2654|0
用C51做一个计时器 [复制链接]
给我下面这段程序加一个暂停和清零功能呗
//主程序
#include
sbit ksec=P3^0;
sbit kmin=P3^1;
sbit khour=P3^2;
unsigned char secshi=0,secge=0,minshi=0,minge=0,hourshi=0,hourge=0;
unsigned int num=0,sec=0,min=0,hour=0;
unsigned char code table[10]={0x3f,0xxx,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
void delay(unsigned int);
void keyscan();
void display();
main()
{TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;ET0=1;TR0=1;
while(1)
{display();
  keyscan();
void delay(unsigned int z)
{unsigned int x,y;
  for(x=z;x>0;x--)
   for(y=110;y>0;y--);}
//时钟设置子程序
void time0() interrupt 1
{num++;
//定时器中断子程序
{num++;
//LED显示子程序
void display()
{if(num==20)
   {num=0;
    sec++;
    if(sec==60)
     {sec=0;
      min++;
      if(min==60)
        {min=0;
         hour++;
         if(hour==24)
           {hour=0;
            min=0;
            sec=0;
secge=sec%10;
secshi=sec/10;
minge=min%10;
minshi=min/10;
hourge=hour%10;
hourshi=hour/10;
P2=0xfe;
P0=table[secge];
delay(5);
P2=0xfd;
P0=table[secshi];
delay(5);
P2=0xfb;
P0=0x40;
delay(5);
P2=0xf7;
P0=table[minge];
delay(5);
P2=0xef;
P0=table[minshi];
delay(5);
P2=0xdf;
P0=0x40;
delay(5);
P2=0xbf;
P0=table[hourge];
delay(5);
P2=0x7f;
P0=table[hourshi];
delay(5);
//按键控制子程序
void keyscan()
{if(ksec==0)
   {delay(10);
    if(ksec==0)
      {sec++;
       if(sec>=60)
       sec=0;
  while(ksec==0)
  display();}
  if(kmin==0)
    {delay(10);
     if(kmin==0)
       {min++;
        if(min>=60)
        min=0;
  while(kmin==0)
  display();
  if(khour==0)
    {delay(10);
     if(khour==0)
       {hour++;
        if(hour>=60)
        hour=0;
  while(khour==0)
  display();
此帖出自51单片机论坛
