#include
#include "IIC.h"
#include "IIC.c"
uint flag=0;
uint tosin[256]={0x80,0x83,0x86,0x89,0x8d,0x90,0x93,0x96,0x99,0x9c,0x9f,0xa2,0xa5,0xa8,0xab,0xae,0xb1,0xb4,0xb7,0xba,0xbc,0xbf,0xc2,0xc5
,0xc7,0xca,0xcc,0xcf,0xd1,0xd4,0xd6,0xd8,0xda,0xdd,0xdf,0xe1,0xe3,0xe5,0xe7,0xe9,0xea,0xec,0xee,0xef,0xf1,0xf2,0xf4,0xf5
,0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfd
,0xfd,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,0xf4,0xf2,0xf1,0xef,0xee,0xec,0xea,0xe9,0xe7,0xe5,0xe3,0xe1,0xde,0xdd,0xda
,0xd8,0xd6,0xd4,0xd1,0xcf,0xcc,0xca,0xc7,0xc5,0xc2,0xbf,0xbc,0xba,0xb7,0xb4,0xb1,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x99
,0x96,0x93,0x90,0x8d,0x89,0x86,0x83,0x80,0x80,0x7c,0x79,0x76,0x72,0x6f,0x6c,0x69,0x66,0x63,0x60,0x5d,0x5a,0x57,0x55,0x51
,0x4e,0x4c,0x48,0x45,0x43,0x40,0x3d,0x3a,0x38,0x35,0x33,0x30,0x2e,0x2b,0x29,0x27,0x25,0x22,0x20,0x1e,0x1c,0x1a,0x18,0x16
,0x15,0x13,0x11,0x10,0x0e,0x0d,0x0b,0x0a,0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x02,0x01,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02 ,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0d,0x0e,0x10,0x11,0x13,0x15
,0x16,0x18,0x1a,0x1c,0x1e,0x20,0x22,0x25,0x27,0x29,0x2b,0x2e,0x30,0x33,0x35,0x38,0x3a,0x3d,0x40,0x43,0x45,0x48,0x4c,0x4e
,0x51,0x55,0x57,0x5a,0x5d,0x60,0x63,0x66 ,0x69,0x6c,0x6f,0x72,0x76,0x79,0x7c,0x80 };
uchar sin64[64]={135,145,158,167,176,188,199,209,218,226,234,240,245,249,252,254,254,253,251,247,243,237,230,222,213,204,193,182,170,158,146,133,121,108,96,84,72,61,50,41,32,24,17,11,7,3,1,0,0,2,5,9,14,20,28,36,45,55,66,78,90,102,114,128};
uchar sin40[40]={ 0x7F,0x93,0xA6,0xB9,0xCA,0xD9,0xE6,0xF1,0xF8,0xFD,0xFE,0xFD,0xF8,0xF1,0xE6,0xD9
,0xCA,0xB9,0xA6,0x93,0x7F,0x6B,0x58,0x45,0x34,0x25,0x18,0x0D,0x06,0x01,0x00,0x01
,0x06,0x0D,0x18,0x25,0x34,0x45,0x58,0x6B};
uchar sin20[20]={ 0x7F,0xA6,0xCA,0xE6,0xF8,0xFE,0xF8,0xE6,0xCA,0xA6,0x7F,0x58,0x34,0x18,0x06,0x00
,0x06,0x18,0x34,0x58};
uchar sin60[61]={0x7F,0x8C,0x9A,0xA6,0xB3,0xBF,0xCA,0xD4,0xDE,0xE6,0xED,0xF3,0xF8,0xFC,0xFE,0xFE
