3264|11
一个可调时间的时钟 搞了一个星期了 没找出哪有问题 [复制链接]
#include"reg51.h"
#define smg P1
#define sj P0
sbit sheding=P1^3;
sbit jiashi=P1^4;
code unsigned char shumaguan[6]={0x07,0x06,0x05,0x04,0x03,0x02};
code unsigned char shijian[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
unsigned char m,s,h,saomiao,a=0;
unsigned long t;
延时函数
void delay(unsigned int yanshi)
unsigned char i;
while(--yanshi)
{for(i=0;i>120;i++);
调时函数
void tiaoshi(void)
switch(a)
{case 1:
  if(!jiashi)
  delay(20);
   if(!jiashi)
   m++;
  break;
case 2:
  if(!jiashi)
  {delay(20);
   if(jiashi==0)
   s++;
  break;
case 3:
  if(!jiashi)
  {delay(20);
   if(!jiashi)
   h++;
  break;
  case 0:
  break;
if(m>60)
m=0;
if(s>60)
s=0;
if(h>24)
h=0;
void shijianjinwei(void)
if(t>120)
{t=0;
m++;
if(m>59)
{m=0;
s++;
if(s>59)
{s=0;
h++;
if(h>23)
h=0;
if(t>249)
t=0;
if(m>59)
m=0;
if(s>59)
s=0;
if(h>23)
h=0;
void xianshi(void)
switch(saomiao)
case 0:                                //秒个位
sj=shijian[m%10];
smg=shumaguan[0];
break;
case 1:                                //秒十位
sj=shijian[m%100/10];
smg=shumaguan[1];
break;
case 2:                                 //分个位
sj=shijian[s%10]|0x80;
smg=shumaguan[2];
break;
case 3:                                 //分十位
sj=shijian[s%100/10];
smg=shumaguan[3];
break;
case 4:                                 //小时个位
sj=shijian[h%10]|0x80;
smg=shumaguan[4];
break;
case 5:                                 //小时十位
sj=shijian[h%100/10];
smg=shumaguan[5];
break;
saomiao++;
t++;
if(saomiao>5)
saomiao=0;
void miaoxianshi(void)
unsigned char miaosaomiao;
switch(miaosaomiao)
{case 0:
sj=shijian[m%10];
smg=shumaguan[0];
break;
case 1:
smg=shumaguan[1];
break;
miaosaomiao++;
if(miaosaomiao>1)
miaosaomiao=0;
void fenxianshi(void)
unsigned char fensaomiao;
switch(fensaomiao)
case 0:
smg=shumaguan[2];
break;
case 1:
smg=shumaguan[3];
break;
fensaomiao++;
if(fensaomiao>1)
fensaomiao=0;
void shixianshi(void)
unsigned char shisaomiao;
switch(shisaomiao)
{case 0:
smg=shumaguan[4];
break;
case 1:
smg=shumaguan[5];
shisaomiao++;
if(shisaomiao>1)
shisaomiao=0;
void main(void)
  jiashi=1;
P3=0xff;
IT1=0;
EX1=1;
EA=1;
a=2;
while(1)
switch(a)
case 1:
miaoxianshi();
tiaoshi();
case 2:
fenxianshi();
tiaoshi();
case 3:
shixianshi();
tiaoshi();
case 0:
xianshi();
shijianjinwei();
void ExInt1IRQ(void) interrupt 1
a++;
以前是直接用按键给a++的,完全没用,现在用外部中断a++还是没用。我直接给a赋值也不能进入调时显示时,分,秒;而且设置的显示那个+1的速度会变快,求大神赐教;
此帖出自单片机论坛
大概看了下,觉得有两个地方不妥: 1.switch语句最后要加上default:break;,不然程序可能会进入死循环。 2.把if(m>60)m=0;放在 if(!jiashi)   {   delay(20);    if(!jiashi)    m++; 后,即 if(!jiashi)   {   delay(20);    if(!jiashi)    m++; if(m>60)m=0; } h和s同理。这是比较正规的编程规范。   详情 回复 发表于 2014-3-21 08:54
1297
写的有点乱,用了好几个开关语句,建议:用定时器中断设置1S来实现数码管时钟,可调时分秒的程序很简单,不需要写这么复杂……
此帖出自单片机论坛
最开始就用的定时器,试了半天不行才改成这样的 ,等下我再试试
此帖出自单片机论坛
gh131413 发表于 2014-3-19 14:13
写的有点乱,用了好几个开关语句,建议:用定时器中断设置1S来实现数码管时钟,可调时分秒的程序很简单,不 ...
