9792|4
26
编译时出现错误,求解答 [复制链接]
1.
Description Resource Path Location Type
#10099-D program will not fit into available memory. placement with alignment/blocking fails for section ".cinit" size 0x81 page 0. Available memory ranges: PinWork C/C++ Problem
2.
unresolved symbol _I2C_enableSlave, first referenced in ./scr/i2c.obj PinWork C/C++ Problem
1、存储器分配有问题 2、 _I2C_enableSlave没有定义  详情 回复 发表于 2014-5-19 12:09
输入有问题没
和输入法还有关系吗?  详情 回复 发表于 2014-5-18 15:23
输入法,,,,
26
和输入法还有关系吗?
裸片初长成(高级)
1、存储器分配有问题
