下面的是程序,可以直接运行,里面Vde_counter没办法正常输出,我也弄不明白为啥,控制它的波形都对
//* COMPANY : TERASIC. www.terasic.com (c) 2005 all rights reserved. *
//* NAME : ITU-R BT.656 YCrCb 4:2:2 DECODER *
//* Created : 7/5/2005 *
//* Author : Joe Yang *
`define sync 8'd101
module deinterlace
CLOCK, //system clock
TD_D, //4:2:2 video data stream
TD_HS, //Decoder_hs
TD_VS, //Decoder_vs
//SW1, //the function of SW1 is not sure!!
Y, //4:4:4 Y
Cb, //4:4:4 Cb
Cr, //4:4:4 Cr
////test/////
YY,
CCb,
CCr,
vde,
h_tr,
blank_h,
Vde_counter,
HSx2
//blank
//Ypix_clock, //Y pixel clock
//VSx1,
//Y_check,
//START,
//COUNTER,
//R,G,B,
//h_tr,
//SW0,
input CLOCK;
input [7:0]TD_D;
input TD_HS;
input TD_VS;
//input SW0; //key1,key0
//input SW1;
output [7:0]Y;
output [7:0]Cb;
output [7:0]Cr;
///////test///////
output [7:0]YY;
output [7:0]CCb;
output [7:0]CCr;
output blank_h;
output vde;
output h_tr;
output HSx2;
output [10:0]Vde_counter;
//output blank;
//test
//output VSx1;
//output Ypix_clock;
//output Y_check;
//output START;
//output [1:0]COUNTER;
//output [9:0]R;
//output [9:0]G;
//output [9:0]B;
//output h_tr;
reg [7:0]YY;
reg [7:0]CCb,Cbb;
reg [7:0]CCr,Crr;
reg HSx2 ;//TD_HS;
//wire VSx1=TD_VS;
reg[7:0]R1,R2,R3;
reg[7:0]RR1,RR2,RR3;
//wire [7:0]cr={2'b0,Cr[6:1]};
//wire [7:0]cb={3'b0,Cb[6:2]};
//wire [7:0]Rr=(Y-16)-{1'b0,Cr[7:0]};//
//wire [7:0]Gg=(Y-16)-cr -cb;
//wire [7:0]Bb=(Y-16)-{1'b0,Cb[7:0]};//
// wire [9:0]R={Rr,2'b00};
// wire [9:0]G={Gg,2'b00};
// wire [9:0]B={Bb,2'b00};
wire Y_check=( (R3==8'hff) && (R2==8'h00) && (R1==8'h00) )?1:0;
always @(posedge CLOCK)
begin
RR1=TD_D;
RR2=R1;
RR3=R2;
end
always @(negedge CLOCK)
begin
R1=RR1;
R2=RR2;
R3=RR3;
end
reg START,Field;
begin
if (Y_check==1) //ff,00,00前导
begin
START=~TD_D[4];//开始信号 0-start 1--end
Field= TD_D[6];//场信号 1--odd 0--even
end
end
reg [1:0]COUNTER;
begin
if (!START) //START=1, XY[4]=0, 表示sav信号
COUNTER=0;
else COUNTER=COUNTER+2'b1;
end
reg Ypix_clock; // 频率为clock的一半
begin
case (COUNTER)
0:begin Cbb = TD_D; Ypix_clock =0;end
1:begin YY = TD_D;CCr=Crr;CCb=Cbb; Ypix_clock =1;end
2:begin Crr = TD_D; Ypix_clock =0;end
3:begin YY = TD_D;CCr=Crr;CCb=Cbb; Ypix_clock =1;end
endcase
end
reg [10:0]H_COUNTER;
reg [10:0]RH_COUNTER;
hs-----_______________________--------
vs-----_______________________________________
begin
if (TD_HS) H_COUNTER=0; //低电平计数
else H_COUNTER=H_COUNTER+11'b1;// TD_HS effective in low
end
always @(posedge TD_HS)// 由低电平变成高电平时 赋值
begin
RH_COUNTER=H_COUNTER;// RH_COUNTER是H_COUNTER最大时,锁存
end
always @(posedge CLOCK) //101??
begin
if (
((H_COUNTER >= 0) && (H_COUNTER < `sync)) ||
((H_COUNTER >= RH_COUNTER[10:1]) && (H_COUNTER < (RH_COUNTER[10:1]+`sync+1)))
// 0=
HSx2=0;//???
