1831|2
msp430f149 ADC [复制链接]
我主频选的8M的晶震  ADC想采样用32768hz的ACLK    但是选着不了  都是按8m跑的
代码如下
  WDTCTL = WDTPW | WDTHOLD;                 // Disable the Watchdog.
     unsigned int iq0;
   _DINT();
   BCSCTL1 &=~XT2OFF;
   do
      IFG1 &= ~OFIFG;                                                        // 清除振荡器失效标志
      for (iq0 = 0xFF; iq0 > 0; iq0--);        // 延时,等待XT2起振
   while ((IFG1 & OFIFG) != 0);                // 判断XT2是否起振
   BCSCTL2 = SELM1+SELS;                // MCLK,SMCLK时钟为XT2
//选择主频
  P2DIR = 0x0F;
  P2OUT = 0x0E;
  P1DIR = 0xff;                             // set port to outputs
  P1OUT = 0;                                // reset port outputs
  P6SEL |= 0x01;                            // select A0 input
  ADC12CTL0 = ADC12ON+SHT0_1+REF2_5V+REFON; // Setup ADC12
  ADC12CTL1 = SHP+CONSEQ_2+SHS_1;           // Timer triggers sampling
  ADC12MCTL0 = INCH_0 + SREF_1;
  ADC12IE = 0x0001;                         // Enable ADC12IFG.0
  TACCR0 = 1500;                            // Delay to allow Ref to settle
  TACCTL0 |= CCIE;                          // Compare-mode interrupt.
  TACTL = TASSEL_1 | MC_1;                  // TACLK = ACLK, Up mode.
  _BIS_SR(LPM3_bits + GIE);                 // Wait for delay, Enable interrupts
  TACCTL0 &= ~CCIE;                         // Disable timer
  P2SEL |= BIT3;                            // Set for Timer A1
  P2DIR |= 0x08;
  TACCR0 = 7;                               // Init TACCR0 w/ sample prd=CCR0+1
  TACCR1 = 4;                               // Trig for ADC12 sample & convert
  TACCTL1 = OUTMOD_3;                       // Set/reset
  TACTL = TACLR | MC_1 | TASSEL_1;          // ACLK, clear TAR, up mode
//AD设置
谁能帮看看哪的毛病?
[attach]139051[/attach]   详情 回复 发表于 2013-12-26 21:44
5014
裸片初长成(初级)
这个我试了  选完还是5m的ADC12OSC  详情 回复 发表于 2013-12-27 08:48
个人签名《MCU工程师炼成记》作者之一
快来报名!
