4368|3
5310
453
恩智浦LPC1549@eeworld ( 五 ) 跑 I2C 例程读TMP275 [复制链接]
恩智浦LPC1549@eeworld ( 五 ) 跑 I2C [url=https://bbs.eeworld.com.cn/thread-438795-1-1.html]例程读TMP275[/url]
目的:
熟悉LPCOPEN库函数
I2C的操作读写
一、硬件连接:
1:温度传感器连接
TMP275-2 SCL  = LPC1549_P0.22
TMP275-1 SDA = LPC1549_P0.23
2:UART连接
LPC1549_P0.13( RXD)  = PL2303_RXD
LPC1549_P0.18( TXD)  = PL2303_RXD
二、初始化配置程序:
        /* 设置I2C引脚复用 */
        Init_I2C_PinMux();
        /* 配置I2C句柄,设置的I2C速率,并初始化I2C时钟 */
        setupI2CMaster();
        /* 禁用I2C中断  */
        NVIC_DisableIRQ(I2C0_IRQn);
/* 设置I2C引脚复用 */
static void Init_I2C_PinMux(void)
#if defined(BOARD_NXP_LPCXPRESSO_1549)
        Chip_IOCON_PinMuxSet(LPC_IOCON, 0, 22, IOCON_DIGMODE_EN | I2C_MODE);//SCL  TMP275-2 SCL
        Chip_IOCON_PinMuxSet(LPC_IOCON, 0, 23, IOCON_DIGMODE_EN | I2C_MODE);//SDA  TMP275-1 SDA
        Chip_SWM_EnableFixedPin(SWM_FIXED_I2C0_SCL);
        Chip_SWM_EnableFixedPin(SWM_FIXED_I2C0_SDA);
#else
#error "No I2C Pin Muxing defined for this example"
#endif
/* 设置I2C句柄和参数*/
static void setupI2CMaster()
        /* 使能I2C时钟和复位I2C外设 - 引导ROM不这样做 */
        Chip_I2C_Init(LPC_I2C0);
        /* 设置时钟速率为I2C*/
        Chip_I2C_SetClockDiv(LPC_I2C0, I2C_CLK_DIVIDER);
        /* 设置I2CM传输速率*/
        Chip_I2CM_SetBusSpeed(LPC_I2C0, I2C_BITRATE);
        /* 启用“主”模式*/
        Chip_I2CM_Enable(LPC_I2C0);
//指定读写
static void SetupXferRecAndExecute(uint8_t devAddr,
        uint8_t *txBuffPtr,
        uint16_t txSize,
        uint8_t *rxBuffPtr,
        uint16_t rxSize)
        /* Setup I2C transfer record */
        i2cmXferRec.slaveAddr = devAddr;
        i2cmXferRec.status = 0;
        i2cmXferRec.txSz = txSize;
        i2cmXferRec.rxSz = rxSize;
        i2cmXferRec.txBuff = txBuffPtr;
        i2cmXferRec.rxBuff = rxBuffPtr;
        //在主模式下发送和接收数据
        Chip_I2CM_XferBlocking(LPC_I2C0, &i2cmXferRec);
/* 主I2CM 轮询模式 接收 */
/* 函数读取的I2C  温度传感器和输出结果 */
static void ReadTemperatureI2CM(void)
        float temp=0.0;
        uint16_t itemp=0;
        uint8_t temperature[2];
        uint8_t lm75TempRegisterAddress = 0;
        /* 读温度传感器 */
                /* I2C总线地址 */
                I2C_TEMP_ADDR_7BIT,
                /* 发送一个字节,温度寄存器地址*/
                &lm75TempRegisterAddress, 1,
                /* 接收回来的两个字节中,温度寄存器的内容 */
                temperature, 2);
        //temp=(float)itemp*0.5;
        /* Test for valid operation */
        if (i2cmXferRec.status == I2CM_STATUS_OK) {
                /* Output temperature. */
                DEBUGOUT("Temperature = %d.%d degrees C.\r\n", //temp);
                  (int) temperature[0], (temperature[1] & 0x80) ? 5 : 0 );//LM75 9位有效
        else {
                DEBUGOUT("Error %d reading temperature.\r\n", i2cmXferRec.status );
#endif
三、UART输出结果
此帖出自NXP MCU论坛
学习了。请问ROM引导和不是ROM引导有什么区别?没有找到相关的说明,谢谢。  详情 回复 发表于 2014-6-15 19:33
点赞 关注(1)
116
不错
此帖出自NXP MCU论坛
616
很好。多出点,这个跟你学习。刚好我也收到一块板子
此帖出自NXP MCU论坛
58
此帖出自NXP MCU论坛