最开始就用的定时器,有弄 个定时器+外部中断的,还是没摸到门儿
此帖出自单片机论坛
#include"reg51.h"
sbit P1_4=P1^4;//调整时间 +1
code unsigned char ledbyte[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};        //0。。。。。9
code unsigned char led[7]={0x07,0x06,0x05,0x04,0x03,0x02,0x01};//第一个数码管......第7个数码管
unsigned char m; //秒
unsigned char s; //分
unsigned char h; //小时
unsigned char sm;//扫描数码管的时间
unsigned char w; //星期
unsigned char t; //250t=1s
unsigned char a; //选择 秒 分 或小时
延时
void delay(unsigned char b)
{unsigned char c;
while(--b)
for(c=0;c>120;c++);
正常显示时间
void xianshi(void)
switch(sm)
{case 0:
P0=ledbyte[m%10];
P1=led[0];
case 1:
P0=ledbyte[m%100/10];
P1=led[1];
case 2:
P0=ledbyte[s%10]|0x80;
P1=led[2];
case 3:
P0=ledbyte[s%100/10];
P1=led[3];
case 4:
P0=ledbyte[h%10]|0x80;
P1=led[4];
case 5:
P0=ledbyte[h%100/10];
P1=led[5];
case 6:
P0=ledbyte[w]|0x80;
P1=led[6];
调时
void ts(unsigned char k,p,q)
switch(sm)
{case 1,2,3:
P0=ledbyte[k%10]|0x80;
P1=led[p];
  case 4,5,6:
P0=ledbyte[k%100/10];
P1=led[q];
if(P1_4==0)
{delay(20);
if(P1_4==0)
k++;
主函数
void main(void)
TMOD=0x01;
EA=1;
TR0=1;
ET0=0x01;
TH0=(65536-4000)/256;
TL0=(65536-4000)%256;
P1_4=1;
P3=0xff;
IT1=1;
EX1=1;
while(1)
switch(a)
{case 0:
{xianshi();
if(t>255)
{t=0;
m++;
if(m>60)
{m=0;
s++;
if(s>24)
{s=0;
w++;
if(w>7)
w=1;
case 1:
  ts(m,0,1);
  if(m>59)
  m=0;
case 2:
ts(s,2,3);
if(s>59)
s=0;
case 3:
ts(h,4,5);
if(h>23)
h=0;
case 4:
if(P1_4==0)
{delay(20);
if(P1_4==0)
w++;}
P0=ledbyte[w];
P1=led[6]|0x80;
if(w>7)
w=0;
定时器0中断
void timer0(void) interrupt 1
sm++;
t++;
if(sm>6)
sm=0;
if(t>249)
{t=0;
s++;
外部中断   按键中断a+1
void ExInt1IRQ(void) interrupt 2
{delay(50);
a++;
if(a>4)
a=0;
此帖出自单片机论坛
上面这个新写的 用定时器和外部中断的   还是......没正常的
下面是原理图
此帖出自单片机论坛
查看本帖全部讨论,请登录或者注册
此帖出自单片机论坛
查看本帖全部讨论,请登录或者注册
此帖出自单片机论坛
查看本帖全部讨论,请登录或者注册
此帖出自单片机论坛
查看本帖全部讨论,请登录或者注册
此帖出自单片机论坛
查看本帖全部讨论,请登录或者注册
此帖出自单片机论坛
查看本帖全部讨论,请登录或者注册
此帖出自单片机论坛
福禄克有奖直播:高精度测温赋能电子制造 报名中!
直播时间:2025年2月28日(周五)上午10:00
直播主题:高精度测温赋能电子制造
小伙伴们儿快来报名直播吧~好礼等你拿!
