4050|3
101
在430F5529官方例程上面遇见一个问题 [复制链接]
//   MSP430F552x Demo - USCI_A0, SPI 3-Wire Master Incremented Data
//   Description: SPI master talks to SPI slave using 3-wire mode. Incrementing
//   data is sent by the master starting at 0x01. Received data is expected to
//   be same as the previous transmission.  USCI RX ISR is used to handle
//   communication with the CPU, normally in LPM0. If high, P1.0 indicates
//   valid data reception.  Because all execution after LPM0 is in ISRs,
//   initialization waits for DCO to stabilize against ACLK.
//   ACLK = ~32.768kHz, MCLK = SMCLK = DCO ~ 1048kHz.  BRCLK = SMCLK/2
//   Use with SPI Slave Data Echo code example.  If slave is in debug mode, P1.1
//   slave reset signal conflicts with slave's JTAG; to work around, use IAR's
//   "Release JTAG on Go" on slave device.  If breakpoints are set in
//   slave RX ISR, master must stopped also to avoid overrunning slave
//   RXBUF.
//                   MSP430F552x
//              --|RST          P1.0|-> LED
//                |             P3.4|-> Data Out (UCA0SIMO)
//                |             P3.5|<- Data In (UCA0SOMI)
//  Slave reset <-|P1.1         P3.0|-> Serial Clock Out (UCA0CLK)
//   Bhargavi Nisarga
//   Texas Instruments Inc.
//   April 2009
//   Built with CCSv4 and IAR Embedded Workbench Version: 4.21
#include
unsigned char MST_Data,SLV_Data;
unsigned char temp;
int main(void)
  volatile unsigned int i;
  WDTCTL = WDTPW+WDTHOLD;                   // Stop watchdog timer
  P1OUT |= 0x02;                            // Set P1.0 for LED
                                            // Set P1.1 for slave reset
  P1DIR |= 0x03;                            // Set P1.0-2 to output direction
  P3SEL |= BIT3+BIT4;                       // P3.3,4 option select
  P2SEL |= BIT7;                            // P2.7 option select
  UCA0CTL1 |= UCSWRST;                      // **Put state machine in reset**
  UCA0CTL0 |= UCMST+UCSYNC+UCCKPL+UCMSB;    // 3-pin, 8-bit SPI master
                                            // Clock polarity high, MSB
  UCA0CTL1 |= UCSSEL_2;                     // SMCLK
  UCA0BR0 = 0x02;                           // /2
  UCA0BR1 = 0;                              //
  UCA0MCTL = 0;                             // No modulation
  UCA0CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
  UCA0IE |= UCRXIE;                         // Enable USCI_A0 RX interrupt
  P1OUT &= ~0x02;                           // Now with SPI signals initialized,
  P1OUT |= 0x02;                            // reset slave
  for(i=50;i>0;i--);                        // Wait for slave to initialize
  MST_Data = 0x01;                          // Initialize data values
  SLV_Data = 0x00;                          //
  while (!(UCA0IFG&UCTXIFG));               // USCI_A0 TX buffer ready?
  UCA0TXBUF = MST_Data;                     // Transmit first character
  __bis_SR_register(LPM0_bits + GIE);       // CPU off, enable interrupts
#pragma vector=USCI_A0_VECTOR
__interrupt void USCI_A0_ISR(void)
  switch(__even_in_range(UCA0IV,4))
    case 0: break;                          // Vector 0 - no interrupt
    case 2:                                 // Vector 2 - RXIFG
      if (UCA0RXBUF==SLV_Data)              // Test for correct character RX'd
        P1OUT |= 0x01;                      // If correct, light LED
      else
        P1OUT &= ~0x01;                     // If incorrect, clear LED
      MST_Data++;                           // Increment data
      SLV_Data++;
      UCA0TXBUF = MST_Data;                 // Send next value
      for(i = 20; i>0; i--);                // Add time between transmissions to
                                            // make sure slave can process information
      break;
    case 4: break;                          // Vector 4 - TXIFG
    default: break;
[attach]162732[/attach] 什么叫没有定义?不明白你的意思。   详情 回复 发表于 2014-8-1 21:02
101
他定义的
我觉得有问题,首先就是他给的解析图上面没有P1.2,2.7,3.3,还有就是P3.0口它根本没有定义。
还有一个问题就是我想问一下,while(!(P2IN&0x80));  ,这个在有些SPI模式中用到,请问他是外部其他单片机和430通信吗?
2776
413
是的。外部输入引脚判断
2776
413
什么叫没有定义?不明白你的意思。
TI 处理器AM62L深度讲解,报名直播赢【双肩包、充电器、胶囊伞】
【直播要点】• 如何实现安全节能设计;• 开箱体验和demo;• 软件和硬件
【直播时间】3月21日(周五)上午10:00
