2684|2
OPA454的E/D和E/D com是什么意思,咋用啊 [复制链接]
此帖出自模拟电子论坛
使能端的电压范围在5.5V [attach]139429[/attach]   详情 回复 发表于 2013-12-30 16:33
1185
The output can be independently disabled using the
Enable/Disable Pin that has its own common return
pin to allow easy interface to low-voltage logic
circuitry. This disable is accomplished without
disturbing the input signal path, not only saving power
but also protecting the load.
楼主可以看文档。用来使能和禁止输出,以保护电源盒负载disabled,,enabled
此帖出自模拟电子论坛
342
使能端的电压范围在5.5V
此帖出自模拟电子论坛
