2145|1
有不知道求大神解释 [复制链接]
#include "msp430g2553.h"
const unsigned int spwm[] = {
250, 327, 396, 452, 487, 499, 487, 452, 396, 327,
250, 172, 103, 47, 12, 3, 12, 47, 103, 172,
unsigned int n=0;
void TimerA_PWM()//产生PWM波
P1DIR |= BIT2;
P1SEL |= BIT2;                            // p1.2
TACCR0 =500;                              // Init TACCR0 w/ sample prd=CCR0+1
  TACCTL1=OUTMOD_7;
  TACCR1= spwm[n];             // set/reset模式
  //TACCTL2=OUTMOD_7;只有置位
  TACCTL0 = CCIE;
TACTL = TACLR + MC_1 + TASSEL_1 +ID_0;                // clear TAR, up mode*/
void ini_s(void)//buzhidao
   WDTCTL=WDTPW+WDTHOLD;  //STOPW DT
   if (CALBC1_8MHZ ==0xFF || CALDCO_8MHZ == 0xFF)
            while(1); // If calibration constants erased
            // do not load, trap CPU!!
            //1Mhz  ~1008000
           BCSCTL1 = CALBC1_16MHZ;                    // Set range
           DCOCTL = CALDCO_16MHZ;                     // Set DCO step + modulation */
           _NOP();
void main()
   ini_s();
   TimerA_PWM();
   _EINT();
//_BIS_SR(LPM0_bits + GIE);
   while(1);
#pragma vector=TIMER0_A0_VECTOR
__interrupt void TimerA(void)
TACCR1 = spwm[n++];
if(n==20)
   n=0;
此帖出自编程基础论坛
我不是大神,问题是你想让大神解释什么,问都没问明白  详情 回复 发表于 2014-7-15 16:14
1801
此帖出自编程基础论坛
