1890|0
28
哪位能帮我看下这个程序 [复制链接]
这是网上找到别人的一个spwm波程序,他说是三相的,但好像也不是,我烧进lm3s811了,测了下没有三相,但有一路倒是spwm波,另一路是PWM波。。。我也找到了周立功的spwm波资料,才发现这两个程序很相近,但是出来的不是spwm波形,,,哪位高人能帮我看下啊
附上源代码
#include"systemInit.h"
#include"pwm.h"
#include"timer.h"
unsigned int n,t;
const unsigned long ulTab[360] = /* 一个周期的SIN函数表 */
{ 1400, 1424, 1447, 1471, 1494, 1518, 1541, 1565, 1588, 1611, 1634, 1658, 1681, 1704, 1727,
1749, 1772, 1795, 1817, 1840, 1862, 1884, 1906, 1927, 1949, 1971, 1992, 2013, 2034, 2054,
2075, 2095, 2115, 2135, 2155, 2174, 2194, 2212, 2231, 2250, 2268, 2286, 2303, 2321, 2338,
2355, 2371, 2387, 2403, 2419, 2434, 2449, 2464, 2478, 2492, 2506, 2519, 2532, 2545, 2557,
2569, 2581, 2592, 2603, 2613, 2624, 2633, 2643, 2652, 2660, 2669, 2676, 2684, 2691, 2698,
2704, 2710, 2715, 2720, 2725, 2729, 2733, 2737, 2740, 2743, 2745, 2747, 2748, 2749, 2750,
2750, 2750, 2749, 2748, 2747, 2745, 2743, 2740, 2737, 2733, 2729, 2725, 2720, 2715, 2710,
2704, 2698, 2691, 2684, 2676, 2669, 2660, 2652, 2643, 2633, 2624, 2613, 2603, 2592, 2581,
2569, 2557, 2545, 2532, 2519, 2506, 2492, 2478, 2464, 2449, 2434, 2419, 2403, 2387, 2371,
2355, 2338, 2321, 2303, 2286, 2268, 2250, 2231, 2212, 2194, 2174, 2155, 2135, 2115, 2095,
2075, 2054, 2034, 2013, 1992, 1971, 1949, 1927, 1906, 1884, 1862, 1840, 1817, 1795, 1772,
1749, 1727, 1704, 1681, 1658, 1634, 1611, 1588, 1565, 1541, 1518, 1494, 1471, 1447, 1424,
1400, 1376, 1353, 1329, 1306, 1282, 1259, 1235, 1212, 1189, 1166, 1142, 1119, 1096, 1073,
1051, 1028, 1005, 983, 960, 938, 916, 894, 873, 851, 829, 808, 787, 766, 746, 725, 705,
685, 665, 645, 626, 606, 588, 569, 550, 532, 514, 497, 479, 462, 445, 429, 413,397,381,
366,351, 336, 322, 308, 294, 281, 268, 255, 243, 231, 219, 208, 197, 187, 176, 167, 157,
148, 140, 131, 124, 116, 109, 102, 96, 90, 85, 80, 75, 71, 67, 63, 60, 57, 55, 53, 52, 51,
50, 50, 50, 51, 52, 53, 55, 57, 60, 63, 67, 71, 75, 80, 85, 90, 96, 102, 109, 116, 124,
131, 140, 148, 157, 167, 176, 187, 197, 208, 219, 231, 243, 255, 268, 281, 294, 308, 322,
336, 351, 366, 381, 397, 413, 429, 445, 462, 479, 497, 514, 532, 550, 569, 588, 606, 626,
645, 665, 685, 705, 725, 746, 766, 787, 808, 829, 851, 873, 894, 916, 938, 960, 983, 1005,
1028, 1051, 1073, 1096, 1119, 1142, 1166, 1189, 1212, 1235, 1259, 1282, 1306, 1329, 1353, 1376
void PWM_Init(void)
        SysCtlPWMClockSet(SYSCTL_PWMDIV_1);                                /* PWM时钟配置:不分频 */
        SysCtlPeriEnable(SYSCTL_PERIPH_PWM);                         /* 使能PWM外设 */
