2485|1
小弟初学VHDL,看别人的结构写了个ALU的程序,但怎么编译都过不去,求大神帮忙改下 [复制链接]
谢谢,,非常感谢
LIBRARY IEEE;
USE IEEE.std_logic_1164.ALL;
USE IEEE.std_logic_unsigned.ALL;
USE IEEE.std_logic_arith.ALL;
entity ALU is
port(cin: in std_logic;
alu_function: in std_logic_vector(2 downto 0);
a_in: in std_logic_vector(7 downto 0);
b_in: in std_logic_vector(7 downto 0);
alu_out: out std_logic_vector(7 downto 0);
z: out std_logic;
c: out std_logic;
v: out std_logic;
                s: out std_logic
end ALU;
Architecture win of ALU is
signal midout: std_logic_vector(15 downto 0);
signal temp: std_logic_vector(15 downto 0);
begin
process(a_in,b_in,alu_function)
constant ADD:std_logic_vector:="000";
constant SUB:std_logic_vector:="001";
constant ANDOP:std_logic_vector:="010";
constant OROP:std_logic_vector:="011";
constant XOROP:std_logic_vector:="100";
constant SHL:std_logic_vector:="101";
constant SHR:std_logic_vector:="110";
cinextend:="000000000000000"&cin;
begin
case alu_function is
when ADD=>midout<=a_in + b_in + cin;
when SUB=>midout<=b_in - a_in;
when ANDOP=>midout<=a_in and b_in;
when OROP=>midout<=a_in or b_in;
when XOROP=>midout<=a_in xor b_in;
when SHL=>midout<=b_in(14 downto 0)&"0";
when SHR=>midout<="0"&b_in(15 downto 0);
when others=>midout<="ZZZZZZZZZZZZZZZZ";
end case;
if(alu_function="000" or "001")
    if(a_in(15)="1" and b_in(15)="1" and midout(15)="0") or (a_in(15)="0" and b_in(15)="0" and midout(15)="1" )
    then V<="1";
    else V<="0";
    end if;
end if;
if(alu_function="000")
then temp:="1111111111111111"-b_in-cinextend;
if temp
      c<="1";
else c<="0";
end if;
else if(alu_function="001")
  if b_in
      c<="1";
  else c="0";
  end if;
else if(alu_function="101")
c
else if(alu_function="110")
c<=a_in(0);
else c<="0";
end if;
end process;
alu_out<=midout;
end win;
此帖出自FPGA/CPLD论坛
注意数据BIT位数  详情 回复 发表于 2014-4-16 23:06
注意数据BIT位数
此帖出自FPGA/CPLD论坛
直播时间:3月12日(周三)上午10:00
直播奖励:多功能榨汁机、蓝牙音箱、手机支架