,0xFE,0xFC,0xF8,0xF3,0xED,0xE6,0xDE,0xD4,0xCA,0xBF,0xB3,0xA6,0x9A,0x8C,0x7F,0x72
,0x64,0x58,0x4B,0x3F,0x34,0x2A,0x20,0x18,0x11,0x0B,0x06,0x02,0x00,0x00,0x00,0x02
,0x06,0x0B,0x11,0x18,0x20,0x2A,0x34,0x3F,0x4B,0x58,0x64,0x72,0x7F};
uchar sin80[80]={ 0x7F,0x89,0x93,0x9D,0xA6,0xB0,0xB9,0xC2,0xCA,0xD2,0xD9,0xE0,0xE6,0xEC,0xF1,0xF5
,0xF8,0xFB,0xFD,0xFE,0xFE,0xFE,0xFD,0xFB,0xF8,0xF5,0xF1,0xEC,0xE6,0xE0,0xD9,0xD2
,0xCA,0xC2,0xB9,0xB0,0xA6,0x9D,0x93,0x89,0x7F,0x75,0x6B,0x61,0x58,0x4E,0x45,0x3C
,0x34,0x2C,0x25,0x1E,0x18,0x12,0x0D,0x09,0x06,0x03,0x01,0x00,0x00,0x00,0x01,0x03
,0x06,0x09,0x0D,0x12,0x18,0x1E,0x25,0x2C,0x34,0x3C,0x45,0x4E,0x58,0x61,0x6B,0x75};
uchar sin50[50]={ 0x7F,0x8F,0x9F,0xAE,0xBC,0xCA,0xD6,0xE1,0xEB,0xF2,0xF8,0xFC,0xFE,0xFE,0xFC,0xF8
,0xF2,0xEB,0xE1,0xD6,0xCA,0xBC,0xAE,0x9F,0x8F,0x7F,0x6F,0x5F,0x50,0x42,0x34,0x28
,0x1D,0x13,0x0C,0x06,0x02,0x00,0x00,0x02,0x06,0x0C,0x13,0x1D,0x28,0x34,0x42,0x50
,0x5F,0x6F};
uchar Write_DAC(uchar wdata);
void Clock_Init();
void TimerA_Init();
函数名称:Write_DAC
功 能:向DAC中写入输出电压数据
参 数:无
返回值 :写入结果:1--成功,0--失败
start();
write1byte(0x98); //DAC的设备地址
if(check()) write1byte(wdata>>4); //写控制模式和电压数据的高四位
else return 0;
if(check()) write1byte(wdata<<4); //写电压数据的低四位
else return 0;
if(check()) stop();
else return 0;
return 1;
// 系统时钟初始化
void Clock_Init()
uchar i;
BCSCTL1&=~XT2OFF; //打开XT振荡器
BCSCTL2|=SELM1+SELS; //MCLK为8MHZ,SMCLK为8MHZ
do{
IFG1&=~OFIFG; //清除震荡标志
for(i=0;i<100;i++)
_NOP(); //延时等待
while((IFG1&OFIFG)!=0); //如果标志为1,则继续循环等待
IFG1&=~OFIFG;
void TimerA_Init()
TACTL=TASSEL_2+MC_1+TACLR;
CCTL0=CCIE;
CCR0=500; //30KHZ CCR0约为133
/****************主函数****************/
void main(void)
/*下面六行程序关闭所有的IO口*/
P1DIR = 0XFF;P1OUT = 0XFF;
P2DIR = 0XFF;P2OUT = 0xff;
P3DIR = 0XFF;P3OUT = 0XFF;
P4DIR = 0XFF;P4OUT = 0xff;
P5DIR = 0XFF;P5OUT = 0xff;
P6DIR = 0XFF;P6OUT = 0XFF;
WDTCTL = WDTPW + WDTHOLD; //停止看门狗
Clock_Init();
Set_IO();
TimerA_Init();
_EINT(); //设置IIC使用的IO方向
while(1)
if(0
Write_DAC(sin50[flag]);
#pragma vector = TIMERA0_VECTOR
__interrupt void Timer_A(void)
// CCR0+=1;
flag++;
if(flag==50)
flag=0;
