3319|0
22
LCD_CtrlLinesConfig [复制链接]
  1. void LCD_CtrlLinesConfig(void)
  2. {
  3.   GPIO_InitTypeDef GPIO_InitStructure;
  4.   /* Enable FSMC, GPIOD, GPIOE, GPIOF, GPIOG and AFIO clocks */
  5.   RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC, ENABLE);
  6.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE |
  7.                          RCC_APB2Periph_GPIOF | RCC_APB2Periph_GPIOG |
  8.                          RCC_APB2Periph_AFIO, ENABLE);
  9.   /* Set PD.00(D2), PD.01(D3), PD.04(NOE), PD.05(NWE), PD.08(D13), PD.09(D14),
  10.      PD.10(D15), PD.14(D0), PD.15(D1) as alternate
  11.      function push pull */
  12.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_4 | GPIO_Pin_5 |
  13.                                 GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_14 |
  14.                                 GPIO_Pin_15;
  15.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  16.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  17.   GPIO_Init(GPIOD, &GPIO_InitStructure);
  18.   /* Set PE.07(D4), PE.08(D5), PE.09(D6), PE.10(D7), PE.11(D8), PE.12(D9), PE.13(D10),
  19.      PE.14(D11), PE.15(D12) as alternate function push pull */
  20.   GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 |
  21.                                 GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 |
  22.                                 GPIO_Pin_15;
  23.   GPIO_Init(GPIOE, &GPIO_InitStructure);
  24.   /* Set PF.00(A0 (RS)) as alternate function push pull */
  25.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
  26.   GPIO_Init(GPIOF, &GPIO_InitStructure);
  27.   /* Set PG.12(NE4 (LCD/CS)) as alternate function push pull - CE3(LCD /CS) */
  28.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
  29.   GPIO_Init(GPIOG, &GPIO_InitStructure);
  30.
  31.   /* LEDs pins configuration */
  32.   /* Set PD7 to disable NAND */
  33. }
复制代码
此帖出自ARM技术论坛
