2099|0
裸片初长成(高级)
ADI的开关电源芯片 ----- ADP2311 [复制链接]
      ADP2311为双路1A、18V同步降压型开关电源芯片。
输入电压范围从4.5 V到 18 V,,最低输出电压可以低至0.6V
每一通道可以连续输出1A电流。
      ADP2311内部集成了高端及低端 MOSFETs ,可提供很高的效率,
两通道工作180°相位的交错方式,可以非常有效地减小波纹、输入电容体积。减EMI
特点和优势
  • Input voltage: 4.5 V to 18 V
  • ±1.0% output accuracy
  • Integrated MOSFET:
    110 mΩ/ 60 mΩ typical
  • Continuous output current:
    1 A/ 1 A
  • Power fail comparator generates warning
  • Power-on reset with programmable delay timer
  • Adjustable voltage monitor for power down (channel 2)
  • Watchdog refresh input
  • Dual phase with 180° out of phase operation
  • Fixed switching frequency:
    300 kHz
  • Internal compensation and soft start
  • See data sheet for additional features