        SysCtlPeriEnable(SYSCTL_PERIPH_GPIOD);                         /* 使能PD口外设 */
        SysCtlPeriEnable(SYSCTL_PERIPH_GPIOB);                         /* 使能PB口外设 */
        SysCtlPeriEnable(SYSCTL_PERIPH_GPIOE);                        /* 使能PE口外设 */
        /* 设置PD0,PD1为PWM0和PWM1*/
        GPIOPinTypePWM(GPIO_PORTD_BASE, GPIO_PIN_0 | GPIO_PIN_1);
        /* 设置PB0,PB1为PWM2和PWM3 */
        GPIOPinTypePWM(GPIO_PORTB_BASE, GPIO_PIN_0 | GPIO_PIN_1);
        /* 设置PB0,PB1为PWM4和PWM5 */
        GPIOPinTypePWM(GPIO_PORTE_BASE, GPIO_PIN_0 | GPIO_PIN_1);
        PWMGenConfigure(PWM_BASE, PWM_GEN_0,                         /* 设置PWM发生器0为上下计数方式 */
        PWM_GEN_MODE_UP_DOWN |                                                         /* 上下计数方式 */
        PWM_GEN_MODE_SYNC |                                                         /* 两路PWM同步 */
        PWM_GEN_MODE_DBG_STOP);
        PWMGenConfigure(PWM_BASE, PWM_GEN_1,                        /* 设置PWM发生器1为上下计数方式 */
        PWMGenConfigure(PWM_BASE, PWM_GEN_2,                        /* 设置PWM发生器2为上下计数方式 */
        PWMGenPeriodSet(PWM_BASE, PWM_GEN_0, t); /* 设置PWM发生器0的频率17857Hz */
        PWMGenPeriodSet(PWM_BASE, PWM_GEN_1, t); /* 设置PWM发生器1的频率17857Hz */
        PWMGenPeriodSet(PWM_BASE, PWM_GEN_2, 6000);
        PWMPulseWidthSet(PWM_BASE, PWM_OUT_0, 2700);/* 设置PWM0脉冲宽度 */
        PWMPulseWidthSet(PWM_BASE, PWM_OUT_1, 2700);/* 设置PWM1脉冲宽度 */
        PWMPulseWidthSet(PWM_BASE, PWM_OUT_2, 2700);/* 设置PWM2脉冲宽度 */
        PWMPulseWidthSet(PWM_BASE, PWM_OUT_3, 2700);/* 设置PWM3脉冲宽度 */
        PWMPulseWidthSet(PWM_BASE, PWM_OUT_4, 2700);/* 设置PWM4脉冲宽度 */
        PWMPulseWidthSet(PWM_BASE, PWM_OUT_5, 2700);/* 设置PWM5脉冲宽度 */
        PWMOutputInvert(PWM_BASE, PWM_OUT_0_BIT |
        PWM_OUT_1_BIT, true);                                                 /* PWM0和PWM3反相输出 */
        PWMOutputInvert(PWM_BASE, PWM_OUT_2_BIT |
        PWM_OUT_3_BIT, true);
        PWMOutputInvert(PWM_BASE, PWM_OUT_4_BIT |
        PWM_OUT_5_BIT, true);
        PWMOutputState(PWM_BASE, PWM_OUT_0_BIT | PWM_OUT_1_BIT, true);
    PWMOutputState(PWM_BASE, PWM_OUT_2_BIT | PWM_OUT_3_BIT, true);
        PWMOutputState(PWM_BASE, PWM_OUT_4_BIT | PWM_OUT_5_BIT, true);
        PWMGenEnable(PWM_BASE, PWM_GEN_0);                         /* 使能PWM发生器0 */
        PWMGenEnable(PWM_BASE, PWM_GEN_1);                         /* 使能PWM发生器1 */
        PWMGenEnable(PWM_BASE, PWM_GEN_2);                         /* 使能PWM发生器2 */
