3232|5
336
参与HELPER2416开发板助学计划----u-boot命令行模式体验 [复制链接]
板子重启后,三秒钟内在串口0上面随意输入字符,然后输入help命令看到如下结果
Helper2416 # help
?       - alias for 'help'
autoscr - run script from memory
base         - print or set address offset
bdinfo  - print Board Info structure
boot    - boot default, i.e., run 'bootcmd'
bootd   - boot default, i.e., run 'bootcmd'
bootelf - Boot from an ELF image in memory
bootm   - boot application image from memory
bootp        - boot image via network using BootP/TFTP protocol
bootvx  - Boot vxWorks from an ELF image
cmp         - memory compare
coninfo - print console devices and information
cp         - memory copy
crc32         - checksum calculation
date    - get/set/reset date & time
dcache  - enable or disable data cache
dhcp        - invoke DHCP client to obtain IP/boot params
dnw     - initialize USB device and ready to receive for Windows server (specific)
echo    - echo args to console
erase   - erase FLASH memory
exit    - exit script
ext2load- load binary file from a Ext2 filesystem
ext2ls  - list files in a directory (default /)
fatinfo - print information about filesystem
fatload - load binary file from a dos filesystem
fatls   - list files in a directory (default /)
flinfo  - print FLASH memory information
go      - start application at address 'addr'
help    - print online help
icache  - enable or disable instruction cache
iminfo  - print header information for application image
imls    - list all images found in flash
imxtract- extract a part of a multi-image
insnand - install SD/MMC bootloader image to NAND flash
itest        - return true/false on integer compare
loadb   - load binary file over serial line (kermit mode)
loads   - load S-Record file over serial line
loady   - load binary file over serial line (ymodem mode)
loop         - infinite loop on address range
md         - memory display
mm         - memory modify (auto-incrementing)
mmcinit - init mmc card
movi        - moviNAND sub-system
mtest         - simple RAM test
mw         - memory write (fill)
nand    - NAND sub-system
nboot   - boot from NAND device
nfs        - boot image via network using NFS protocol
nm         - memory modify (constant address)
ping        - send ICMP ECHO_REQUEST to network host
printenv- print environment variables
protect - enable or disable FLASH write protection
rarpboot- boot image via network using RARP/TFTP protocol
reset   - Perform RESET of the CPU
reginfo - print register information
run     - run commands in an environment variable
saveenv - save environment variables to persistent storage
setenv  - set environment variables
sleep   - delay execution for some time
test    - minimal test like /bin/sh
tftpboot- boot image via network using TFTP protocol
version - print monitor version
Helper2416 #
显示uboot版本
输入 最后一个命令 version,
Helper2416 # version
U-Boot 1.3.4 (Mar  4 2014 - 16:19:04) for SMDK2416
Helper2416 #
输入help nand命令后,出现以下信息:
Helper2416 # help nand
nand info             - show available NAND devices
nand device [dev]     - show or set current device
nand read[.jffs2]     - addr off|partition size
nand write[.jffs2]    - addr off|partiton size - read/write `size' bytes starting
    at offset `off' to/from memory address `addr'
nand write[.yaffs[1]] - addr off|partition size - write `size' byte yaffs image
    starting at offset `off' from memory address `addr' (.yaffs1 for 512+16 NAND)
nand erase [clean] [off size] - erase `size' bytes from
    offset `off' (entire device if not specified)
nand bad - show bad blocks
nand dump[.oob] off - dump page
nand scrub - really clean NAND erasing bad blocks (UNSAFE)
nand markbad off - mark bad block at offset (UNSAFE)
nand biterr off - make a bit error at offset (UNSAFE)
nand lock [tight] [status] - bring nand to lock state or display locked pages
nand unlock [offset] [size] - unlock section
nand info信息如下:
Helper2416 # nand info
Device 0: NAND 256MiB 3,3V 8-bit, sector size 128 KiB
nand bad 信息如下:
Helper2416 # nand bad
Device 0 bad blocks:
  0f480000
说明0f480000是坏块。
uboot命令解析见附件 uboot.pdf (1.34 MB, 下载次数: 7)
help命令也是一种分享,很多人刚接触UBOOT,有可能不知道这个   详情 回复 发表于 2014-8-3 09:21
点赞 关注(1)
个人签名每一刻都是崭新的,加油!
165
这是分享help这个命令?
个人签名好好学习,天天向上
181
谢谢分享
554
霹雳之火 发表于 2014-8-2 20:55
这是分享help这个命令?
个人签名My dreams will go on...
http://www.jyxtec.com
336
这是分享help这个命令?
是分享uboot的一些命令操作
个人签名每一刻都是崭新的,加油!
336
个人签名每一刻都是崭新的,加油!
