3343|1
Energia msp430f5529 Timer 程序 编译通过,没有进入中断 [复制链接]
#include "Energia.h"
volatile int state=HIGH;
void setup()
  // put your setup code here, to run once:
   pinMode( RED_LED ,OUTPUT); //  set P1_0 output
   TA1CTL = TASSEL_1+TACLR+ MC_2+TAIE;
void loop()
  // put your main code here, to run repeatedly:
  digitalWrite( RED_LED, state);   //ser P4_1 high
// Timer interrupt service routine
__attribute__((interrupt(TIMER1_A0_VECTOR)))
void Timer_A_int(void)
  digitalWrite( RED_LED, LOW);   //ser P4_1 high
开总中断(GIE)试试  详情 回复 发表于 2014-6-23 08:07
开总中断(GIE)试试