else
HSx2=1;
end
reg [10:0]h;
reg h_tr;
reg h_tr_h;
begin
if(!HSx2)
h=0;
else
h=h+11'b1;
end
begin
if ((h< 51) || (h > 771))
h_tr=0;
else
h_tr=1;
end
begin
if ((h< 41) || (h > 781))
h_tr_h=0;
else
h_tr_h=1;
end
wire [7:0]Yw;//YYw;
wire [7:0]Cwr;//CCwr;
wire [7:0]Cwb;//CCwb;
//assign YYw =((h_tr==1) && (VSx1==1))?Yw : 8'h10;//current set
//assign CCwr =((h_tr==1) && (VSx1==1))?Cwr: 8'h80;
//assign CCwb =((h_tr==1) && (VSx1==1))?Cwb: 8'h80;
reg [10:0]pcounter_h;
reg [10:0]pcounter_v;
begin
if
(!h_tr) pcounter_h=0;
else
pcounter_h=pcounter_h+11'b1;
end
always @(posedge h_tr)
begin
if
(!TD_VS) pcounter_v=0;
else
pcounter_v=pcounter_v+11'b1;
end
//??? wire t
wire t=(
// ((pcounter_h >=0) && (pcounter_h < 45) && (pcounter_v[9:5]==5'b00000)) ||
((pcounter_h >=0) && (pcounter_h < 90) && (pcounter_v[9:5]==5'b00001)) ||
((pcounter_h >=0) && (pcounter_h < 135) && (pcounter_v[9:5]==5'b00010)) ||
((pcounter_h >=0) && (pcounter_h < 180) && (pcounter_v[9:5]==5'b00011)) ||
((pcounter_h >=0) && (pcounter_h < 225) && (pcounter_v[9:5]==5'b00100)) ||
((pcounter_h >=0) && (pcounter_h < 270) && (pcounter_v[9:5]==5'b00101)) ||
((pcounter_h >=0) && (pcounter_h < 315) && (pcounter_v[9:5]==5'b00110)) ||
//((pcounter_h >=0) && (pcounter_h < 360) && (pcounter_v[9:5]==5'b00111)) ||
((pcounter_h >=0) && (pcounter_h < 405) && (pcounter_v[9:5]==5'b01000)) ||
((pcounter_h >=0) && (pcounter_h < 450) && (pcounter_v[9:5]==5'b01001)) ||
((pcounter_h >=0) && (pcounter_h < 495) && (pcounter_v[9:5]==5'b01010)) ||
((pcounter_h >=0) && (pcounter_h < 540) && (pcounter_v[9:5]==5'b01011)) ||
((pcounter_h >=0) && (pcounter_h < 585) && (pcounter_v[9:5]==5'b01100)) ||
// ((pcounter_h >=0) && (pcounter_h < 630) && (pcounter_v[9:5]==5'b01101)) ||
((pcounter_h >=0) && (pcounter_h < 675) && (pcounter_v[9:5]==5'b01110)) ||
((pcounter_h >=0) && (pcounter_h < 720) && (pcounter_v[9:5]==5'b01111))
)?1:0;
wire [7:0]ym= t? 8'hff:8'h80;
wire [7:0]crm=t? 8'h80:8'h80;
wire [7:0]cbm=t? 8'h80:8'h80;
wire [7:0]Ymm =SW1? ym :Yw ;
wire [7:0]Crmm =SW1? crm:Cwr;
wire [7:0]Cbmm =SW1? cbm:Cwb;
wire [7:0]Ymm =Yw ;
wire [7:0]Crmm =Cwr;
wire [7:0]Cbmm =Cwb;
reg[10:0]Hde_counter;
reg[10:0]Vde_counter;
begin
if(HSx2==0)
Hde_counter=0;
else
Hde_counter=Hde_counter+11'b1;
end
always@(posedge HSx2)
begin
if (TD_VS==1) // effective low or high ?
Vde_counter=0;
else
Vde_counter=Vde_counter+11'b1;
end
//wire hde=((Hde_counter > 51) && (Hde_counter < 691)) ? 1:0;//720 640
wire vde=((Vde_counter > 31) && (Vde_counter < 511)) ? 1:0;//480
wire blank_h = h_tr & vde;
wire blank = h_tr_h & vde;
wire [7:0]Y = (blank_h)?Ymm :8'h10;
wire [7:0]Cr = (blank_h)?Crmm :8'h80;
wire [7:0]Cb = (blank_h)?Cbmm :8'h80;
dul_port_c1024 YYYR(
.iDATA(YY[7:0]),
.iHSYNC(TD_HS),
// .iHSYNCx2(HSx2),
.iHSYNCx2(blank),
.Y_CLOCK(Ypix_clock),
.Y_CLOCKx2(CLOCK),
.oDATA(Yw[7:0]),
.field(Field),
.VS(TD_VS)
dul_port_c1024 CBB(
.iDATA(CCb[7:0]),
.iHSYNC(TD_HS),
// .iHSYNCx2(HSx2),
.iHSYNCx2(blank),
.Y_CLOCKx2(CLOCK),
.oDATA(Cwb[7:0]),
.field(Field),
.VS(TD_VS)
dul_port_c1024 CRR(
.iDATA(CCr[7:0]),
.iHSYNC(TD_HS),
// .iHSYNCx2(HSx2),
.iHSYNCx2(blank),
.Y_CLOCKx2(CLOCK),
.oDATA(Cwr[7:0]),
.field(Field),
.VS(TD_VS)
endmodule
