7650|5
29
在proteus中LCD1602出现乱码是怎么一回事 [复制链接]
#include
#define uchar unsigned char
#define uint unsigned int
#define NORMAL_MODE 0
#define HOUR_SET 1
#define MINTUE_SET 2
#define SECOND_SET 3
sbit lcden=P3^4;
sbit lcdrs=P3^5;
sbit KEY_HOUR_UP=P2^0;
sbit KEY_HOUR_DN=P2^1;
sbit KEY_MIN_UP=P2^2;
sbit KEY_MIN_DN=P2^3;
sbit KEY_SEC_UP=P2^4;
sbit KEY_SEC_DN=P2^5;
uchar hour,min,sec,num,count;
uchar code table[]="Time";
//uchar code table1[]="12:00:00";                   //默认显示状态
//void  write_date(uchar date);
void init();
void keycontrol();
void delayms(uint xms) //延时函数
  uint i,j;
  for(i=xms;i>0;i--)
     for(j=110;j>0;j--);
void write_com(uchar com)        //液晶写命令函数
     lcdrs=0;
     lcden=0;
     P0=com;
     delayms(5);
     lcden=1;
     delayms(5);
     lcden=0;
void write_date(uchar date)  //液晶写数据函数
    lcdrs=1;
    lcden=0;
    P0=date;
    delayms(5);
    lcden=1;
    delayms(5);
    lcden=0;
void write_sfm(uchar add,uchar date)           //写时分秒函数
    uchar shi,ge;
        shi=date/10;
        ge=date%10;
        write_com(0x80+0x40+add);                           //设置显示位置
        write_date(0x30+shi);
        write_date(0x30+ge);
void keycontrol()
        if(KEY_HOUR_UP==0)
                  hour++;
                  if(hour==24)
                          hour=0;
                  while(!KEY_HOUR_UP);
                   write_sfm(5,hour);
        if(KEY_HOUR_DN==0)
                   hour--;
                  if(hour==0)
                    hour=23;
                   while(!KEY_HOUR_DN);
                   write_sfm(5,hour);
                if(KEY_MIN_UP==0)
                   min++;
                   if(min==60)
                             min=0;
                   while(!KEY_MIN_UP);
                   write_sfm(8,min);
            if(KEY_MIN_DN==0)
                    min--;
                    if(min==0)
                    min=59;
                        while(!KEY_MIN_DN);
                        write_sfm(8,min);
            if(KEY_SEC_UP==0)
                    sec++;
                        if(sec==60)
                        sec=0;
                        while(!KEY_SEC_UP);
                     write_sfm(11,sec);
             if(KEY_SEC_DN==0)
                    sec--;
                        if(sec==0)
                        sec=59;
                        while(!KEY_SEC_DN);
                        write_sfm(11,sec);
void init()           //初始化函数
    hour=12;
        min=0;
        sec=0;
        lcden=0;
        write_com(0x38);
    write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
        write_com(0x80+0x40+7);
        write_date(':');
        delayms(5);
        write_com(0x80+0x40+10);
        write_date(':');
        delayms(5);
        TMOD=0X11;
        TH0=(65536-45872)/256;
        TL0=(65536-45872)%256;
        EA=1;
        ET0=1;
        TR0=1;
void main()                                        //主函数
         init();
         while(1)
                keycontrol();
                 write_com(0x80);
                for(num=0;num<4;num++)
                   write_date(table[num]);
                   delayms(5);
                if(count==20)        //20次50毫秒为1秒
                      count=0;
                          sec++;
                          if(sec==60)
                             sec=0;
                                 min++;
                                 if(min==60)
                                    min=0;
                                        hour++;
                                        if(hour==24)
                                            hour=0;
                                          write_sfm(5,hour);
                                    write_sfm(8,min);
                             write_sfm(11,sec);
void T0_time()interrupt 1
         count++;
此帖出自51单片机论坛
楼主原因在哪里  详情 回复 发表于 2015-6-2 16:44
340
乱码与proteus无关
此帖出自51单片机论坛
29
我知道的,只是不知道我程序那里出问题了,我检查不出来
此帖出自51单片机论坛
我之前仿过。你试试吧液晶旋转。正对着自己。如果你是倒了90度就乱码。还不行的话发个仿真图和代码给你。看看我这个和你的区别在哪。  详情 回复 发表于 2014-4-20 19:11
1185
此帖出自51单片机论坛
恩恩,谢谢哈,我已经找到原因了,就是我程序有一个地方出了点小问题,现在已经解决了,谢谢啦  详情 回复 发表于 2014-4-21 19:05
29
youluo 发表于 2014-4-20 19:11
我之前仿过。你试试吧液晶旋转。正对着自己。如果你是倒了90度就乱码。还不行的话发个仿真图和代码给你。 ...
此帖出自51单片机论坛
楼主原因在哪里
此帖出自51单片机论坛