        PWMSyncUpdate(PWM_BASE, PWM_GEN_0_BIT | PWM_GEN_1_BIT |
        PWM_GEN_2_BIT | PWM_GEN_3_BIT);                                /* 同步时间更新 */
        PWMSyncTimeBase(PWM_BASE, PWM_GEN_0_BIT | PWM_GEN_1_BIT |
        SysCtlDelay(10000000);
void TIMER_Init(void)
        SysCtlPeriEnable(SYSCTL_PERIPH_TIMER0);                         /* 使能定时器0外设 */
        TimerConfigure(TIMER0_BASE, TIMER_CFG_32_BIT_PER);        /* 设置定时器0为周期触发模式 */
        TimerLoadSet(TIMER0_BASE, TIMER_A, t);                                 /* 设置定时器装载值 */
        TimerIntEnable(TIMER0_BASE, TIMER_TIMA_TIMEOUT);        /* 设置定时器为溢出中断 */
        TimerEnable(TIMER0_BASE, TIMER_A);                                         /* 使能定时器0 */
int main(void)
        jtagWait();
//        clockInit();
        SysCtlLDOSet(SYSCTL_LDO_2_75V);
        SysCtlClockSet(SYSCTL_SYSDIV_4 |         /* PLL4分频,系统时钟50M */
        SYSCTL_USE_PLL |                                         /* 使用PLL */
        SYSCTL_OSC_MAIN |
        SYSCTL_XTAL_6MHZ);
        t=2800;                                        /* 配置6MHz外部晶振作为主时钟 */
        PWM_Init();                         /* 初始化PWM */
        TIMER_Init();                         /* 初始化TIMER */
        IntEnable(INT_TIMER0A); /* 使能Timer中断 */
        IntMasterEnable();                 /* 使能总中断 */
        while(1);
void Timer0A_ISR (void)
        TimerIntClear(TIMER0_BASE, TIMER_TIMA_TIMEOUT); /* 清除定时器0中断 */
//        PWMPulseWidthSet(PWM_BASE, PWM_OUT_0, ulTab[n]);
//        PWMPulseWidthSet(PWM_BASE, PWM_OUT_1, ulTab[n]);
//        PWMPulseWidthSet(PWM_BASE, PWM_OUT_2, ulTab[n]); /* 设置PWM2输出的周期 */
//        PWMPulseWidthSet(PWM_BASE, PWM_OUT_3, ulTab[n]); /* 设置PWM3输出的周期 */
        n++;
        if(n<=180)
                PWMOutputState(PWM_BASE, PWM_OUT_1_BIT, false);
                PWMOutputState(PWM_BASE, PWM_OUT_0_BIT, true);
                PWMPulseWidthSet(PWM_BASE, PWM_OUT_0, ulTab[n]); // 设置PWM0输出的周期
         else
                PWMOutputState(PWM_BASE,PWM_OUT_0_BIT, false);
                PWMOutputState(PWM_BASE,PWM_OUT_1_BIT, true);
                PWMPulseWidthSet(PWM_BASE, PWM_OUT_1, ulTab[n]); // 设置PWM1输出的周期
        if(n==360)
                n = 0; /* 重复SPWM输出 */
        /* 同步时间更新 */
        PWMSyncTimeBase(PWM_BASE, PWM_GEN_0_BIT | PWM_GEN_1_BIT|
SPWM逆变电源应用,基于LM3S811的程序.rar
88.28 KB, 下载次数: 0
LM3SAPP_SPWM_Contravarlant_Power基于SPWM技术的逆变电源.pdf
405.83 KB, 下载次数: 0
