2148|3
pwm的三路输出 [复制链接]
名称:3路输出的pwm波
参数:
端口:
说明:三路输出.选择p4.1-TB1,P4.2-TB2,P4.3-TB3
#include
void clk_init(void)
  volatile unsigned int i;
  BCSCTL1 |= XTS;                           // ACLK = LFXT1 = HF XTAL打开XT振荡器      (XTS:选择LFXT1工作在低频晶体模式(XTS=0)还是高频晶体模式(XTS=1))
  BCSCTL2 |= SELM_2+SELS;                   // SELM_2:选MCLK的时钟源选择为XT2,SELS:选SMCLK为XT2;8m
  do
  IFG1 &= ~OFIFG;                           // Clear OSCFault flag:清除振荡错误标志
  for (i = 0xFF; i > 0; i--);               // Time for flag to set
  while ((IFG1 & OFIFG));                   // OSCFault flag still set?:如果标志为1,则继续循环等待
  IFG1&=~OFIFG;
void pwm_init(void)
  P4DIR |= 0x0e;                           // P4.1 and P4.2 and P4.3 output
  P4SEL |= 0x0e;                           // P4.2 and P4.2 TB1/2 otions
  TBCCR0 = 800;                            //PWM信号频率10KHZ
  TBCCTL1 = OUTMOD_7;                                     // CCR1 reset/set
  TBCCR1 = 400;                            // 占空比为50%
  TBCCTL2 = OUTMOD_7;                                     // CCR2 reset/set
  TBCCR2 = 400;                            // 占空比为50%
  TBCCTL3 = OUTMOD_7;                                     // CCR3 reset/set
  TBCCR3 = 400;                            // 占空比为50%
  TBCTL = TBSSEL_1 + MC_1;                 // ACLK, up mode // 时钟源:ACLK// up mode:定时器重复从0计数到TAxCCR0
  _BIS_SR(CPUOFF);                          // Enter LPM0
int main(void)
         WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
         clk_init();
         pwm_init();
         while(1);
这是我写的msp430f149三路输出,用的time—b。编译通过了,但是不知道对不对,大神可以帮我看一下吗。
还有“TBCTL = TBSSEL_1 + MC_1;”选择aclk和选择mclk有什么区别吗?之前时钟源都选的XT2。有点混乱啊
#include "msp430.h" typedef unsigned char uchar; typedef unsigned int  uint; uchar flag; uchar table[]={0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,\ 21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,\ 44,45,46,47,48,49,50,49,48,47,46,45,44,43,42,41,40,39,38,37,36,35,34,\ 33,32,31,30,29,28,27,26,25,24,23,22,21,20,19,18,17,16,15,14,13,12,11,\ 10,9,8,7,6,5,4,3,2,1,0};//呼吸的效果 void main(void) {   uchar i;   WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT      BCSCTL1 &= ~XT2OFF;                       //打开xt2晶振   do   {    IFG1 &= ~OFIFG;    for(i = 0xff; i > 0; i--);   }   while((IFG1 & OFIFG));                    //等待起振,消除晶体失败标志      BCSCTL2 |= SELM_2 + SELS;                 //mclk.smclk选择高频晶振   TACTL |= TASSEL_2 + ID_3 + MC_1;          //计数时钟选测smclk,8分频,增计数模式 1mhz //TBCTL |= TBSSEL_2 + ID_3+ MC_1 ;   TBCTL|= TBSSEL_2 + TBCLGRP_0 + ID_3 + MC_1 ;      P4SEL|=BIT2;   P4DIR|=BIT2;       TBCCR0 = 50;                             // 50us de 周期   TBCCTL1 = OUTMOD_3+CLLD_0; //  TBCCTL1 &= ~CAP;   TACCR0 =5000;   TACCTL0 = CCIE;                         // 开中断使能       _EINT();                                 // Enter LPM0 w/ interrupt //  LPM0;                                    //低功耗    while(1);                                 //应该不会进入此句 } #pragma  vector  = TIMERA0_VECTOR __interrupt void timeA() { static uchar  i = 0; flag++;   P2DIR = 0XFF;   P2OUT = 0XFF; if(flag == 4)                             //大概20 ms时 较为理想 {       flag = 0;    TBCCR1 = table[i++];    if(i > 100)    { i = 0;         P2DIR = 0XFF;      P2OUT = 0X00;    }     } }你看看我写的, 不过不行啊, 而且哦找不到问题  详情 回复 发表于 2015-3-28 13:11
928
对不对要下载到板子上验证一下呀,上半段的缩进格式不好,看得有点累。
你这个有用吗
#include "msp430.h"
uchar flag;
void main(void)
  uchar i;
  do
   IFG1 &= ~OFIFG;
  P4SEL|=BIT2;
  P4DIR|=BIT2;
//  TBCCTL1 &= ~CAP;
  TACCR0 =5000;
//  LPM0;                                    //低功耗
static uchar  i = 0;
flag++;
  P2DIR = 0XFF;
  P2OUT = 0XFF;
   flag = 0;
   if(i > 100)
   { i = 0;
     P2DIR = 0XFF;
     P2OUT = 0X00;
快来报名!
