1335|1
MSP430在设置DCO时钟时有一个公式 DCO = DELTA*(4096),这个是怎么来的,还有当定时器用作捕捉功能时如果TACCTL0的CCISx选GND,那么定时器捕捉的是哪个信号?
程序:
void Set_DCO (void)                         // Set DCO to selected frequency
#define DELTA 488                           // Target DCO = DELTA*(4096) = 2MHz
  unsigned int Compare, Oldcapture = 0;
  CCTL2 = CM_1 + CCIS_1 + CAP;              // CAP, ACLK
  TACTL = TASSEL_2 + MC_2 + TACLR;          // SMCLK, cont-mode, clear
  while (1)
    while (!(CCIFG & CCTL2));               // Wait until capture occured
    CCTL2 &= ~CCIFG;                        // Capture occured, clear flag
    Compare = CCR2;                         // Get current captured SMCLK
    Compare = Compare - Oldcapture;         // SMCLK difference
    Oldcapture = CCR2;                      // Save current captured SMCLK
    if (DELTA == Compare) break;            // If equal, leave "while(1)"
    else if (DELTA < Compare)
      DCOCTL--;
      if (DCOCTL == 0xFF)                   // DCO is too fast, slow it down
        if (!(BCSCTL1 == (XT2OFF + DIVA_3)))
        BCSCTL1--;                          // Did DCO role under?, Sel lower RSEL
    else
      DCOCTL++;                             // DCO is too slow, speed it down
      if (DCOCTL == 0x00)
        if (!(BCSCTL1 == (XT2OFF + DIVA_3 + 0x07)))
        BCSCTL1++;                          // Did DCO role over? Sel higher RSEL
  CCTL2 = 0;                                // Stop CCR2
  TACTL = 0;                                // Stop Timer_A
我也不是很懂~~~~  详情 回复 发表于 2014-5-26 16:24
1119
我也不是很懂~~~~
