2591|1
853
关于wince RegFlushKey 函数了解 [复制链接]
在wince6.0 随便找个例子看看
BOOL CApplicationPropPage::WriteRegistrySettings()
        DEBUGMSG (1, (L"CApplicationPropPage::WriteRegistrySettings() \n"));
        /* Set RDP Connection-specific values to the registry */
        HKEY hKeyConnection;
        TCHAR szPath [s_MAX_PATHLEN] = {0};
        StringCchCopy(szPath, s_MAX_PATHLEN, REG_TSC_PATH);
        StringCchCat(szPath, s_MAX_PATHLEN, L"\\");
        StringCchCat(szPath, s_MAX_PATHLEN, m_pConnMgr->m_szConnectionName);
        // Open the specified connection key
        DWORD dwResult = RegOpenKeyEx(HKEY_CURRENT_USER, szPath,
                                                        0, KEY_WRITE, &hKeyConnection);
        if (dwResult != ERROR_SUCCESS)
                LPCTSTR pszErrorTitle = LoadStringEx (IDS_REG_SET_FAILED);
                LPCTSTR pszMsg = LoadStringEx (IDS_REG_SET_FAILED_MESSAGE);
                TCHAR szMsg [MAX_DISPLAY_STRING] = {0};
                wsprintf (szMsg, pszMsg, GetLastError());
                MessageBox (szMsg, pszErrorTitle, MB_ICONINFORMATION | MB_OK);
                return FALSE;
        // For the Application page, check to see what the user has selected
        if (m_bDesktop)
                dwResult = RegSetValueEx(hKeyConnection, PROP_STARTPROGRAM, 0, REG_SZ,
        (BYTE *)(_T("")), (wcslen(_T("")) * sizeof(TCHAR))
        + sizeof(TCHAR));
                        // Close key
                        RegCloseKey(hKeyConnection);
                        return FALSE;
                // Delete "Desktop" and "Shell Working Directory" values from the registry
                RegDeleteValue(hKeyConnection, _T("Desktop"));
                RegDeleteValue(hKeyConnection, PROP_WORKDIR);
        else
                DWORD dwDesktop = 2;
                dwResult = RegSetValueEx(hKeyConnection, _T("Desktop"), 0 , REG_DWORD,
                                                             (BYTE *)&dwDesktop, sizeof(DWORD));
                        // Close key
                        return FALSE;
        (BYTE *)(LPTSTR)m_szAlternateShell,
        (wcslen((LPTSTR)m_szAlternateShell) * sizeof(TCHAR))
        + sizeof(TCHAR));
                        // Close key
                        return FALSE;
                dwResult = RegSetValueEx(hKeyConnection, PROP_WORKDIR, 0, REG_SZ,
        (BYTE *)(LPTSTR)m_szShellWorkingDirectory,
        (wcslen((LPTSTR)m_szShellWorkingDirectory) * sizeof(TCHAR))
        + sizeof(TCHAR));
                        StringCchPrintf (szMsg, MAX_DISPLAY_STRING, pszMsg, GetLastError());
                        // Close key
                        return FALSE;
        // Close key
        // Put up the wait cursor
        HCURSOR hOldCursor = SetCursor (LoadCursor (NULL, IDC_WAIT));
        // Flush the MSTSC key
        HKEY hKeyFlush;
        RegOpenKeyEx(HKEY_CURRENT_USER, REG_TSC_PATH, 0, KEY_WRITE, &hKeyFlush);
        RegFlushKey(hKeyFlush);
        RegCloseKey(hKeyFlush);
        // Flush the registered connections key
        RegOpenKeyEx(HKEY_LOCAL_MACHINE, REGISTRATION_CONNECTIONS_KEY, 0, KEY_WRITE, &hKeyFlush);
        // Remove the wait cursor
        SetCursor (hOldCursor);
        return TRUE;
个人签名如果对linux,Android,wince 等嵌入式底层有兴趣的,请加这个QQ群吧,群号:27100460
853
在 RegCloseKey 之前调用。
在MSDN 介绍了这个函数的作用
This function writes all the attributes of the specified open registry key into the registry.
写入注册表。在 RegCloseKey 之前调用。
快来报名!
