1716|1
LMH6629有句话不理解,求助 [复制链接]
The LMH6629 operates on 2.7 to 5.5V supply with an
input common mode range that extends below
ground and outputs that swing to within 0.8V of the
rails for ease of use in single supply applications
这句话什么意思啊,求教
此帖出自PCB设计论坛
LMH6629工作在2.7V至5.5V电源供电,输入共模范围可低于地和输出范围0.8V内使用, 单电源使用。   详情 回复 发表于 2014-5-21 11:34
340
单电源使用。
此帖出自PCB设计论坛
