A4001DGNR
100V Input, 50mA, Single Output Low-Dropout Linear Regulator
升压开关电源,MOS管外置
TPS40210DGQR
Wide Input Range Current Mode Boost Controller
MOS管
CSD19535KCS
100V, N-Channel NexFET? Power MOSFET
电流检测芯片
INA210AIDCKR
Voltage Output, High/Low-Side Measurement, Bi-Directional Zero-Drift Series Current Shunt Monitor
INA282AIDR
Wide Common Mode Range, Bidirectional, High Accuracy Current Shunt Monitor
高速放大器
电流反馈
THS3201D
1.8GHz Current Feedback Amplifier
LMH6703MF/NOPB
1.2 GHz, Low Distortion Op Amp with Shutdown
OPA2695ID
Dual, Ultra-Wideband, Current-Feedback Operational Amplifier with Disable
差分输入压控增益放大器
VCA821ID
Wideband, > 40dB Adjust Range, Linear in dB Variable Gain Amplifier
全差分放大器
LMH6552MA/NOPB
1.5 GHz Fully Differential Amplifier
电压反馈
OPA842IDR
Wideband, Low Distortion, Unity Gain Stable, Voltage Feedback Operational Amplifier
5V 电压反馈
OPA2356AIDR
2.5V, 200MHz GBW, CMOS Dual Op Amp
精密ADC/DAC
Delta-Sigma
ADS1118IDGSR
16-Bit ADC with Integrated MUX, PGA, Temperature Sensor, Oscillator, and Reference
Multiplying DAC, R-2R
DAC7811IDGSR
12-Bit, Serial Input, Multiplying Digital to Analog Converter
R-String DAC
DAC8571IDGKR
Low-Power Rail-To-Rail Output 16-Bit I2C Input DAC
3V 参考源
REF3330AIDBZR
30ppm/C Drift, 3.9uA, SOT23-3, SC70-3 Voltage Reference
精密放大器
5V CMOS 仪表放大器
INA333AIDGKR
Low Power, Precision Instrumentation Amplifier
36V 仪表放大器
INA826AID
Precision, 200-μA Supply Current, 36-V Supply Instrumentation Amplifier
36V 精密放大器
OPA192IDR
High Voltage, Rail-to-Rail Input/Output,Precision Op Amps,GBW = 10MHz
5V CMOS 放大器
OPA2320AIDGKR
Precision, 20MHz, 0.9pA Ib, RRIO, CMOS Operational Amplifier
5V CMOS 放大器
OPA2330AIDR
1.8V, 35µA, microPower, Precision, Zero Drift CMOS Op Amp
5V CMOS 放大器
OPA2376AIDR
Precision, Low Noise, Low Quiescent Current Operational Amplifier
音频功放
D类25W功放
TPA3112D1PWPR
25-W Filter-Free Mono Class-D Audio Amplifier with SpeakerGuard? (TPA3112)
其他
高速比较器
TLV3501AIDR
4.5ns Rail-to-Rail, High Speed Comparator in Microsized Packages
1bit 数字缓冲器
SN74AUP1G07DBVR
Low-Power Single Buffer/Driver with Open-Drain Outputs
5V 2选一模拟开关
TS5A3159DBVR
1-Ohm SPDT Analog Switch
5V 单通道模拟开关
TS5A3166DBVR
12V 单通道模拟开关
TS12A4515DR
此帖出自电子竞赛论坛
不晓得啊 ,烦死了   详情 回复 发表于 2014-8-9 14:12
34
自己顶一下求大神帮忙解决。谢谢大家
此帖出自电子竞赛论坛
34
大家来讨论一下好么?
此帖出自电子竞赛论坛
就这么多吗?这个在哪找到的?
此帖出自电子竞赛论坛
不应该是这个吗http://www.deyisupport.com/unive ... sts/516.2014ti.aspx
此帖出自电子竞赛论坛
在官网上下载的,老师给的。  详情 回复 发表于 2014-8-6 10:06
34
crooser 发表于 2014-8-5 22:12
不应该是这个吗http://www.deyisupport.com/universityprogram/w/contests/516.2014ti.aspx
在官网上下载的,老师给的。
此帖出自电子竞赛论坛
81
你传的是TI推荐的器件,不是比赛必须的
此帖出自电子竞赛论坛
比赛必须的有哪些,求指导。。  详情 回复 发表于 2014-8-6 18:34
34
sw3926 发表于 2014-8-6 10:24
你传的是TI推荐的器件,不是比赛必须的
比赛必须的有哪些,求指导。。
此帖出自电子竞赛论坛
609
可能有个射频程控放大器
此帖出自电子竞赛论坛
环绕立体声这个算在D类高功率音频么?  详情 回复 发表于 2014-8-7 08:49
个人签名我在翠绿的稻田中
凝视远方落下的太阳
609
还有 音频功放题目 D类功放 ,估计要高效率的
此帖出自电子竞赛论坛
个人签名我在翠绿的稻田中
凝视远方落下的太阳
609
还有可能是低功耗低电源电压的放大器
此帖出自电子竞赛论坛
个人签名我在翠绿的稻田中
凝视远方落下的太阳
34
longhaozheng 发表于 2014-8-6 19:17
可能有个射频程控放大器
环绕立体声这个算在D类高功率音频么?
此帖出自电子竞赛论坛
可以算吧  详情 回复 发表于 2014-8-9 10:29
34
云弋sky 发表于 2014-8-7 08:49
环绕立体声这个算在D类高功率音频么?
可以算吧
此帖出自电子竞赛论坛
48
环绕立体声这个算在D类高功率音频么?
不晓得啊 ,烦死了
此帖出自电子竞赛论坛
